[GRASS-SVN] r61999 - grass/trunk/lib/python/temporal/testsuite
Tue Sep 16 09:41:30 PDT 2014
Author: huhabla
Date: 2014-09-16 09:41:30 -0700 (Tue, 16 Sep 2014)
New Revision: 61999
   grass/trunk/lib/python/temporal/testsuite/test_register_function.py
temporal framework testsuite: Using g.mremove instead of g.remove in tests
Modified: grass/trunk/lib/python/temporal/testsuite/test_register_function.py
--- grass/trunk/lib/python/temporal/testsuite/test_register_function.py	2014-09-16 16:40:13 UTC (rev 61998)
+++ grass/trunk/lib/python/temporal/testsuite/test_register_function.py	2014-09-16 16:41:30 UTC (rev 61999)
@@ -52,7 +52,7 @@
         """!Remove maps from temporal database
         self.runModule("t.unregister", maps="register_map_1,register_map_2", quiet=True)
-        self.runModule("g.remove", rast="register_map_1,register_map_2", quiet=True)
+        self.runModule("g.mremove", type="rast",  pattern="register_map_1,register_map_2", quiet=True)
         self.strds_abs.delete()
         self.strds_rel.delete()
