[GRASS-SVN] r61979 - grass/trunk/vector/v.distance
svn_grass at osgeo.org
Mon Sep 15 11:36:39 PDT 2014
Author: mmetz
Date: 2014-09-15 11:36:39 -0700 (Mon, 15 Sep 2014)
New Revision: 61979
grass/trunk/vector/v.distance/distance.c
grass/trunk/vector/v.distance/local_proto.h
grass/trunk/vector/v.distance/main.c
v.distance: use Vect_line_geodesic_distance()
Modified: grass/trunk/vector/v.distance/distance.c
--- grass/trunk/vector/v.distance/distance.c 2014-09-15 18:27:01 UTC (rev 61978)
+++ grass/trunk/vector/v.distance/distance.c 2014-09-15 18:36:39 UTC (rev 61979)
@@ -1,3 +1,4 @@
+#include <math.h>
#include <grass/gis.h>
#include <grass/glocale.h>
#include <grass/vector.h>
@@ -3,5 +4,5 @@
#include "local_proto.h"
-/* TODO: geodesic distance for latlong */
+dist_func *line_distance;
int get_line_box(const struct line_pnts *Points,
@@ -37,6 +38,23 @@
return 1;
+/* segment angle */
+double sangle(struct line_pnts *Points, int segment)
+ double dx, dy;
+ if (Points->n_points < 2 || segment < 1)
+ return -9;
+ if (segment >= Points->n_points)
+ G_fatal_error(_("Invalid segment number %d for %d points"),
+ segment, Points->n_points);
+ dx = Points->x[segment] - Points->x[segment - 1];
+ dy = Points->y[segment] - Points->y[segment - 1];
+ return atan2(dy, dx);
/* calculate distance parameters between two primitives
* return 1 point to point
* return 2 point to line
@@ -49,18 +67,15 @@
double *tx, double *ty, double *tz,
double *talong, double *tangle,
double *dist,
- int with_z,
- int geodesic)
+ int with_z)
int i, fseg, tseg, tmp_seg;
double tmp_dist, tmp_x, tmp_y, tmp_z, tmp_along;
int ret = 1;
static struct line_pnts *iPoints = NULL;
- static struct line_pnts *LPoints = NULL;
if (!iPoints) {
iPoints = Vect_new_line_struct();
- LPoints = Vect_new_line_struct();
*dist = PORT_DOUBLE_MAX;
@@ -82,7 +97,7 @@
/* point -> point */
if ((ftype & GV_POINTS) && (ttype & GV_POINTS)) {
- Vect_line_distance(TPoints, FPoints->x[0], FPoints->y[0],
+ line_distance(TPoints, FPoints->x[0], FPoints->y[0],
FPoints->z[0], with_z, tx, ty, tz, dist,
NULL, talong);
@@ -90,11 +105,11 @@
/* point -> line and line -> line */
if ((ttype & GV_LINES)) {
- tseg = 1;
+ fseg = tseg = 0;
/* calculate the min distance between each point in fline with tline */
for (i = 0; i < FPoints->n_points; i++) {
- tmp_seg = Vect_line_distance(TPoints, FPoints->x[i],
+ tmp_seg = line_distance(TPoints, FPoints->x[i],
FPoints->y[i], FPoints->z[i],
with_z, &tmp_x, &tmp_y, &tmp_z,
&tmp_dist, NULL, &tmp_along);
@@ -108,22 +123,39 @@
*tz = tmp_z;
*talong = tmp_along;
tseg = tmp_seg;
+ fseg = i + 1;
- Vect_point_on_line(TPoints, *talong, NULL, NULL, NULL,
- tangle, NULL);
+ *tangle = sangle(TPoints, tseg);
+ if (FPoints->n_points > 1 && fseg > 0) {
+ int np = FPoints->n_points;
+ fseg--;
+ if (fseg > 0) {
+ FPoints->n_points = fseg + 1;
+ *falong = Vect_line_length(FPoints);
+ FPoints->n_points = np;
+ np = fseg;
+ if (fseg == 0)
+ fseg = 1;
+ *fangle = sangle(FPoints, fseg);
ret++;
/* line -> point and line -> line */
if (ftype & GV_LINES) {
- fseg = 1;
+ fseg = tseg = 0;
/* calculate the min distance between each point in tline with fline */
for (i = 0; i < TPoints->n_points; i++) {
- tmp_seg = Vect_line_distance(FPoints, TPoints->x[i],
+ tmp_seg = line_distance(FPoints, TPoints->x[i],
TPoints->y[i], TPoints->z[i],
@@ -136,13 +168,28 @@
*tx = TPoints->x[i];
*ty = TPoints->y[i];
*tz = TPoints->z[i];
- *talong = 0.;
- *tangle = -9.;
fseg = tmp_seg;
+ tseg = i + 1;
- Vect_point_on_line(FPoints, *falong, NULL, NULL, NULL,
- fangle, NULL);
+ if (TPoints->n_points > 1 && tseg > 0) {
+ int np = TPoints->n_points;
+ tseg--;
+ if (tseg > 0) {
+ TPoints->n_points = tseg + 1;
+ *talong = Vect_line_length(TPoints);
+ TPoints->n_points = np;
+ np = tseg;
+ if (tseg == 0)
+ tseg = 1;
ret++;
if ((ttype & GV_LINES) && *dist > 0) {
@@ -162,63 +209,22 @@
*fz = *tz = iPoints->z[0];
/* falong, talong */
- Vect_line_distance(FPoints, iPoints->x[0],
+ fseg = line_distance(FPoints, iPoints->x[0],
iPoints->y[0], iPoints->z[0],
with_z, NULL, NULL, NULL,
NULL, NULL, falong);
- Vect_line_distance(TPoints, iPoints->x[0],
+ tseg = line_distance(TPoints, iPoints->x[0],
NULL, NULL, talong);
/* fangle, tangle */
- fangle, NULL);
- tangle, NULL);
- if (geodesic) {
- if (*fx != *tx || *fy != *ty || (with_z && *fz != *tz)) {
- Vect_reset_line(LPoints);
- Vect_append_point(LPoints, *fx, *fy, *fz);
- Vect_append_point(LPoints, *tx, *ty, *tz);
- *dist = Vect_line_geodesic_length(LPoints);
- /* falong */
- if (FPoints->x[0] != *fx || FPoints->y[0] != *fy ||
- (with_z && FPoints->z[0] != *fz)) {
- fseg = Vect_line_distance(FPoints, *tx, *ty, *tz,
- with_z, &tmp_x, &tmp_y, &tmp_z,
- &tmp_dist, NULL, &tmp_along);
- for (i = 0; i < fseg; i++)
- Vect_append_point(LPoints, FPoints->x[i], FPoints->y[i],
- FPoints->z[i]);
- *falong = Vect_line_geodesic_length(LPoints);
- /* talong */
- if (TPoints->x[0] != *tx || TPoints->y[0] != *ty ||
- (with_z && TPoints->z[0] != *tz)) {
- tseg = Vect_line_distance(TPoints, *fx, *fy, *fz,
- for (i = 0; i < tseg; i++)
- Vect_append_point(LPoints, TPoints->x[i], TPoints->y[i],
- TPoints->z[i]);
- *talong = Vect_line_geodesic_length(LPoints);
return ret;
@@ -234,8 +240,7 @@
double *dist,
- int with_z,
- int geodesic)
+ int with_z)
int i, j;
double tmp_dist;
@@ -306,7 +311,10 @@
line2line(Points, type, aPoints, GV_BOUNDARY,
fx, fy, fz, falong, fangle,
tx, ty, tz, talong, tangle,
- dist, with_z, geodesic);
+ dist, with_z);
+ *talong = 0;
+ *tangle = -9;
return 1;
@@ -330,7 +338,7 @@
line2line(Points, type, iPoints[j], GV_BOUNDARY,
&tmp_fx, &tmp_fy, &tmp_fz, &tmp_falong, &tmp_fangle,
&tmp_tx, &tmp_ty, &tmp_tz, &tmp_talong, &tmp_tangle,
- &tmp_dist, with_z, geodesic);
+ &tmp_dist, with_z);
if (*dist > tmp_dist) {
*dist = tmp_dist;
@@ -344,7 +352,7 @@
*tx = tmp_tx;
*ty = tmp_ty;
*tz = tmp_tz;
- *talong = tmp_talong;
+ *talong = 0;
*tangle = tmp_tangle;
@@ -366,6 +374,9 @@
*tx = Points->x[i];
*ty = Points->y[i];
*tz = Points->z[i];
+ *fangle = *tangle = -9.;
+ *falong = *talong = 0.;
*dist = 0;
@@ -377,6 +388,10 @@
if (*dist == 0) {
/* the line intersected with the isle boundary
* -> line is partially inside the area */
return 1;
/* else continue with next point */
@@ -417,8 +432,10 @@
+ dist, with_z);
+ *talong = 0;
if (*dist == 0)
return 1;
Modified: grass/trunk/vector/v.distance/local_proto.h
--- grass/trunk/vector/v.distance/local_proto.h 2014-09-15 18:27:01 UTC (rev 61978)
+++ grass/trunk/vector/v.distance/local_proto.h 2014-09-15 18:36:39 UTC (rev 61979)
@@ -1,6 +1,9 @@
#include <grass/dbmi.h>
+#ifndef _LOCAL_PROTO_
+#define _LOCAL_PROTO_
/* define codes for characteristics of relation between two nearest features */
#define CAT 1 /* category of nearest feature */
#define FROM_X 2 /* x coordinate of nearest point on 'from' feature */
@@ -35,6 +38,12 @@
char *column; /* column name */
} UPLOAD;
+typedef int dist_func(const struct line_pnts *, double, double, double, int,
+ double *, double *, double *, double *, double *,
+ double *);
+extern dist_func *line_distance;
/* cmp.c */
int cmp_near(const void *, const void *);
int cmp_near_to(const void *, const void *);
@@ -50,8 +59,7 @@
double *dist,
- int with_z,
- int geodesic);
+ int with_z);
int line2area(const struct Map_info *To,
struct line_pnts *Points, int type,
int area, const struct bound_box *abox,
@@ -60,8 +68,9 @@
double *dist,
- int with_z,
- int geodesic);
+ int with_z);
/* print.c */
int print_upload(NEAR *, UPLOAD *, int, dbCatValArray *, dbCatVal *, char *);
+#endif
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2014-09-15 18:27:01 UTC (rev 61978)
+++ grass/trunk/vector/v.distance/main.c 2014-09-15 18:36:39 UTC (rev 61979)
@@ -238,6 +238,10 @@
do_all = TRUE;
geodesic = G_projection() == PROJECTION_LL;
+ if (geodesic)
+ line_distance = Vect_line_geodesic_distance;
+ else
+ line_distance = Vect_line_distance;
/* Read upload and column options */
/* count */
@@ -707,7 +711,7 @@
line2line(FPoints, ftype, TPoints, ttype,
if (tmp_dist > max || tmp_dist < min)
continue; /* not in threshold */
@@ -781,7 +785,7 @@
line2area(&To, FPoints, ftype, aList->id[i], &aList->box[i],
@@ -992,7 +996,7 @@
line2area(&From, TPoints, ttype, area, &fbox,
@@ -1078,7 +1082,7 @@
poly = line2area(&From, TPoints, ttype, area, &fbox,
if (poly == 3) {
/* 'to' outer ring is outside 'from' area,
@@ -1102,7 +1106,7 @@
poly = line2area(&To, FPoints, ttype, tarea, &aList->box[i],
/* inside isle ? */
poly = poly == 2;
@@ -1122,7 +1126,7 @@
&tmp2_tx, &tmp2_ty, &tmp2_tz, &tmp2_talong, &tmp2_tangle,
&tmp2_fx, &tmp2_fy, &tmp2_fz, &tmp2_falong, &tmp2_fangle,
- &tmp2_dist, with_z, geodesic);
+ &tmp2_dist, with_z);
if (tmp2_dist < tmp_dist) {
tmp_dist = tmp2_dist;
@@ -1306,7 +1310,10 @@
else if (do_all && opt.table->answer) { /* create new table */
db_set_string(&stmt, "create table ");
db_append_string(&stmt, opt.table->answer);
- db_append_string(&stmt, " (from_cat integer");
+ if (Outp)
+ db_append_string(&stmt, " (cat integer,from_cat integer");
+ else
+ db_append_string(&stmt, " (from_cat integer");
j = 0;
while (Upload[j].upload != END) {
@@ -1375,6 +1382,8 @@
Vect_reset_line(FPoints);
Vect_reset_cats(FCats);
+ Vect_cat_set(FCats, 1, i);
Vect_append_point(FPoints, Near[i].from_x, Near[i].from_y, 0);
if (Near[i].dist == 0) {
@@ -1429,8 +1438,13 @@
else if (do_all) { /* insert new record */
- sprintf(buf1, "insert into %s values ( %d ", opt.table->answer,
- Near[i].from_cat);
+ if (!Outp)
+ sprintf(buf1, "insert into %s values ( %d ", opt.table->answer,
+ Near[i].from_cat);
+ else
+ sprintf(buf1, "insert into %s values ( %d, %d ", opt.table->answer,
+ i, Near[i].from_cat);
db_set_string(&stmt, buf1);
j = 0;
@@ -1655,6 +1669,15 @@
Vect_close(&From);
if (Outp != NULL) {
+ if (do_all && opt.table->answer) {
+ dbConnection connection;
+ db_set_default_connection();
+ db_get_connection(&connection);
+ Vect_map_add_dblink(Outp, 1, NULL, opt.table->answer, "cat",
+ connection.databaseName,
+ connection.driverName);
Vect_build(Outp);
Vect_close(Outp);
