[GRASS-SVN] r62004 - grass/trunk/lib/python/script
Tue Sep 16 14:19:20 PDT 2014
Author: wenzeslaus
Date: 2014-09-16 14:19:20 -0700 (Tue, 16 Sep 2014)
New Revision: 62004
   grass/trunk/lib/python/script/setup.py.sed
script/init: add extrabin to PATH, do not add extralib (extralib removed from WinGRASS installer somewhere around r57646)
Modified: grass/trunk/lib/python/script/setup.py.sed
--- grass/trunk/lib/python/script/setup.py.sed	2014-09-16 20:05:46 UTC (rev 62003)
+++ grass/trunk/lib/python/script/setup.py.sed	2014-09-16 21:19:20 UTC (rev 62004)
@@ -52,7 +52,7 @@
     os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin')
     os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'scripts')
     if sys.platform.startswith('win'):  # added for winGRASS
-        os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'extralib')
+        os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'extrabin')
     # define LD_LIBRARY_PATH
     if '@LD_LIBRARY_PATH_VAR@' not in os.environ:
