[GRASS-SVN] r61985 - in grass/trunk/temporal: t.connect t.connect/testsuite t.info t.list t.vect.list
svn_grass at osgeo.org
Mon Sep 15 15:34:24 PDT 2014
Author: huhabla
Date: 2014-09-15 15:34:24 -0700 (Mon, 15 Sep 2014)
New Revision: 61985
Added:
grass/trunk/temporal/t.connect/testsuite/
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.vect.list/t.vect.list.py
temporal modules: Enabling mapset specific temporal databases in temporal modules, added new tests. This feature is very experimental.
Added: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py (rev 0)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2014-09-15 22:34:24 UTC (rev 61985)
@@ -0,0 +1,208 @@
+"""Test t.rast.extract
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+import grass.pygrass.modules as pymod
+import subprocess
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+import os
+mapset_count = 0
+class TestRasterExtraction(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ os.putenv("GRASS_OVERWRITE", "1")
+ for i in range(1, 5):
+ cls.runModule("g.mapset", flags="c", mapset="test%i"%i)
+ cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10, res3=10)
+ # Use always the current mapset as temporal database
+ cls.runModule("r.mapcalc", expression="a1 = 100")
+ cls.runModule("r.mapcalc", expression="a2 = 200")
+ cls.runModule("r.mapcalc", expression="a3 = 300")
+ cls.runModule("t.create", type="strds", temporaltype="absolute",
+ output="A", title="A test", description="A test")
+ cls.runModule("t.register", flags="i", type="rast", input="A",
+ maps="a1,a2,a3",
+ start="2001-01-01", increment="%i months"%i)
+ def test_tlist(self):
+ self.runModule("g.mapset", mapset="test1")
+ list_string = """A|test1|2001-01-01 00:00:00|2001-04-01 00:00:00|3
+ A|test2|2001-01-01 00:00:00|2001-07-01 00:00:00|3
+ A|test3|2001-01-01 00:00:00|2001-10-01 00:00:00|3
+ A|test4|2001-01-01 00:00:00|2002-01-01 00:00:00|3"""
+ entries = list_string.split("\n")
+ t_list = SimpleModule("t.list", quiet=True, columns=["name","mapset,start_time","end_time","number_of_maps"], type="strds")
+ self.assertModule(t_list)
+ out = t_list.outputs["stdout"].value
+ for a, b in zip(list_string.split("\n"), out.split("\n")):
+ self.assertEqual(a.strip(), b.strip())
+ def test_trast_list(self):
+ list_string = """a1|test1|2001-01-01 00:00:00|2001-02-01 00:00:00
+ a2|test1|2001-02-01 00:00:00|2001-03-01 00:00:00
+ a3|test1|2001-03-01 00:00:00|2001-04-01 00:00:00"""
+ trast_list = SimpleModule("t.rast.list", quiet=True, flags="s", input="A at test1")
+ self.assertModule(trast_list)
+ out = trast_list.outputs["stdout"].value
+ list_string = """a1|test2|2001-01-01 00:00:00|2001-03-01 00:00:00
+ a2|test2|2001-03-01 00:00:00|2001-05-01 00:00:00
+ a3|test2|2001-05-01 00:00:00|2001-07-01 00:00:00"""
+ trast_list = SimpleModule("t.rast.list", quiet=True, flags="s", input="A at test2")
+ list_string = """a1|test3|2001-01-01 00:00:00|2001-04-01 00:00:00
+ a2|test3|2001-04-01 00:00:00|2001-07-01 00:00:00
+ a3|test3|2001-07-01 00:00:00|2001-10-01 00:00:00"""
+ trast_list = SimpleModule("t.rast.list", quiet=True, flags="s", input="A at test3")
+ list_string = """a1|test4|2001-01-01 00:00:00|2001-05-01 00:00:00
+ a2|test4|2001-05-01 00:00:00|2001-09-01 00:00:00
+ a3|test4|2001-09-01 00:00:00|2002-01-01 00:00:00"""
+ trast_list = SimpleModule("t.rast.list", quiet=True, flags="s", input="A at test4")
+ def test_strds_info(self):
+ self.runModule("g.mapset", mapset="test4")
+ tinfo_string="""id=A at test1
+ name=A
+ mapset=test1
+ start_time=2001-01-01 00:00:00
+ end_time=2001-04-01 00:00:00
+ granularity=1 month"""
+ info = SimpleModule("t.info", flags="g", input="A at test1")
+ self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
+ self.runModule("g.mapset", mapset="test3")
+ tinfo_string="""id=A at test2
+ name=A
+ mapset=test2
+ end_time=2001-07-01 00:00:00
+ granularity=2 months"""
+ info = SimpleModule("t.info", flags="g", input="A at test2")
+ self.runModule("g.mapset", mapset="test2")
+ tinfo_string="""id=A at test3
+ name=A
+ mapset=test3
+ end_time=2001-10-01 00:00:00
+ granularity=3 months"""
+ info = SimpleModule("t.info", flags="g", input="A at test3")
+ tinfo_string="""id=A at test4
+ name=A
+ mapset=test4
+ end_time=2002-01-01 00:00:00
+ granularity=4 months"""
+ info = SimpleModule("t.info", flags="g", input="A at test4")
+ def test_raster_info(self):
+ tinfo_string="""id=a1 at test1
+ name=a1
+ mapset=test1
+ creator=soeren
+ temporal_type=absolute
+ end_time=2001-02-01 00:00:00 """
+ info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test1")
+ tinfo_string="""id=a1 at test2
+ name=a1
+ mapset=test2
+ creator=soeren
+ end_time=2001-03-01 00:00:00 """
+ info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test2")
+ tinfo_string="""id=a1 at test3
+ name=a1
+ mapset=test3
+ creator=soeren
+ end_time=2001-04-01 00:00:00 """
+ info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test3")
+ tinfo_string="""id=a1 at test4
+ name=a1
+ mapset=test4
+ creator=soeren
+ end_time=2001-05-01 00:00:00 """
+ info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test4")
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
Added: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py (rev 0)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2014-09-15 22:34:24 UTC (rev 61985)
@@ -0,0 +1,205 @@
+"""test distributed temporal databases with str3ds
+for details.
+import os
+class testRaster3dExtraction(TestCase):
+ @classmethod
+ cls.runModule("g.mapset", flags="c", mapset="test3d%i"%i)
+ cls.runModule("r3.mapcalc", expression="a1 = 100")
+ cls.runModule("r3.mapcalc", expression="a2 = 200")
+ cls.runModule("r3.mapcalc", expression="a3 = 300")
+ cls.runModule("t.create", type="str3ds", temporaltype="absolute",
+ output="A", title="A test3d", description="A test3d")
+ cls.runModule("t.register", flags="i", type="rast3d", input="A",
+ maps="a1,a2,a3",
+ self.runModule("g.mapset", mapset="test3d1")
+ list_string = """A|test3d1|2001-01-01 00:00:00|2001-04-01 00:00:00|3
+ A|test3d2|2001-01-01 00:00:00|2001-07-01 00:00:00|3
+ A|test3d3|2001-01-01 00:00:00|2001-10-01 00:00:00|3
+ A|test3d4|2001-01-01 00:00:00|2002-01-01 00:00:00|3"""
+ t_list = SimpleModule("t.list", quiet=True, columns=["name","mapset,start_time","end_time","number_of_maps"], type="str3ds")
+ list_string = """a1|test3d1|2001-01-01 00:00:00|2001-02-01 00:00:00
+ a2|test3d1|2001-02-01 00:00:00|2001-03-01 00:00:00
+ a3|test3d1|2001-03-01 00:00:00|2001-04-01 00:00:00"""
+ trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s", input="A at test3d1")
+ list_string = """a1|test3d2|2001-01-01 00:00:00|2001-03-01 00:00:00
+ a2|test3d2|2001-03-01 00:00:00|2001-05-01 00:00:00
+ a3|test3d2|2001-05-01 00:00:00|2001-07-01 00:00:00"""
+ trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s", input="A at test3d2")
+ list_string = """a1|test3d3|2001-01-01 00:00:00|2001-04-01 00:00:00
+ a2|test3d3|2001-04-01 00:00:00|2001-07-01 00:00:00
+ a3|test3d3|2001-07-01 00:00:00|2001-10-01 00:00:00"""
+ trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s", input="A at test3d3")
+ list_string = """a1|test3d4|2001-01-01 00:00:00|2001-05-01 00:00:00
+ a2|test3d4|2001-05-01 00:00:00|2001-09-01 00:00:00
+ a3|test3d4|2001-09-01 00:00:00|2002-01-01 00:00:00"""
+ trast_list = SimpleModule("t.rast3d.list", quiet=True, flags="s", input="A at test3d4")
+ self.runModule("g.mapset", mapset="test3d4")
+ tinfo_string="""id=A at test3d1
+ name=A
+ mapset=test3d1
+ info = SimpleModule("t.info", flags="g", type="str3ds", input="A at test3d1")
+ self.runModule("g.mapset", mapset="test3d3")
+ tinfo_string="""id=A at test3d2
+ name=A
+ mapset=test3d2
+ info = SimpleModule("t.info", flags="g", type="str3ds", input="A at test3d2")
+ self.runModule("g.mapset", mapset="test3d2")
+ tinfo_string="""id=A at test3d3
+ name=A
+ mapset=test3d3
+ info = SimpleModule("t.info", flags="g", type="str3ds", input="A at test3d3")
+ tinfo_string="""id=A at test3d4
+ name=A
+ mapset=test3d4
+ info = SimpleModule("t.info", flags="g", type="str3ds", input="A at test3d4")
+ tinfo_string="""id=a1 at test3d1
+ name=a1
+ mapset=test3d1
+ creator=soeren
+ info = SimpleModule("t.info", flags="g", type="rast3d", input="a1 at test3d1")
+ tinfo_string="""id=a1 at test3d2
+ name=a1
+ mapset=test3d2
+ creator=soeren
+ info = SimpleModule("t.info", flags="g", type="rast3d", input="a1 at test3d2")
+ tinfo_string="""id=a1 at test3d3
+ name=a1
+ mapset=test3d3
+ creator=soeren
+ info = SimpleModule("t.info", flags="g", type="rast3d", input="a1 at test3d3")
+ tinfo_string="""id=a1 at test3d4
+ name=a1
+ mapset=test3d4
+ creator=soeren
+ info = SimpleModule("t.info", flags="g", type="rast3d", input="a1 at test3d4")
+ test()
Added: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py (rev 0)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2014-09-15 22:34:24 UTC (rev 61985)
@@ -0,0 +1,215 @@
+"""test distributed temporal databases with stvds
+for details.
+import subprocess
+import os
+mapset_count = 0
+ @classmethod
+ cls.runModule("g.mapset", flags="c", mapset="testvect%i"%i)
+ cls.runModule("v.random", output="a1", n=20)
+ cls.runModule("v.random", output="a2", n=20)
+ cls.runModule("v.random", output="a3", n=20)
+ cls.runModule("t.create", type="stvds", temporaltype="absolute",
+ output="A", title="A testvect", description="A testvect")
+ cls.runModule("t.register", flags="i", type="vect", input="A",
+ maps="a1,a2,a3",
+ self.runModule("g.mapset", mapset="testvect1")
+ list_string = """A|testvect1|2001-01-01 00:00:00|2001-04-01 00:00:00|3
+ A|testvect2|2001-01-01 00:00:00|2001-07-01 00:00:00|3
+ A|testvect3|2001-01-01 00:00:00|2001-10-01 00:00:00|3
+ A|testvect4|2001-01-01 00:00:00|2002-01-01 00:00:00|3"""
+ t_list = SimpleModule("t.list", quiet=True, columns=["name","mapset,start_time","end_time","number_of_maps"], type="stvds")
+ def test_tvect_list(self):
+ list_string = """a1|testvect1|2001-01-01 00:00:00|2001-02-01 00:00:00
+ a2|testvect1|2001-02-01 00:00:00|2001-03-01 00:00:00
+ a3|testvect1|2001-03-01 00:00:00|2001-04-01 00:00:00"""
+ trast_list = SimpleModule("t.vect.list", quiet=True, flags="s",
+ columns=["name","mapset","start_time","end_time"] ,
+ input="A at testvect1")
+ list_string = """a1|testvect2|2001-01-01 00:00:00|2001-03-01 00:00:00
+ a2|testvect2|2001-03-01 00:00:00|2001-05-01 00:00:00
+ a3|testvect2|2001-05-01 00:00:00|2001-07-01 00:00:00"""
+ input="A at testvect2")
+ list_string = """a1|testvect3|2001-01-01 00:00:00|2001-04-01 00:00:00
+ a2|testvect3|2001-04-01 00:00:00|2001-07-01 00:00:00
+ a3|testvect3|2001-07-01 00:00:00|2001-10-01 00:00:00"""
+ input="A at testvect3")
+ list_string = """a1|testvect4|2001-01-01 00:00:00|2001-05-01 00:00:00
+ a2|testvect4|2001-05-01 00:00:00|2001-09-01 00:00:00
+ a3|testvect4|2001-09-01 00:00:00|2002-01-01 00:00:00"""
+ input="A at testvect4")
+ def test_stvds_info(self):
+ self.runModule("g.mapset", mapset="testvect4")
+ tinfo_string="""id=A at testvect1
+ name=A
+ mapset=testvect1
+ info = SimpleModule("t.info", flags="g", type="stvds", input="A at testvect1")
+ self.runModule("g.mapset", mapset="testvect3")
+ tinfo_string="""id=A at testvect2
+ name=A
+ mapset=testvect2
+ info = SimpleModule("t.info", flags="g", type="stvds", input="A at testvect2")
+ self.runModule("g.mapset", mapset="testvect2")
+ tinfo_string="""id=A at testvect3
+ name=A
+ mapset=testvect3
+ info = SimpleModule("t.info", flags="g", type="stvds", input="A at testvect3")
+ tinfo_string="""id=A at testvect4
+ name=A
+ mapset=testvect4
+ info = SimpleModule("t.info", flags="g", type="stvds", input="A at testvect4")
+ def testv_vector_info(self):
+ tinfo_string="""id=a1 at testvect1
+ name=a1
+ mapset=testvect1
+ creator=soeren
+ info = SimpleModule("t.info", flags="g", type="vect", input="a1 at testvect1")
+ tinfo_string="""id=a1 at testvect2
+ name=a1
+ mapset=testvect2
+ creator=soeren
+ info = SimpleModule("t.info", flags="g", type="vect", input="a1 at testvect2")
+ tinfo_string="""id=a1 at testvect3
+ name=a1
+ mapset=testvect3
+ creator=soeren
+ info = SimpleModule("t.info", flags="g", type="vect", input="a1 at testvect3")
+ tinfo_string="""id=a1 at testvect4
+ name=a1
+ mapset=testvect4
+ creator=soeren
+ info = SimpleModule("t.info", flags="g", type="vect", input="a1 at testvect4")
+ test()
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2014-09-15 22:33:24 UTC (rev 61984)
+++ grass/trunk/temporal/t.info/t.info.py 2014-09-15 22:34:24 UTC (rev 61985)
@@ -2,15 +2,15 @@
# -*- coding: utf-8 -*-
-# MODULE: t.info
-# AUTHOR(S): Soeren Gebbert
+# MODULE: t.info
+# AUTHOR(S): Soeren Gebbert
-# PURPOSE: Print information about a space-time dataset
-# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# PURPOSE: Print information about a space-time dataset
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (version 2). Read the file COPYING that comes with GRASS
-# for details.
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
@@ -77,7 +77,7 @@
if system and not shellstyle:
# 0123456789012345678901234567890
print " +------------------- Temporal DBMI backend information ----------------------+"
- print " | DBMI Python interface:...... " + str(dbif.dbmi.__name__)
+ print " | DBMI Python interface:...... " + str(dbif.get_dbmi().__name__)
print " | Temporal database string:... " + str(
tgis.get_tgis_database_string())
print " | SQL template path:.......... " + str(
@@ -88,7 +88,7 @@
print " +----------------------------------------------------------------------------+"
return
elif system:
- print "dbmi_python_interface=\'" + str(dbif.dbmi.__name__) + "\'"
+ print "dbmi_python_interface=\'" + str(dbif.get_dbmi().__name__) + "\'"
print "dbmi_string=\'" + str(tgis.get_tgis_database_string()) + "\'"
print "sql_template_path=\'" + str(tgis.get_sql_template_path()) + "\'"
if rows:
@@ -106,10 +106,10 @@
dataset = tgis.dataset_factory(type_, id_)
- if dataset.is_in_db() == False:
+ if dataset.is_in_db(dbif) == False:
grass.fatal(_("Dataset <%s> not found in temporal database") % (id_))
- dataset.select()
+ dataset.select(dbif)
if history == True and type in ["strds", "stvds", "str3ds"]:
dataset.print_history()
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2014-09-15 22:33:24 UTC (rev 61984)
+++ grass/trunk/temporal/t.list/t.list.py 2014-09-15 22:34:24 UTC (rev 61985)
@@ -76,7 +76,7 @@
#% guisection: Formatting
#%end
-import grass.script as grass
+import grass.script as gscript
import grass.temporal as tgis
import sys
@@ -91,7 +91,7 @@
columns = options["columns"]
order = options["order"]
where = options["where"]
- separator = grass.separator(options["separator"])
+ separator = gscript.separator(options["separator"])
colhead = flags['c']
# Make sure the temporal database exists
@@ -100,7 +100,8 @@
sp = tgis.dataset_factory(type, None)
first = True
- sys.stderr.write("----------------------------------------------\n")
+ if gscript.verbosity() > 0:
+ sys.stderr.write("----------------------------------------------\n")
for ttype in temporal_type.split(","):
if ttype == "absolute":
@@ -120,12 +121,13 @@
rows = stds_list[key]
if rows:
- if issubclass(sp.__class__, tgis.AbstractMapDataset):
- sys.stderr.write(_("Time stamped %s maps with %s available in mapset <%s>:\n")%\
- (sp.get_type(), time, key))
- else:
- sys.stderr.write(_("Space time %s datasets with %s available in mapset <%s>:\n")%\
- (sp.get_new_map_instance(None).get_type(), time, key))
+ if issubclass(sp.__class__, tgis.AbstractMapDataset):
+ sys.stderr.write(_("Time stamped %s maps with %s available in mapset <%s>:\n")%\
+ (sp.get_type(), time, key))
+ else:
+ sys.stderr.write(_("Space time %s datasets with %s available in mapset <%s>:\n")%\
+ (sp.get_new_map_instance(None).get_type(), time, key))
# Print the column names if requested
if colhead == True and first == True:
@@ -153,5 +155,5 @@
print output
if __name__ == "__main__":
- options, flags = grass.parser()
+ options, flags = gscript.parser()
main()
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.py
--- grass/trunk/temporal/t.vect.list/t.vect.list.py 2014-09-15 22:33:24 UTC (rev 61984)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.py 2014-09-15 22:34:24 UTC (rev 61985)
@@ -44,7 +44,7 @@
#% required: no
#% multiple: yes
#% options: id,name,layer,creator,mapset,temporal_type,creation_time,start_time,end_time,north,south,west,east,points,lines,boundaries,centroids,faces,kernels,primitives,nodes,areas,islands,holes,volumes
-#% answer: id,name,layer,mapset,start_time,end_time
+#% answer: name,layer,mapset,start_time,end_time
#%end
#%option G_OPT_T_WHERE
