[GRASS-SVN] r61996 - grass/trunk/temporal/t.connect/testsuite
svn_grass at osgeo.org
Tue Sep 16 08:26:22 PDT 2014
Author: wenzeslaus
Date: 2014-09-16 08:26:22 -0700 (Tue, 16 Sep 2014)
New Revision: 61996
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
testing: do not use user or machine specific values in tests
(assertModuleKeyValue considers the reference input to by subset of the module actual output)
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2014-09-16 14:51:17 UTC (rev 61995)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2014-09-16 15:26:22 UTC (rev 61996)
@@ -162,7 +162,6 @@
tinfo_string="""id=a1 at test1
name=a1
mapset=test1
- creator=soeren
temporal_type=absolute
start_time=2001-01-01 00:00:00
end_time=2001-02-01 00:00:00 """
@@ -173,7 +172,6 @@
tinfo_string="""id=a1 at test2
name=a1
mapset=test2
- creator=soeren
end_time=2001-03-01 00:00:00 """
@@ -184,7 +182,6 @@
tinfo_string="""id=a1 at test3
name=a1
mapset=test3
- creator=soeren
end_time=2001-04-01 00:00:00 """
@@ -195,7 +192,6 @@
tinfo_string="""id=a1 at test4
name=a1
mapset=test4
- creator=soeren
end_time=2001-05-01 00:00:00 """
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2014-09-16 14:51:17 UTC (rev 61995)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2014-09-16 15:26:22 UTC (rev 61996)
@@ -159,7 +159,6 @@
tinfo_string="""id=a1 at test3d1
name=a1
mapset=test3d1
- creator=soeren
@@ -170,7 +169,6 @@
tinfo_string="""id=a1 at test3d2
name=a1
mapset=test3d2
- creator=soeren
@@ -181,7 +179,6 @@
tinfo_string="""id=a1 at test3d3
name=a1
mapset=test3d3
- creator=soeren
@@ -192,7 +189,6 @@
tinfo_string="""id=a1 at test3d4
name=a1
mapset=test3d4
- creator=soeren
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2014-09-16 14:51:17 UTC (rev 61995)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2014-09-16 15:26:22 UTC (rev 61996)
@@ -169,7 +169,6 @@
tinfo_string="""id=a1 at testvect1
name=a1
mapset=testvect1
- creator=soeren
@@ -180,7 +179,6 @@
tinfo_string="""id=a1 at testvect2
name=a1
mapset=testvect2
- creator=soeren
@@ -191,7 +189,6 @@
tinfo_string="""id=a1 at testvect3
name=a1
mapset=testvect3
- creator=soeren
@@ -202,7 +199,6 @@
tinfo_string="""id=a1 at testvect4
name=a1
mapset=testvect4
- creator=soeren
