[GRASS-SVN] r62015 - in grass/trunk: gui/wxpython/animation gui/wxpython/core gui/wxpython/gmodeler gui/wxpython/gui_core gui/wxpython/iclass gui/wxpython/iscatt gui/wxpython/lmgr gui/wxpython/rlisetup gui/wxpython/vnet gui/wxpython/xml lib/gpde/test lib/manage lib/python/gunittest lib/python/gunittest/testsuite lib/python/pygrass lib/python/pygrass/modules lib/python/pygrass/modules/grid lib/python/pygrass/vector/testsuite lib/python/script lib/python/temporal lib/python/temporal/testsuite raster/r.category raster/r.li/r.li.setup raster/r.mapcalc/testsuite raster/r.out.mpeg raster/r.patch raster/r.reclass raster/r.series raster/r.series.accumulate raster/r.series.accumulate/test_suite raster/r.slope.aspect/testsuite raster/r.to.rast3elev raster/r.viewshed/testsuite raster/r.watershed/front raster/simwe/r.sim.water raster3d/r3.cross.rast raster3d/r3.flow/testsuite raster3d/r3.gradient/testsuite raster3d/r3.in.bin/test_suite raster3d/r3.out.netcdf/test_suite raster3d/r3.retile ra ster3d/r3.to.rast scripts/d.rast.edit scripts/d.shadedmap scripts/db.in.ogr scripts/i.in.spotvgt scripts/i.pansharpen scripts/i.spectral scripts/r.buffer.lowmem scripts/r.colors.stddev scripts/r.fillnulls scripts/r.grow scripts/r.in.wms scripts/r.mask scripts/r.reclass.area scripts/r.unpack/test_suite scripts/r3.in.xyz scripts/v.dissolve scripts/v.out.gps scripts/v.rast.stats scripts/v.to.lines scripts/v.unpack scripts/v.unpack/test_suite temporal/t.list temporal/t.merge/testsuite temporal/t.rast.accdetect temporal/t.rast.accumulate temporal/t.rast.gapfill temporal/t.rast.import temporal/t.rast.list temporal/t.rast.mapcalc temporal/t.rast.neighbors temporal/t.rast.out.vtk temporal/t.rast.series temporal/t.rast.to.rast3 temporal/t.rast.to.rast3/testsuite temporal/t.rast3d.list temporal/t.register temporal/t.remove temporal/t.rename temporal/t.support temporal/t.vect.db.select temporal/t.vect.extract temporal/t.vect.import/testsuite temporal/t.vect.list temporal/t.vect.list/te stsuite temporal/t.vect.observe.strds/testsuite temporal/t.vect.univar/testsuite temporal/t.vect.what.strds testsuite/raster tools vector/v.distance vector/v.lrs/v.lrs.create
Wed Sep 17 09:24:35 PDT 2014
Author: hcho
Date: 2014-09-17 09:24:34 -0700 (Wed, 17 Sep 2014)
New Revision: 62015
   grass/trunk/gui/wxpython/animation/g.gui.animation.html
   grass/trunk/gui/wxpython/core/globalvar.py
   grass/trunk/gui/wxpython/gmodeler/frame.py
   grass/trunk/gui/wxpython/gmodeler/model.py
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/gselect.py
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/iscatt/iscatt_core.py
   grass/trunk/gui/wxpython/lmgr/datacatalog.py
   grass/trunk/gui/wxpython/rlisetup/functions.py
   grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
   grass/trunk/gui/wxpython/vnet/vnet_core.py
   grass/trunk/gui/wxpython/vnet/vnet_data.py
   grass/trunk/gui/wxpython/xml/toolboxes.xml
   grass/trunk/lib/gpde/test/test_arrays.c
   grass/trunk/lib/manage/managelib.dox
   grass/trunk/lib/python/gunittest/case.py
   grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py
   grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py
   grass/trunk/lib/python/pygrass/functions.py
   grass/trunk/lib/python/pygrass/modules/grid/grid.py
   grass/trunk/lib/python/pygrass/modules/shortcuts.py
   grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py
   grass/trunk/lib/python/script/core.py
   grass/trunk/lib/python/script/db.py
   grass/trunk/lib/python/script/pythonlib.dox
   grass/trunk/lib/python/script/raster.py
   grass/trunk/lib/python/script/raster3d.py
   grass/trunk/lib/python/temporal/aggregation.py
   grass/trunk/lib/python/temporal/extract.py
   grass/trunk/lib/python/temporal/mapcalc.py
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/lib/python/temporal/space_time_datasets.py
   grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
   grass/trunk/lib/python/temporal/temporal_raster_algebra.py
   grass/trunk/lib/python/temporal/temporal_vector_algebra.py
   grass/trunk/lib/python/temporal/testsuite/test_register_function.py
   grass/trunk/raster/r.category/test_rcategory_doctest.txt
   grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh
   grass/trunk/raster/r.li/r.li.setup/r.li.setup
   grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh
   grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh
   grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh
   grass/trunk/raster/r.mapcalc/testsuite/test_r_mapcalc.py
   grass/trunk/raster/r.out.mpeg/main.c
   grass/trunk/raster/r.patch/r.patch.html
   grass/trunk/raster/r.reclass/r.reclass.html
   grass/trunk/raster/r.series.accumulate/r.series.accumulate.html
   grass/trunk/raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh
   grass/trunk/raster/r.series/r.series.html
   grass/trunk/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py
   grass/trunk/raster/r.to.rast3elev/test.r.to.rast3elev.sh
   grass/trunk/raster/r.viewshed/testsuite/test_r_viewshed.py
   grass/trunk/raster/r.watershed/front/r.watershed.html
   grass/trunk/raster/simwe/r.sim.water/spearfish.sh
   grass/trunk/raster3d/r3.cross.rast/test.r3.cross.rast.sh
   grass/trunk/raster3d/r3.flow/testsuite/r3flow_test.py
   grass/trunk/raster3d/r3.gradient/testsuite/r3gradient_test.py
   grass/trunk/raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh
   grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
   grass/trunk/raster3d/r3.retile/test.r3.retile.sh
   grass/trunk/raster3d/r3.to.rast/test.r3.to.rast.sh
   grass/trunk/scripts/d.rast.edit/d.rast.edit.py
   grass/trunk/scripts/d.shadedmap/d.shadedmap.py
   grass/trunk/scripts/db.in.ogr/db.in.ogr.py
   grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
   grass/trunk/scripts/i.pansharpen/i.pansharpen.py
   grass/trunk/scripts/i.spectral/i.spectral.html
   grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py
   grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
   grass/trunk/scripts/r.grow/r.grow.py
   grass/trunk/scripts/r.in.wms/wms_base.py
   grass/trunk/scripts/r.mask/r.mask.py
   grass/trunk/scripts/r.reclass.area/r.reclass.area.py
   grass/trunk/scripts/r.unpack/test_suite/test.r.unpack.sh
   grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
   grass/trunk/scripts/v.dissolve/v.dissolve.html
   grass/trunk/scripts/v.dissolve/v.dissolve.py
   grass/trunk/scripts/v.out.gps/v.out.gps.py
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
   grass/trunk/scripts/v.to.lines/v.to.lines.py
   grass/trunk/scripts/v.unpack/test_suite/test.v.unpack.sh
   grass/trunk/scripts/v.unpack/v.unpack.py
   grass/trunk/temporal/t.list/t.list.html
   grass/trunk/temporal/t.merge/testsuite/test.t.merge.sh
   grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
   grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
   grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
   grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh
   grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
   grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh
   grass/trunk/temporal/t.rast.list/t.rast.list.html
   grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
   grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
   grass/trunk/temporal/t.rast.series/test.t.rast.series.sh
   grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
   grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
   grass/trunk/temporal/t.rast3d.list/t.rast3d.list.html
   grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh
   grass/trunk/temporal/t.register/test.t.register.vector.sh
   grass/trunk/temporal/t.remove/t.remove.html
   grass/trunk/temporal/t.remove/t.remove.py
   grass/trunk/temporal/t.rename/test.t.rename.sh
   grass/trunk/temporal/t.support/test.t.support.sh
   grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
   grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh
   grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
   grass/trunk/temporal/t.vect.import/testsuite/test.t.vect.import.sh
   grass/trunk/temporal/t.vect.list/t.vect.list.html
   grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh
   grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh
   grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh
   grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh
   grass/trunk/temporal/t.vect.univar/testsuite/test.t.vect.univar.sh
   grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
   grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
   grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
   grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh
   grass/trunk/testsuite/raster/raster_md5test.sh
   grass/trunk/testsuite/raster/rhemisphere.sh
   grass/trunk/tools/thumbnails.py
   grass/trunk/vector/v.distance/v.distance.html
   grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html
Rename g.mlist to g.list and update g.remove usage
Modified: grass/trunk/gui/wxpython/animation/g.gui.animation.html
--- grass/trunk/gui/wxpython/animation/g.gui.animation.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/animation/g.gui.animation.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -63,15 +63,15 @@
 </pre></div>
 The loading of a series of maps into the Animation Tool can be simplified
-with <em><a href="g.mlist.html">g.mlist<a></em> (back ticks syntax works for Linux and Mac only):
+with <em><a href="g.list.html">g.list<a></em> (back ticks syntax works for Linux and Mac only):
 <div class="code"><pre>
-g.gui.animation rast=`g.mlist type=rast mapset=. separator=comma pattern="precip*"`
+g.gui.animation rast=`g.list type=rast mapset=. separator=comma pattern="precip*"`
 </pre></div>
 Using extended regular expressions, the list of a series of raster maps can be subset by
 e.g., numeric range (here: precipitation for the years 1997-2012):
-g.gui.animation rast=`g.mlist -e type=rast mapset=. separator=comma pattern="precip_total.(199[7-9]|200[0-9]|201[0-2]).sum"`
+g.gui.animation rast=`g.list -e type=rast mapset=. separator=comma pattern="precip_total.(199[7-9]|200[0-9]|201[0-2]).sum"`
 </pre></div>
@@ -85,7 +85,7 @@
 <p>
 <em>
   <a href="g.gui.timeline.html">g.gui.timeline</a>,
-  <a href="g.mlist.html">g.mlist</a>
+  <a href="g.list.html">g.list</a>
 </em>
 <p>
Modified: grass/trunk/gui/wxpython/core/globalvar.py
--- grass/trunk/gui/wxpython/core/globalvar.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/core/globalvar.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -201,11 +201,11 @@
 """@Toolbar icon size"""
 toolbarSize = (24, 24)
-"""@Is g.mlist available?"""
-if 'g.mlist' in grassCmd:
-    have_mlist = True
+"""@Is g.list available?"""
+if 'g.list' in grassCmd:
+    have_list = True
 else:
-    have_mlist = False
+    have_list = False
 """@Check version of wxPython, use agwStyle for 2.8.11+"""
 hasAgw = CheckWxVersion()
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -326,11 +326,14 @@
             dlg.Destroy()
             if rast:
-                self._gconsole.RunCmd(['g.remove', 'rast=%s' %','.join(rast)])
+                self._gconsole.RunCmd(['g.remove', '-f', 'type=rast',
+                                       'pattern=%s' %','.join(rast)])
             if rast3d:
-                self._gconsole.RunCmd(['g.remove', 'rast3d=%s' %','.join(rast3d)])
+                self._gconsole.RunCmd(['g.remove', '-f', 'type=rast3d',
+                                       'pattern=%s' %','.join(rast3d)])
             if vect:
-                self._gconsole.RunCmd(['g.remove', 'vect=%s' %','.join(vect)])
+                self._gconsole.RunCmd(['g.remove', '-f', 'type=vect',
+                                       'pattern=%s' %','.join(vect)])
             self.SetStatusText(_("%d maps deleted from current mapset") % \
                                  int(len(rast) + len(rast3d) + len(vect)))
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/gmodeler/model.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -709,11 +709,11 @@
         rast, vect, rast3d, msg = self.GetIntermediateData()
         if rast:
-            log.RunCmd(['g.remove', 'rast=%s' %','.join(rast)])
+            log.RunCmd(['g.remove', '-f', 'type=rast', 'pattern=%s' %','.join(rast)])
         if rast3d:
-            log.RunCmd(['g.remove', 'rast3d=%s' %','.join(rast3d)])
+            log.RunCmd(['g.remove', '-f', 'type=rast3d', 'pattern=%s' %','.join(rast3d)])
         if vect:
-            log.RunCmd(['g.remove', 'vect=%s' %','.join(vect)])
+            log.RunCmd(['g.remove', '-f', 'type=vect', 'pattern=%s' %','.join(vect)])
     def GetIntermediateData(self):
         """Get info about intermediate data"""
@@ -2338,18 +2338,18 @@
         if rast:
             self.fd.write(
-r"""  run_command('g.remove',
-                      rast=%s)
+r"""  run_command('g.remove', flags='f', type='rast',
+                      pattern=%s)
 """% ','.join(map(lambda x: "'" + x + "'", rast)))
         if vect:
             self.fd.write(
-                      vect = %s)
+r"""  run_command('g.remove', flags='f', type='vect',
+                      pattern=%s)
 """% ','.join(map(lambda x: "'" + x + "'", vect)))
         if rast3d:
             self.fd.write(
-                      rast3d = %s)
+r"""  run_command('g.remove', flags='f', type='rast3d',
+                      pattern=%s)
 """% ','.join(map(lambda x: "'" + x + "'", rast3d)))
         if not rast and not vect and not rast3d:
             self.fd.write('    pass\n')
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -1513,7 +1513,7 @@
     def GetLayerType(self, cmd = False):
         """Get selected layer type
-        :param bool cmd: True for g.mlist
+        :param bool cmd: True for g.list
         if not cmd:
             return self.layerType.GetStringSelection()
@@ -1575,7 +1575,7 @@
     def _modelerDSeries(self):
         self.dseries = wx.CheckBox(parent = self, id = wx.ID_ANY,
-                                   label = _("Dynamic series (%s)") % 'g.mlist')
+                                   label = _("Dynamic series (%s)") % 'g.list')
         self.dseries.SetValue(False)
         self.mainSizer.Add(item = self.dseries, proportion = 0,
                            flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
@@ -1583,12 +1583,12 @@
     def GetDSeries(self):
         """Used by modeler only
-        :return: g.mlist command
+        :return: g.list command
         if not self.dseries or not self.dseries.IsChecked():
             return ''
-        cond = 'map in `g.mlist type=%s ' % self.GetLayerType(cmd = True)
+        cond = 'map in `g.list type=%s ' % self.GetLayerType(cmd = True)
         patt = self.filter.GetValue()
         if patt:
             cond += 'pattern=%s ' % patt
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -407,7 +407,7 @@
         # get current mapset
         curr_mapset = grass.gisenv()['MAPSET']
-        # map element types to g.mlist types
+        # map element types to g.list types
         elementdict = {'cell':'rast',
                        'raster':'rast',
                        'rast':'rast',
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -254,7 +254,9 @@
         """Removes temporary vector map with training areas"""
         ret = RunCommand(prog = 'g.remove',
                          parent = self,
-                         vect = self.trainingAreaVector)
+                         flags = 'f',
+                         type = 'vect',
+                         pattern = self.trainingAreaVector)
         if ret != 0:
             return False
         return True
@@ -265,7 +267,9 @@
         self.GetSecondMap().Clean()
                          parent = self,
-                         rast = raster)
+                         flags = 'f',
+                         type = 'rast',
+                         pattern = raster)
         if ret != 0:
             return False
         return True
Modified: grass/trunk/gui/wxpython/iscatt/iscatt_core.py
--- grass/trunk/gui/wxpython/iscatt/iscatt_core.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/iscatt/iscatt_core.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -284,8 +284,7 @@
             ret = UpdateCatRast(patch_rast, region, self.scatts_dt.GetCatRastCond(cat))
             if ret < 0:
                 GException(_("Patching category raster conditions file failed."))
-            RunCommand("g.remove",
-                      rast = patch_rast)
+            RunCommand("g.remove", flags='f', type='rast', pattern=patch_rast)
     def _rasterize(self, grass_region, layer, cat, out_rast):
@@ -598,8 +597,8 @@
         grass.try_remove(self.cats_rasts_conds[cat_id])
         del self.cats_rasts_conds[cat_id]
-                   rast=self.cats_rasts[cat_id])
+                   pattern=self.cats_rasts[cat_id])
         del self.cats_rasts[cat_id]
         return True
@@ -709,8 +708,8 @@
         for tmp in self.cats_rasts_conds.itervalues():
             grass.try_remove(tmp)
         for tmp in self.cats_rasts.itervalues():
-                       rast=tmp,
+                       type='rast', pattern=tmp,
                        getErrorMsg=True)
         self.cats_rasts = {}
Modified: grass/trunk/gui/wxpython/lmgr/datacatalog.py
--- grass/trunk/gui/wxpython/lmgr/datacatalog.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/lmgr/datacatalog.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -116,7 +116,7 @@
                 self.ChangeEnvironment(location)
             varloc = self.AppendItem(self.root, loc)
             #get list of all maps in location
-            maplist = RunCommand('g.mlist', flags='mt', type='rast,rast3d,vect', mapset=','.join(mapsets),
+            maplist = RunCommand('g.list', flags='mt', type='rast,rast3d,vect', mapset=','.join(mapsets),
                                  quiet=True, read=True)
             maplist = maplist.splitlines()
             for ml in maplist:
@@ -414,15 +414,18 @@
                 label = _("Deleting") + " " + string + " ..."
                 self.showNotification.emit(message=label)
                 if (self.GetItemText(self.selected_type)=='vect'):
-                    removed = RunCommand('g.remove', vect=string)
+                    removed = RunCommand('g.remove', flags='f', type='vect',
+                                         pattern=string)
                 elif (self.GetItemText(self.selected_type)=='rast'):
-                    removed = RunCommand('g.remove', rast=string)
+                    removed = RunCommand('g.remove', flags='f', type='rast',
+                                         pattern=string)
                 else:
-                    removed = RunCommand('g.remove', rast3d=string)
+                    removed = RunCommand('g.remove', flags='f', type='rast3d',
+                                         pattern=string)
                 if (removed==0):
                     self.Delete(self.selected_layer)
                     Debug.msg(1,"LAYER "+string+" DELETED")
-                    label = "g.remove "+self.GetItemText(self.selected_type)+"="+string+"    -- completed" # generate this message (command) automatically?
+                    label = "g.remove -f type="+self.GetItemText(self.selected_type)+" pattern="+string+"    -- completed" # generate this message (command) automatically?
             self.RestoreBackup()
Modified: grass/trunk/gui/wxpython/rlisetup/functions.py
--- grass/trunk/gui/wxpython/rlisetup/functions.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/rlisetup/functions.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -85,7 +85,8 @@
     grass.run_command('g.region', vect=tmp_vect, align=origrast)
     grass.run_command('v.to.rast', input=vect, output=outrast, use='cat',
                       cats=cat, overwrite=True, quiet=True)
-    grass.run_command('g.remove', vect=tmp_vect, quiet=True)
+    grass.run_command('g.remove', flags='f', type='vect',
+                      pattern=tmp_vect, quiet=True)
 def obtainAreaVector(outrast):
Modified: grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
--- grass/trunk/gui/wxpython/rlisetup/sampling_frame.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/rlisetup/sampling_frame.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -263,8 +263,8 @@
         marea = MaskedArea(region, rasterName)
-        RunCommand('g.remove', rast=tmpraster)
-        RunCommand('g.remove', vect=tmpvector)
+        RunCommand('g.remove', flags='f', type='rast', pattern=tmpraster)
+        RunCommand('g.remove', flags='f', type='vect', pattern=tmpvector)
         os.unlink(polyfile.name)
         return marea
Modified: grass/trunk/gui/wxpython/vnet/vnet_core.py
--- grass/trunk/gui/wxpython/vnet/vnet_core.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/vnet/vnet_core.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -121,8 +121,8 @@
         # for case there is some map with same name
         # (when analysis does not produce any map, this map would have been shown as result)
-                    vect = self.results["vect_map"].GetVectMapName())
+        RunCommand('g.remove', flags = 'f', type = 'vect',
+                    pattern = self.results["vect_map"].GetVectMapName())
         # save data from
         self.history._saveAnInputToHist(analysis, params, flags)
Modified: grass/trunk/gui/wxpython/vnet/vnet_data.py
--- grass/trunk/gui/wxpython/vnet/vnet_data.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/vnet/vnet_data.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -938,8 +938,8 @@
         if vectMap:
             vectMap.DeleteRenderLayer()
-                        vect = vectMap.GetVectMapName())
+                        pattern = vectMap.GetVectMapName())
             self.RemoveFromTmpMaps(vectMap)
             return True
         return False
@@ -948,8 +948,8 @@
         """Delete all temporary maps in the class"""
         update = False
         for tmpMap in self.tmpMaps:
-                        vect = tmpMap.GetVectMapName())
+                        pattern = tmpMap.GetVectMapName())
             if tmpMap.DeleteRenderLayer():
                 update = True
         return update
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml	2014-09-17 16:24:34 UTC (rev 62015)
@@ -518,9 +518,6 @@
       <module-item name="g.list">
         <label>List</label>
       </module-item>
-      <module-item name="g.mlist">
-        <label>List filtered</label>
-      </module-item>
       <separator/>
       <module-item name="g.rename">
         <label>Rename</label>
@@ -529,9 +526,6 @@
       <module-item name="g.remove">
         <label>Delete</label>
       </module-item>
-      <module-item name="g.mremove">
-        <label>Delete filtered</label>
-      </module-item>
     </items>
   </toolbox>
   <toolbox name="MapTypeConversions">
Modified: grass/trunk/lib/gpde/test/test_arrays.c
--- grass/trunk/lib/gpde/test/test_arrays.c	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/gpde/test/test_arrays.c	2014-09-17 16:24:34 UTC (rev 62015)
@@ -294,7 +294,7 @@
     sprintf(buff,
-	    "g.remove rast=gpde_lib_test_raster_1,gpde_lib_test_raster_2,gpde_lib_test_raster_3");
+	    "g.remove -f type=rast pattern=gpde_lib_test_raster_1,gpde_lib_test_raster_2,gpde_lib_test_raster_3");
     system(buff);
     N_free_array_2d(data1);
@@ -588,7 +588,7 @@
     sprintf(buff,
     system(buff);
@@ -857,7 +857,7 @@
     N_free_array_3d(tmp);
     sprintf(buff,
-	    "g.remove rast3d=gpde_lib_test_volume_1,gpde_lib_test_volume_2");
+	    "g.remove -f type=rast3d pattern=gpde_lib_test_volume_1,gpde_lib_test_volume_2");
     system(buff);
     N_free_array_3d(data1);
Modified: grass/trunk/lib/manage/managelib.dox
--- grass/trunk/lib/manage/managelib.dox	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/manage/managelib.dox	2014-09-17 16:24:34 UTC (rev 62015)
@@ -5,8 +5,7 @@
 \section manageintro Introduction
 This library used for management of data base elements. See modules
-<tt>g.list, g.mlist, g.remove, g.mremove, g.copy</tt> or
-<tt>g.rename</tt>.
+<tt>g.list, g.remove, g.copy</tt> or <tt>g.rename</tt>.
 \code
 #include <grass/manage.h>
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/gunittest/case.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -125,7 +125,7 @@
                                "does not corresond to currently set"
                                " WIND_OVERRIDE ({c})",
                                n=cls._temp_region, c=name)
-        call_module("g.remove", quiet=True, region=name)
+        call_module("g.remove", quiet=True, flags='f', type='region', pattern=name)
         # TODO: we don't know if user calls this
         # so perhaps some decorator which would use with statemet
         # but we have zero chance of infuencing another test class
@@ -628,7 +628,7 @@
                                           sep='=', precision=precision,
                                           reference=statistics, msg=msg)
             finally:
-                call_module('g.remove', rast=diff)
+                call_module('g.remove', flags='f', type='rast', pattern=diff)
         else:
             # general case
             # TODO: we are using r.info min max and r.univar min max interchangably
@@ -654,7 +654,7 @@
             self.assertRasterFitsUnivar(raster=diff, reference=statistics,
                                         precision=precision, msg=msg)
         finally:
     def assertRasters3dNoDifference(self, actual, reference,
                                     precision, statistics=None, msg=None):
@@ -675,7 +675,7 @@
             finally:
-                call_module('g.remove', rast3d=diff)
+                call_module('g.remove', flags='f', type='rast3d', pattern=diff)
         else:
             # general case
@@ -701,7 +701,7 @@
             self.assertRaster3dFitsUnivar(raster=diff, reference=statistics,
         finally:
     # TODO: this works only in 2D
     # TODO: write tests
@@ -744,7 +744,7 @@
                                             reference=ref_info,
                                             msg=msg, precision=precision)
         finally:
-            call_module('g.remove', vect=remove)
+            call_module('g.remove', flags='f', type='vect', pattern=remove)
     # TODO: write tests
     def assertVectorsNoAreaDifference(self, actual, reference, precision,
@@ -777,7 +777,7 @@
                     va=actual, vr=reference, p=precision, a=total_area)
                 self.fail(self._formatMessage(msg, stdmsg))
         finally:
-            call_module('g.remove', vect=diff)
+            call_module('g.remove', flags='f', type='vect', pattern=diff)
     # TODO: here we have to have significant digits which is not consistent
     # TODO: documentation for all new asserts
@@ -841,7 +841,7 @@
             # we rely on fail method to either raise or return (soon)
             os.remove(factual)
             if vreference:
-                self.runModule('g.remove', vect=vreference)
+                self.runModule('g.remove', flags='f', type='vect', pattern=vreference)
     # TODO: we expect v.out.ascii to give the same order all the time, is that OK?
     def assertVectorAsciiEqualsVectorAscii(self, actual, reference,
Modified: grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions_rast3d.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -29,8 +29,8 @@
     def tearDownClass(cls):
         cls.del_temp_region()
         # TODO: input as list does not work, why?
-        cls.runModule('g.remove',
-                      rast3d=','.join([cls.constant_map, cls.rcd_increasing_map]))
+        cls.runModule('g.remove', flags='f', type='rast3d',
+                      pattern=','.join([cls.constant_map, cls.rcd_increasing_map]))
     def test_assertRaster3dFitsUnivar(self):
         reference = dict(n=1000000,
Modified: grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py
--- grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/gunittest/testsuite/test_assertions_vect.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -138,7 +138,8 @@
         # when invoking separately, no need to delete maps since mapset
         # is deleted
         if cls.maps_to_remove:
-            cls.runModule('g.remove', vect=','.join(cls.maps_to_remove))
+            cls.runModule('g.remove', flags='f', type='vect',
+                          pattern=','.join(cls.maps_to_remove))
     def test_assertVectorEqualsVector_basic(self):
         """Check completely different maps."""
Modified: grass/trunk/lib/python/pygrass/functions.py
--- grass/trunk/lib/python/pygrass/functions.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/pygrass/functions.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -94,10 +94,10 @@
         return find_in_gisdbase(type, pattern, gis)
-def remove(oldname, maptype, **kwargs):
+def remove(oldname, maptype):
     """Remove a map"""
-    kwargs.update({maptype: '{old}'.format(old=oldname)})
-    grasscore.run_command('g.remove', quiet=True, **kwargs)
+    grasscore.run_command('g.remove', quiet=True, flags='f',
+                          type=maptype, pattern=oldname)
 def rename(oldname, newname, maptype, **kwargs):
Modified: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -255,7 +255,7 @@
         mpclc(expression="%s=%s" % (name, rast), overwrite=True, env_=env)
         file_dst = "%s.pack" % os.path.join(path_dst, name)
         rpck(input=name, output=file_dst, overwrite=True, env_=env)
-        remove(rast=name, env_=env)
+        remove(flags='f', type='rast', pattern=name, env_=env)
         # change gisdbase to dst
         env['GISRC'] = gisrc_dst
         rupck(input=file_dst, output=rast_clean, overwrite=True, env_=env)
@@ -289,7 +289,7 @@
         name = nam % vect
         vpck(input=name, output=file_dst, overwrite=True, env_=env)
-        remove(vect=name, env_=env)
+        remove(flags='f', type='vect', pattern=name, env_=env)
         vupck(input=file_dst, output=vect, overwrite=True, env_=env)
@@ -603,4 +603,4 @@
         if self.inlist:
             grm = Module('g.remove')
             for key in self.inlist:
-                grm(rast=self.inlist[key])
+                grm(flags='f', type='rast', pattern=self.inlist[key])
Modified: grass/trunk/lib/python/pygrass/modules/shortcuts.py
--- grass/trunk/lib/python/pygrass/modules/shortcuts.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/pygrass/modules/shortcuts.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -20,16 +20,16 @@
     """Example how to use MetaModule
        >>> g = MetaModule('g')
-       >>> g_mlist = g.mlist
-       >>> g_mlist.name
-       'g.mlist'
-       >>> g_mlist.required
+       >>> g_list = g.list
+       >>> g_list.name
+       'g.list'
+       >>> g_list.required
        ['type']
-       >>> g_mlist.inputs.type = 'rast'
-       >>> g_mlist.stdout_ = -1
-       >>> g_mlist.run()
-       Module('g.mlist')
-       >>> g_mlist.outputs.stdout                         # doctest: +ELLIPSIS
+       >>> g_list.inputs.type = 'rast'
+       >>> g_list.stdout_ = -1
+       >>> g_list.run()
+       Module('g.list')
+       >>> g_list.outputs.stdout                         # doctest: +ELLIPSIS
        '...basins...soils...'
        >>> r = MetaModule('r')
        >>> what = r.what
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -61,7 +61,7 @@
         """Remove the generated vector map, if exist"""
         mset = get_mapset_vector(cls.tmpname, mapset='')
         if mset:
-            run_command("g.remove", vect="%s@%s" % (cls.tmpname, mset))
+            run_command("g.remove", flags='f', type='vect', pattern=cls.tmpname)
 if __name__ == '__main__':
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/script/core.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -1006,7 +1006,7 @@
     """Unsets WIND_OVERRIDE and removes any region named by it."""
     try:
         name = os.environ.pop('WIND_OVERRIDE')
-        run_command("g.remove", quiet=True, region=name)
+        run_command("g.remove", flags='f', quiet=True, type='region', pattern=name)
     except:
         pass
@@ -1040,97 +1040,10 @@
 # interface to g.list
-def list_grouped(type, check_search_path=True):
-    """List elements grouped by mapsets.
-    Returns the output from running g.list, as a dictionary where the
-    keys are mapset names and the values are lists of maps in that
-    mapset. Example:
-    >>> list_grouped('rast')['PERMANENT'] # doctest: +ELLIPSIS
-    ['basins' ... 'landuse']
-    :param str type: element type (rast, vect, rast3d, region, ...)
-    :param bool check_search_path: True to add mapsets for the search path
-                                   with no found elements
-    :return: directory of mapsets/elements
-    if type == 'raster' or type == 'cell':
-        verbose(_('Element type should be "rast" and not "%s"') % type)
-        type = 'rast'
-    dashes_re = re.compile("^----+$")
-    mapset_re = re.compile("<(.*)>")
-    result = {}
-    if check_search_path:
-        for mapset in mapsets(search_path=True):
-            result[mapset] = []
-    mapset = None
-    for line in read_command("g.list", type=type).splitlines():
-        if line == "":
-            continue
-        if dashes_re.match(line):
-            continue
-        m = mapset_re.search(line)
-        if m:
-            mapset = m.group(1)
-            if mapset not in result.keys():
-            continue
-        if mapset:
-            result[mapset].extend(line.split())
-    return result
-def _concat(xs):
-    result = []
-    for x in xs:
-        result.extend(x)
-    return result
-def list_pairs(type):
-    """List of elements as tuples.
-    Returns the output from running g.list, as a list of (map, mapset)
-    pairs. Example:
-    >>> list_pairs('rast') # doctest: +ELLIPSIS
-    [('basins', 'PERMANENT'),  ... ('landuse', 'PERMANENT')]
-    :return: list of tuples (map, mapset)
-    return _concat([[(map, mapset) for map in maps]
-                    for mapset, maps in list_grouped(type).iteritems()])
-def list_strings(type):
+def list_strings(type, pattern=None, mapset=None, exclude=None, flag=''):
     """List of elements as strings.
     Returns the output from running g.list, as a list of qualified
-    names. Example:
-    >>> list_strings('rast')  # doctest: +ELLIPSIS
-    [..., 'lakes at PERMANENT', ..., 'slope at PERMANENT', ...
-    :return: list of strings ('map@@mapset')
-    return ["%s@%s" % pair for pair in list_pairs(type)]
-# interface to g.mlist
-def mlist_strings(type, pattern=None, mapset=None, exclude=None, flag=''):
-    """List of elements as strings.
-    Returns the output from running g.mlist, as a list of qualified
     names.
@@ -1146,7 +1059,7 @@
         type = 'rast'
     result = list()
-    for line in read_command("g.mlist",
+    for line in read_command("g.list",
                              quiet=True,
                              flags='m' + flag,
                              type=type,
@@ -1158,10 +1071,10 @@
     return result
-def mlist_pairs(type, pattern=None, mapset=None, exclude=None, flag=''):
+def list_pairs(type, pattern=None, mapset=None, exclude=None, flag=''):
     """List of elements as pairs
+    Returns the output from running g.list, as a list of
     (name, mapset) pairs
@@ -1173,20 +1086,20 @@
     :return: list of elements
-    return [tuple(map.split('@', 1)) for map in mlist_strings(type, pattern,
+    return [tuple(map.split('@', 1)) for map in list_strings(type, pattern,
                                                               mapset, exclude,
                                                               flag)]
-def mlist_grouped(type, pattern=None, check_search_path=True, exclude=None,
+def list_grouped(type, pattern=None, check_search_path=True, exclude=None,
                   flag=''):
     """List of elements grouped by mapsets.
-    Returns the output from running g.mlist, as a dictionary where the
+    Returns the output from running g.list, as a dictionary where the
     mapset. Example:
-    >>> mlist_grouped('vect', pattern='*roads*')['PERMANENT']
+    >>> list_grouped('vect', pattern='*roads*')['PERMANENT']
     ['railroads', 'roadsmajor']
@@ -1208,7 +1121,7 @@
             result[mapset] = []
     mapset = None
-    for line in read_command("g.mlist", quiet=True, flags="m" + flag,
+    for line in read_command("g.list", quiet=True, flags="m" + flag,
                              type=type, pattern=pattern, exclude=exclude).splitlines():
         try:
             name, mapset = line.split('@')
Modified: grass/trunk/lib/python/script/db.py
--- grass/trunk/lib/python/script/db.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/script/db.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -31,7 +31,7 @@
     0
     >>> db_describe('myfirestations') # doctest: +ELLIPSIS
     {'nrows': 71, 'cols': [['cat', 'INTEGER', '20'], ... 'ncols': 22}
-    >>> run_command('g.remove', vect='myfirestations')
+    >>> run_command('g.remove', flags='f', type='vect', pattern='myfirestations')
     0
     :param str table: table name
@@ -71,7 +71,7 @@
     0
     >>> db_table_exist('myfirestations')
     True
     0
@@ -118,7 +118,7 @@
     >>> db_select(table = 'myfirestations') # doctest: +ELLIPSIS
     (('1', '24', 'Morrisville #3', ... 'HS2A', '1.37'))
     0
     :param str sql: SQL statement to perform (or None)
@@ -164,7 +164,7 @@
     >>> db_table_in_vector('myfirestations')
     ['myfirestations at user1']
     >>> db_table_in_vector('mfirestations')
     0
     :param str table: name of table to query
Modified: grass/trunk/lib/python/script/pythonlib.dox
--- grass/trunk/lib/python/script/pythonlib.dox	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/script/pythonlib.dox	2014-09-17 16:24:34 UTC (rev 62015)
@@ -157,8 +157,6 @@
  - python::script::core::list_strings()
- - python::script::core::mlist_grouped()
 <b>Interface to \gmod{g.mapsets}</b>
  - python::script::core::mapsets()
Modified: grass/trunk/lib/python/script/raster.py
--- grass/trunk/lib/python/script/raster.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/script/raster.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -119,7 +119,7 @@
     0
     >>> p2.wait()
     1
-    >>> run_command('g.remove', rast=output)
+    >>> run_command('g.remove', flags='f', type='rast', pattern=output)
     :param str exp: expression
     :param bool quiet: True to run quietly (<tt>--q</tt>)
Modified: grass/trunk/lib/python/script/raster3d.py
--- grass/trunk/lib/python/script/raster3d.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/script/raster3d.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -32,7 +32,7 @@
     >>> mapcalc3d('volume = row() + col() + depth()')
     >>> raster3d_info('volume') # doctest: +ELLIPSIS
     {'vertical_units': '"units"', 'tbres': 1.0, ... 'south': 185000.0}
-    >>> run_command('g.remove', rast3d='volume')
+    >>> run_command('g.remove', flags='f', type='rast3d', pattern='volume')
     0
     :param str map: map name
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/aggregation.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -174,7 +174,7 @@
     # In case of a null map continue, do not register null maps
     if new_map.metadata.get_min() is None and new_map.metadata.get_max() is None:
         if not register_null:
-            gscript.run_command("g.remove", rast=output)
+            gscript.run_command("g.remove", flags='f', type='rast', pattern=output)
             return None
     return new_map
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/extract.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -237,11 +237,14 @@
                     names += ",%s" % (map.get_name())
                 count += 1
             if type == "raster":
-                gscript.run_command("g.remove", rast=names, quiet=True)
+                                    pattern=names, quiet=True)
             elif type == "raster3d":
-                gscript.run_command("g.remove", rast3d=names, quiet=True)
+                gscript.run_command("g.remove", flags='f', type='rast3d',
             elif type == "vector":
-                gscript.run_command("g.remove", vect=names, quiet=True)
+                gscript.run_command("g.remove", flags='f', type='vect',
     dbif.close()
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/mapcalc.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -331,9 +331,11 @@
                 count += 1
     dbif.close()
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/register.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -481,7 +481,7 @@
     register_maps_in_space_time_dataset(type, output_stds_id, unit=unit,
                                         file=filename, dbif=dbif)
-    g_remove = pymod.Module("g.remove", quiet=True,
+    g_remove = pymod.Module("g.remove", flags='f', quiet=True,
                             run_=False, finish_=True)
     # Remove empty maps
@@ -490,7 +490,7 @@
             if  map.is_in_db(dbif):
                 map.delete(dbif)
             mod = copy.deepcopy(g_remove)
-            mod(rast=map.get_name())
+            mod(type='rast', pattern=map.get_name())
             mod.run()
     if connected:
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -103,7 +103,7 @@
         >>> rmap.is_time_relative()
         False
-        >>> grass.run_command("g.remove", rast=name, quiet=True)
+        >>> grass.run_command("g.remove", flags="f", type="rast", pattern=name, quiet=True)
         0
         >>> grass.del_temp_region()
@@ -420,7 +420,7 @@
         True
         >>> r3map.is_time_relative()
         False
-        >>> grass.run_command("g.remove", rast3d=name, quiet=True)
+        >>> grass.run_command("g.remove", flags="f", type="rast3d", pattern=name, quiet=True)
         0
@@ -741,7 +741,7 @@
         True
         >>> vmap.is_time_relative()
         False
-        >>> grass.run_command("g.remove", vect=name, quiet=True)
+        >>> grass.run_command("g.remove", flags="f", type="vect", pattern=name, quiet=True)
         0
Modified: grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/temporal_raster3d_algebra.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -23,7 +23,7 @@
         TemporalRasterBaseAlgebraParser.__init__(self, pid, run, debug, spatial, nprocs, register_null)
         self.m_mapcalc = pymod.Module('r3.mapcalc')
-        self.m_mremove = pymod.Module('g.mremove')
+        self.m_remove = pymod.Module('g.remove')
     def parse(self, expression, basename = None, overwrite=False):
         self.lexer = TemporalRasterAlgebraLexer()
@@ -49,7 +49,7 @@
                 stringlist = ",".join(chunk)
                 if self.run:
-                    m = copy.deepcopy(self.m_mremove)
+                    m = copy.deepcopy(self.m_remove)
                     m.inputs["type"].value = "rast3d"
                     m.inputs["pattern"].value = stringlist
                     m.flags["f"].value = True
Modified: grass/trunk/lib/python/temporal/temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_algebra.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/temporal_raster_algebra.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -64,7 +64,7 @@
         self.m_mapcalc = pymod.Module('r.mapcalc', run_=False, finish_=False)
@@ -90,7 +90,7 @@
                 if self.run:
                     m.inputs["type"].value = "rast"
Modified: grass/trunk/lib/python/temporal/temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/temporal_vector_algebra.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/temporal_vector_algebra.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -493,7 +493,7 @@
         self.m_overlay = pygrass.Module('v.overlay', quiet=True, run_=False)
         self.m_rename = pygrass.Module('g.rename', quiet=True, run_=False)
         self.m_patch = pygrass.Module('v.patch', quiet=True, run_=False)
-        self.m_mremove = pygrass.Module('g.mremove', quiet=True, run_=False)
+        self.m_remove = pygrass.Module('g.remove', quiet=True, run_=False)
         self.m_buffer = pygrass.Module('v.buffer', quiet=True, run_=False)
     def parse(self, expression, basename = None, overwrite = False):
@@ -520,10 +520,10 @@
             for chunk in chunklist:
                 if self.debug:
-                    print "g.mremove type=vect pattern=%s"%(stringlist)
+                    print "g.remove type=vect pattern=%s"%(stringlist)
                 if self.run:
                     m.inputs["type"].value = "vect"
Modified: grass/trunk/lib/python/temporal/testsuite/test_register_function.py
--- grass/trunk/lib/python/temporal/testsuite/test_register_function.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/lib/python/temporal/testsuite/test_register_function.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -52,7 +52,7 @@
         """!Remove maps from temporal database
         self.runModule("t.unregister", maps="register_map_1,register_map_2", quiet=True)
-        self.runModule("g.mremove", type="rast",  pattern="register_map_1,register_map_2", quiet=True)
+        self.runModule("g.remove", flags='f', type="rast", pattern="register_map_1,register_map_2", quiet=True)
         self.strds_abs.delete()
         self.strds_rel.delete()
Modified: grass/trunk/raster/r.category/test_rcategory_doctest.txt
--- grass/trunk/raster/r.category/test_rcategory_doctest.txt	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.category/test_rcategory_doctest.txt	2014-09-17 16:24:34 UTC (rev 62015)
@@ -231,9 +231,9 @@
 when test finishes. It could test if everything which was expected
 to be created was created if it would check all outputs properly.
->>> run_command('g.remove', rast='test')
+>>> run_command('g.remove', flags='f', type='rast', pattern='test')
 0
->>> run_command('g.remove', rast='test_14')
+>>> run_command('g.remove', flags='f', type='rast', pattern='test_14')
 0
->>> run_command('g.remove', rast='test_d')
+>>> run_command('g.remove', flags='f', type='rast', pattern='test_d')
 0
Modified: grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh
--- grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.li/r.li.setup/masked_area_selection.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -104,7 +104,7 @@
    eval `g.findfile elem=windows file="tmp_rli_selmsk.$$" | grep '^name='`
    if [ -n "$name" ] ; then
       g.region region="tmp_rli_selmsk.$$"
-      g.remove region="tmp_rli_selmsk.$$" --quiet
+      g.remove -f type=region pattern="tmp_rli_selmsk.$$" --quiet
    fi
    rm -f "$TMP" "$TMP".val
@@ -190,8 +190,8 @@
 	    "$GIS_OPT_conf"
     # remove tmp raster and vector
-    g.remove rast="tmp_rli_mask.$$" --quiet
-    g.remove vect="tmp_rli_mask_v$$" --quiet
+    g.remove -f type=rast pattern="tmp_rli_mask.$$" --quiet
+    g.remove -f type=vect pattern="tmp_rli_mask_v$$" --quiet
     if [ "$GIS_FLAG_f" -eq 1 ] ; then
     	g.region n="$GIS_OPT_north" s="$GIS_OPT_south" \
Modified: grass/trunk/raster/r.li/r.li.setup/r.li.setup
--- grass/trunk/raster/r.li/r.li.setup/r.li.setup	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.li/r.li.setup/r.li.setup	2014-09-17 16:24:34 UTC (rev 62015)
@@ -33,7 +33,7 @@
    eval `g.findfile elem=windows file="tmp_rlisetup.$$" | grep '^name='`
       unset WIND_OVERRIDE
-      g.remove region="tmp_rlisetup.$$" --quiet
+      g.remove -f type=region pattern="tmp_rlisetup.$$" --quiet
    fi
 trap "cleanup" 2 3 15
Modified: grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh
--- grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.li/r.li.setup/sample_area_vector.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -71,7 +71,7 @@
    eval `g.findfile elem=windows file="tmp_rli_sampvect.$$" | grep '^name='`
       g.region region="tmp_rli_sampvect.$$"
-      g.remove region="tmp_rli_sampvect.$$" --quiet
+      g.remove -f type=region pattern="tmp_rli_sampvect.$$" --quiet
    fi
    rm -f "$TMP"*
@@ -184,12 +184,12 @@
 	echo "MASKEDOVERLAYAREA $mask_name|$n|$s|$e|$w" >> "$GIS_OPT_conf"
     elif [ "$ok" -eq -1 ] ; then
-	g.remove vect="$EXTRACT" --quiet
+	g.remove -f type=vect pattern="$EXTRACT" --quiet
 	break
     fi
     #remove temporary vector map created from v.extract
 done < "$TMP.cat"
Modified: grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh
--- grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.li/r.li.setup/square_mouse_selection.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -90,7 +90,7 @@
    eval `g.findfile elem=windows file="tmp_rli_sq.$$" | grep '^name='`
       g.region region="tmp_rli_sq.$$"
-      g.remove region="tmp_rli_sq.$$" --quiet
+      g.remove -f type=region pattern="tmp_rli_sq.$$" --quiet
    fi
    rm -f "$TMP" "$TMP.var"
Modified: grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh
--- grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.mapcalc/testsuite/const_map_test.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -43,7 +43,7 @@
 cleanup()
  echo "Removing temporary map"
- g.remove rast=$TMPNAME > /dev/null
+ g.remove -f type=rast pattern=$TMPNAME > /dev/null
 # check if a MASK is already present:
@@ -59,11 +59,11 @@
  echo "Restoring user region"
  g.region region=$TMPNAME
- g.remove region=$TMPNAME > /dev/null
+ g.remove -f type=region pattern=$TMPNAME > /dev/null
  #restore user mask if present:
  if test -f $LOCATION/cell/$USERMASK ; then
   echo "Restoring user MASK"
-  g.remove rast=MASK > /dev/null
+  g.remove -f type=rast pattern=MASK > /dev/null
   g.rename $USERMASK,MASK > /dev/null
  fi
Modified: grass/trunk/raster/r.mapcalc/testsuite/test_r_mapcalc.py
--- grass/trunk/raster/r.mapcalc/testsuite/test_r_mapcalc.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.mapcalc/testsuite/test_r_mapcalc.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -72,7 +72,8 @@
     @classmethod
-        cls.runModule('g.remove', rast=','.join(cls.to_remove))
+        cls.runModule('g.remove', flags='f', type='rast',
+                      pattern=','.join(cls.to_remove))
     def rinfo_contains_number(self, raster, number):
         """Test that r.info stdandard output for raster contains a given number
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.out.mpeg/main.c	2014-09-17 16:24:34 UTC (rev 62015)
@@ -398,7 +398,7 @@
 	sprintf(pattern_arg, "pattern=%s", wildarg);
 	sprintf(mapset_arg, "mapset=%s", mapset);
-	G_spawn_ex("g.mlist", "g.mlist",
+	G_spawn_ex("g.list", "g.list",
 		   type_arg, pattern_arg, mapset_arg,
 		   SF_REDIRECT_FILE, SF_STDOUT, SF_MODE_APPEND, outfile,
 		   NULL);
Modified: grass/trunk/raster/r.patch/r.patch.html
--- grass/trunk/raster/r.patch/r.patch.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.patch/r.patch.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -85,7 +85,7 @@
 used in the order listed.
-MAPS=`g.mlist type=rast sep=, pat="map_*"`
+MAPS=`g.list type=rast sep=, pat="map_*"`
 g.region rast=$MAPS
 r.patch in=$MAPS out=mosaic
 </pre></div>
Modified: grass/trunk/raster/r.reclass/r.reclass.html
--- grass/trunk/raster/r.reclass/r.reclass.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.reclass/r.reclass.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -69,7 +69,7 @@
 raster map layer from which a <em>r.reclass</em> has been derived
 is only possible if the original map is removed first.
 Alternatively, a <em>r.reclass</em> map can be removed including
-its base map by using <p><em><a href="g.mremove.html">g.mremove</a></em>'s
+its base map by using <p><em><a href="g.remove.html">g.remove</a></em>'s
 <b>-b</b> flag.
 <p>A <em>r.reclass</em> map is not a true raster map layer.
Modified: grass/trunk/raster/r.series/r.series.html
--- grass/trunk/raster/r.series/r.series.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.series/r.series.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -84,10 +84,10 @@
 Using <em>r.series</em> with wildcards:
 <br>
-r.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
+r.series input="`g.list pattern='insitu_data.*' sep=,`" \
          output=insitu_data.stddev method=stddev
 </pre></div>
-<p>Note the <em>g.mlist</em> script also supports regular expressions for
+<p>Note the <em>g.list</em> script also supports regular expressions for
 selecting map names.
 <p>Using <em>r.series</em> with NULL raster maps:
 <br>
@@ -131,11 +131,11 @@
 daily average maps ('???' as DOY wildcard):
 # Approach for shell based systems
-r.series input=`g.mlist rast pattern="temp_2003_???_avg" sep=,` \
+r.series input=`g.list rast pattern="temp_2003_???_avg" sep=,` \
          output=temp_2003_days_over_25deg range=25.0,100.0 method=count
 # Approach in two steps (e.g., for Windows systems)
-g.mlist rast pattern="temp_2003_???_avg" output=mapnames.txt
+g.list rast pattern="temp_2003_???_avg" output=mapnames.txt
 r.series file=mapnames.txt \
 </pre></div>
@@ -143,7 +143,7 @@
 <h2>SEE ALSO</h2>
-<em><a href="g.mlist.html">g.mlist</a></em>,
+<em><a href="g.list.html">g.list</a></em>,
 <em><a href="g.region.html">g.region</a></em>
 <h2>AUTHOR</h2>
Modified: grass/trunk/raster/r.series.accumulate/r.series.accumulate.html
--- grass/trunk/raster/r.series.accumulate/r.series.accumulate.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.series.accumulate/r.series.accumulate.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -125,7 +125,7 @@
 <em>
 <a href="r.series.html">r.series</a>,
-<a href="g.mlist.html">g.mlist</a>,
+<a href="g.list.html">g.list</a>,
 </em>
Modified: grass/trunk/raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh
--- grass/trunk/raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.series.accumulate/test_suite/test.r.series.accumulate.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -51,7 +51,7 @@
                     output=test_accu_9 range=6,9 method=mean --verbose
 # Test for correct results
-for map in `g.mlist type=rast pattern=test_accu_*` ; do
+for map in `g.list type=rast pattern=test_accu_*` ; do
     r.out.ascii input=${map} output=${map}.ref dp=2
 done
@@ -62,4 +62,4 @@
 CHAR_NUM=`cat out.diff | wc -c`
 # Return as exit status 0 in case no diffs are found
-exit $CHAR_NUM
\ No newline at end of file
+exit $CHAR_NUM
Modified: grass/trunk/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py
--- grass/trunk/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.slope.aspect/testsuite/test_r_slope_aspect.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -68,7 +68,7 @@
     @classmethod
-        cls.runModule('g.remove', rast=cls.elevation)
+        cls.runModule('g.remove', flags='f', type='rast', pattern=cls.elevation)
     def test_slope(self):
         ref_slope = 'reference_slope'
Modified: grass/trunk/raster/r.to.rast3elev/test.r.to.rast3elev.sh
--- grass/trunk/raster/r.to.rast3elev/test.r.to.rast3elev.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.to.rast3elev/test.r.to.rast3elev.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -45,4 +45,4 @@
 # r.to.rast3elev --o -lu input=elev_25_double,elev_5_double elevation=elev_25_double,elev_5_double output=test_elev_volume_double_9
 # Export of the references
-# for i in `g.mlist type=rast3d pattern=test_elev_volume_*` ; do r3.out.ascii dp=0 input=$i output=${i}.ref; done
+# for i in `g.list type=rast3d pattern=test_elev_volume_*` ; do r3.out.ascii dp=0 input=$i output=${i}.ref; done
Modified: grass/trunk/raster/r.viewshed/testsuite/test_r_viewshed.py
--- grass/trunk/raster/r.viewshed/testsuite/test_r_viewshed.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.viewshed/testsuite/test_r_viewshed.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -37,7 +37,7 @@
     @classmethod
     def test_viewshed(self):
         ref_viewshed = 'reference_viewshed'
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -422,7 +422,7 @@
        abs(rwater.accum), \
        null() )"
   r.colors -g rwater.course col=bcyr
-  g.remove MASK
   # <i>Thinning is required before converting raster lines to vector</i>
   r.thin in=rwater.course out=rwater.course.Thin
Modified: grass/trunk/raster/simwe/r.sim.water/spearfish.sh
--- grass/trunk/raster/simwe/r.sim.water/spearfish.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster/simwe/r.sim.water/spearfish.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -41,14 +41,14 @@
 r.out.vtk elevation=${dem} input=${output}_manin,soils vectormaps=${output}_dx,${output}_dy,${output}_null output=manning_soils_gradient.vtk null=0.0
 echo "Build topology and exporting walker vector points for each time step"
-for i in `g.mlist vect | grep ${output}` ; do
+for i in `g.list vect | grep ${output}` ; do
 	v.build $i
 	echo "v.out.vtk input=$i output=$i.vtk"
 done
 echo "Exporting the raster maps for each time step"
-for i in `g.mlist rast | grep ${output}` ; do
+for i in `g.list rast | grep ${output}` ; do
 	echo "r.out.vtk elevation=${dem} input=$i output=$i.vtk null=0.0"
 done
@@ -57,5 +57,5 @@
 echo "Step throu the time steps and adjust the color tables"
 # cleanup
-g.remove --q rast=${output}_dx,${output}_dy,${output}_rain,${output}_manin,${output}_infil,${output}_null
-g.remove --q vect=observation_points
+g.remove --q -f type=rast pattern=${output}_dx,${output}_dy,${output}_rain,${output}_manin,${output}_infil,${output}_null
+g.remove --q -f type=vect pattern=observation_points
Modified: grass/trunk/raster3d/r3.cross.rast/test.r3.cross.rast.sh
--- grass/trunk/raster3d/r3.cross.rast/test.r3.cross.rast.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster3d/r3.cross.rast/test.r3.cross.rast.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -34,7 +34,7 @@
 r3.cross.rast --o input=volume_null elevation=elev_cross output=test_cross_section_result
 # Export of the text files
-for i in `g.mlist type=rast pattern=test_cross_section_*` ; do
+for i in `g.list type=rast pattern=test_cross_section_*` ; do
     r.out.ascii input=$i output=${i}.txt;
 done
Modified: grass/trunk/raster3d/r3.flow/testsuite/r3flow_test.py
--- grass/trunk/raster3d/r3.flow/testsuite/r3flow_test.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster3d/r3.flow/testsuite/r3flow_test.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -54,8 +54,8 @@
         """!Remove the temporary region"""
-        cls.runModule('g.remove', rast3d=['map_1', 'map_2', 'map_3', 'map_4', 'map_5', 'test_flowaccum'])
-        cls.runModule('g.remove', vect=['test_flowline', 'test_seeds'])
+        cls.runModule('g.remove', flags='f', type='rast3d', pattern=['map_1', 'map_2', 'map_3', 'map_4', 'map_5', 'test_flowaccum'])
+        cls.runModule('g.remove', flags='f', type='vect', pattern=['test_flowline', 'test_seeds'])
         os.remove('./data/flowline_tmp.ascii')
     def test_interpolation(self):
Modified: grass/trunk/raster3d/r3.gradient/testsuite/r3gradient_test.py
--- grass/trunk/raster3d/r3.gradient/testsuite/r3gradient_test.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster3d/r3.gradient/testsuite/r3gradient_test.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -114,7 +114,8 @@
-        cls.runModule('g.remove', rast3d=['test_map_1_ref', 'test_map_2_ref', 'test_grad_x',
+                      pattern=['test_map_1_ref', 'test_map_2_ref', 'test_grad_x',
                                           'test_grad_y', 'test_grad_z', 'test_null_grad_x',
                                           'test_null_grad_y', 'test_null_grad_z'])
Modified: grass/trunk/raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh
--- grass/trunk/raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -124,7 +124,7 @@
     bottom=0 top=100 west=0 east=180 south=0 north=90 \
     cols=18 rows=9 depths=10
-for map in `g.mlist type=rast3d pattern=test_in_bin_float*` ; do
+for map in `g.list type=rast3d pattern=test_in_bin_float*` ; do
   r3.out.ascii input=${map} output=${map}.txt dp=0
 done
@@ -132,7 +132,7 @@
     diff $i test_out_bin_float.ref
 done
-g.mremove -f rast3d=test_in*
-g.mremove -f rast3d=test_out*
+g.remove -f type=rast3d pattern=test_in*
+g.remove -f type=rast3d pattern=test_out*
 rm test_in_*.txt
 rm test_out_*.bin
Modified: grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
--- grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -31,4 +31,4 @@
 r3.info volume_time_float
 ncdump -h test_time_float.nc
-g.remove rast3=volume_float,volume_double,volume_time_double,volume_time_float
+g.remove -f type=rast3 pattern=volume_float,volume_double,volume_time_double,volume_time_float
Modified: grass/trunk/raster3d/r3.retile/test.r3.retile.sh
--- grass/trunk/raster3d/r3.retile/test.r3.retile.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster3d/r3.retile/test.r3.retile.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -36,7 +36,7 @@
 r3.info -g map=test_retile_map_10 > test_retile_map_10_info.txt
 # Create the validation files
-for map in `g.mlist type=rast3d pattern=test_retile_map_*` ; do
+for map in `g.list type=rast3d pattern=test_retile_map_*` ; do
 done
Modified: grass/trunk/raster3d/r3.to.rast/test.r3.to.rast.sh
--- grass/trunk/raster3d/r3.to.rast/test.r3.to.rast.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/raster3d/r3.to.rast/test.r3.to.rast.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -21,8 +21,8 @@
 r3.to.rast --o input=volume_null_float output=test_raster_slice_float
-for i in `g.mlist type=rast pattern=test_raster_slice_1*` ; do r.out.ascii input=$i output=${i}.txt; done
-for i in `g.mlist type=rast pattern=test_raster_slice_float*` ; do r.out.ascii input=$i output=${i}.txt; done
+for i in `g.list type=rast pattern=test_raster_slice_1*` ; do r.out.ascii input=$i output=${i}.txt; done
+for i in `g.list type=rast pattern=test_raster_slice_float*` ; do r.out.ascii input=$i output=${i}.txt; done
 # The next @preprocess step adjusts the raster region to increase the resolution by 2
 g.region res=7.5 -p3
@@ -32,7 +32,7 @@
 r3.to.rast --o input=volume_null output=test_raster_slice_2
-for i in `g.mlist type=rast pattern=test_raster_slice_2*` ; do r.out.ascii input=$i output=${i}.txt; done
+for i in `g.list type=rast pattern=test_raster_slice_2*` ; do r.out.ascii input=$i output=${i}.txt; done
 # The next @preprocess step adjusts the raster region to increase the resolution by 2 again
 g.region res=5 -p3
@@ -42,7 +42,7 @@
 r3.to.rast --o input=volume_null output=test_raster_slice_3
-for i in `g.mlist type=rast pattern=test_raster_slice_3*` ; do r.out.ascii input=$i output=${i}.txt; done
+for i in `g.list type=rast pattern=test_raster_slice_3*` ; do r.out.ascii input=$i output=${i}.txt; done
 # Comparison of references and text files
 for i in `ls *.ref` ; do
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -495,7 +495,7 @@
     def cleanup(self):
 	grass.try_remove(self.tempfile)
-	run('g.remove', rast = self.tempmap)
+	run('g.remove', flags = 'f', type = 'rast', pattern = self.tempmap)
     def finalize(self):
 	self.save_map()
@@ -529,7 +529,7 @@
 	run('g.region', rast = self.inmap)
 	run('r.patch', input = (self.tempmap, self.outmap), output = self.outmap, overwrite = True)
 	run('r.colors', map = self.outmap, rast = self.inmap)
     def read_header(self, infile):
 	wind = {}
@@ -635,7 +635,7 @@
 	run('r.mapcalc', expression = "%s = %d" % (self.tempmap, val))
 	run('r.colors', map = self.tempmap, rast = self.inmap)
 	run('r.out.ppm', input = self.tempmap, out = self.tempfile)
 	tempimg = wx.Image(self.tempfile)
Modified: grass/trunk/scripts/d.shadedmap/d.shadedmap.py
--- grass/trunk/scripts/d.shadedmap/d.shadedmap.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/d.shadedmap/d.shadedmap.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -60,8 +60,8 @@
                           r_map = tmp_r, g_map = tmp_g, b_map = tmp_b)
         grass.run_command('r.composite', red = tmp_r, green = tmp_g,
                           blue = tmp_b, output = output_map)
-        grass.run_command('g.remove', quiet = True,
-                          rast = '%s,%s,%s' % (tmp_r, tmp_g, tmp_b))
+        grass.run_command('g.remove', flags = 'f', quiet = True, type='rast',
+                          pattern = '%s,%s,%s' % (tmp_r, tmp_g, tmp_b))
     ret = grass.run_command("d.his", h_map = drape_map, i_map = relief_map,
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -108,7 +108,7 @@
     else:
 	# remove the vector part
 	grass.run_command('v.db.connect', quiet = True, map = output, layer = '1', flags = 'd')
-	grass.run_command('g.remove', quiet = True, vect = output)
+	grass.run_command('g.remove', flags = 'f', quiet = True, type = 'vect', pattern = output)
     # get rid of superfluous auto-added cat column (and cat_ if present)
     nuldev = file(os.devnull, 'w+')
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -177,7 +177,7 @@
     grass.message(_("Remapping digital numbers to NDVI..."))
     tmpname = "%s_%s" % (name, pid)
     grass.mapcalc("$tmpname = 0.004 * $name - 0.1", tmpname = tmpname, name = name)
-    grass.run_command('g.remove', rast = name, quiet = True)
+    grass.run_command('g.remove', flags = 'f', type = 'rast', pattern = name, quiet = True)
     grass.run_command('g.rename', rast = (tmpname, name), quiet = True)
     # write cmd history:
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -175,7 +175,8 @@
         # Cleanup
-        grass.run_command('g.remove', quiet=True, rast='%s,%s,%s' % (panmatch1, panmatch2, panmatch3))
+        grass.run_command('g.remove', flags='f', quiet=True, type='rast',
+                          pattern='%s,%s,%s' % (panmatch1, panmatch2, panmatch3))
     elif sharpen == "ihs":
         grass.verbose(_("Using IHS<->RGB algorithm"))
@@ -205,7 +206,8 @@
                           blue_output="%s_blue" % out)
         # Cleanup
-        grass.run_command('g.remove', quiet=True, rast=panmatch)
+                          pattern=panmatch)
     elif sharpen == "pca":
         grass.verbose(_("Using PCA/inverse PCA algorithm"))
@@ -299,7 +301,8 @@
         # Cleanup
-        grass.run_command('g.mremove', flags='f', quiet=True, type="rast", pattern='tmp%s*,%s' % (pid,panmatch))
+        grass.run_command('g.remove', flags='f', quiet=True, type="rast",
+                          pattern='tmp%s*,%s' % (pid,panmatch))
     #Could add other sharpening algorithms here, e.g. wavelet transformation
@@ -335,7 +338,8 @@
         grass.raster_history("%s_%s" % (out, ch))
     # Cleanup
-    grass.run_command('g.mremove', flags="f", type="rast", pattern="tmp%s*" % pid, quiet=True)
+    grass.run_command('g.remove', flags="f", type="rast",
+                      pattern="tmp%s*" % pid, quiet=True)
 def matchhist(original, target, matched):
@@ -417,7 +421,8 @@
     # create reclass of target from reclass rules file
     result = grass.core.find_file(matched, element = 'cell')
     if result['fullname']:
-        grass.run_command('g.remove', quiet=True, rast=matched)
+                          pattern=matched)
         grass.run_command('r.reclass', input=original, out=matched, rules=outfile.name)
     else:
Modified: grass/trunk/scripts/i.spectral/i.spectral.html
--- grass/trunk/scripts/i.spectral/i.spectral.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/i.spectral/i.spectral.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -29,7 +29,7 @@
 g.region rast=lsat7_2002_10 -p
-LIST=`g.mlist type=rast pattern="lsat7_2002_[1-5,7]0" separator=","`
+LIST=`g.list type=rast pattern="lsat7_2002_[1-5,7]0" separator=","`
 i.spectral raster=$LIST coordinates=637502.25,221744.25
 </pre></div>
Modified: grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py
--- grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -58,9 +58,9 @@
 # what to do in case of user break:
 def cleanup():
     if grass.find_file(temp_src)['file']:
-        grass.run_command('g.remove', quiet = True, flags = 'f', rast = temp_src)
+        grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'rast', pattern = temp_src)
     if grass.find_file(temp_dist)['file']:
-        grass.run_command('g.remove', quiet = True, flags = 'f', rast = temp_dist)
+        grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'rast', pattern = temp_dist)
 def main():
     global temp_dist, temp_src
Modified: grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
--- grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -40,7 +40,8 @@
 def cleanup():
     if tmpmap:
-	grass.run_command('g.remove', rast = tmpmap, quiet = True)
+                      pattern = tmpmap, quiet = True)
 def main():
     global tmpmap
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -100,9 +100,9 @@
 def cleanup():
     #delete internal mask and any TMP files:
     if len(tmp_vmaps) > 0:
-        grass.run_command('g.remove', quiet = True, flags = 'f', vect = tmp_vmaps)
+        grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'vect', pattern = tmp_vmaps)
     if len(tmp_rmaps) > 0:
-        grass.run_command('g.remove', quiet = True, flags = 'f', rast = tmp_rmaps)
+        grass.run_command('g.remove', quiet = True, flags = 'fb', type = 'rast', pattern = tmp_rmaps)
     if usermask and mapset:
         if grass.find_file(usermask, mapset = mapset)['file']:
             grass.run_command('g.rename', quiet = True, rast = (usermask, 'MASK'), overwrite = True)
@@ -233,7 +233,7 @@
                 grass.fatal(_("abandoned. Removing temporary maps, restoring user mask if needed:"))
             # remove temporary map to not overfill disk
-            if grass.run_command('g.remove', flags = 'f', vect = holename + '_pol', quiet = quiet) != 0:
+            if grass.run_command('g.remove', flags = 'fb', type = 'vect', pattern = holename + '_pol', quiet = quiet) != 0:
             tmp_vmaps.remove(holename + '_pol')
@@ -325,14 +325,14 @@
                 tmp_rmaps.remove(holename + '_dem')
             except:
                 pass
-            if grass.run_command('g.remove', quiet = quiet, flags = 'f', rast =
+            if grass.run_command('g.remove', quiet = quiet, flags = 'fb', type = 'rast', pattern =
                 (holename, holename + '_grown', holename + '_edges', holename + '_dem')) != 0:
             try:
                 tmp_vmaps.remove(holename)
             except:
                 pass
-            if grass.run_command('g.remove', quiet = quiet, flags = 'f', vect = holename) != 0:
+            if grass.run_command('g.remove', quiet = quiet, flags = 'fb', type = 'vect', pattern = holename) != 0:
     #check if method is different from rst to use r.resamp.bspline
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r.grow/r.grow.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -68,7 +68,8 @@
 def cleanup():
     for map in [temp_dist, temp_val]:
         if map:
-            grass.run_command('g.remove', quiet = True, flags = 'f', rast = map)
+            grass.run_command('g.remove', flags = 'fb', quiet = True,
+                              type='rast', pattern = map)
 def main():
     global temp_dist, temp_val
Modified: grass/trunk/scripts/r.in.wms/wms_base.py
--- grass/trunk/scripts/r.in.wms/wms_base.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r.in.wms/wms_base.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -463,8 +463,9 @@
             if maps:
                                   quiet = True,
-                                  flags = 'f',
-                                  rast  = ','.join(maps))
+                                  flags = 'fb',
+                                  type = 'rast',
+                                  pattern = ','.join(maps))
         # delete environmental variable which overrides region
         if 'GRASS_REGION' in os.environ.keys():
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r.mask/r.mask.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -73,9 +73,11 @@
 def cleanup():
     if tmp:
-        grass.run_command('g.remove', rast = tmp, quiet = True)
+                          pattern = tmp, quiet = True)
     if tmp_hull:
-        grass.run_command('g.remove', vect = tmp_hull, quiet = True)
+        grass.run_command('g.remove', flags = 'f', type = 'vect',
+                          pattern = tmp_hull, quiet = True)
 def main():
     raster = options['raster']
@@ -96,7 +98,8 @@
     if remove:
         # -> remove
         if exists:
-            grass.run_command('g.remove', quiet = True, rast = 'MASK')
+                              type = 'rast', pattern = 'MASK')
             grass.message(_("Raster MASK removed"))
         else:
             grass.fatal(_("No existing MASK to remove"))
@@ -107,7 +110,8 @@
                 grass.fatal(_("MASK already found in current mapset. Delete first or overwrite."))
             else:
                 grass.warning(_("MASK already exists and will be overwritten"))
         if raster:
             # check if input raster exists
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -164,7 +164,7 @@
     """!Delete temporary maps"""
     TMPRAST.reverse()  # reclassed map first
     for rast in TMPRAST:
-        grass.run_command("g.remove", rast=rast, quiet=True)
+        grass.run_command("g.remove", flags='f', type='rast', pattern=rast, quiet=True)
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass/trunk/scripts/r.unpack/test_suite/test.r.unpack.sh
--- grass/trunk/scripts/r.unpack/test_suite/test.r.unpack.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r.unpack/test_suite/test.r.unpack.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -21,7 +21,7 @@
 r.pack --o --v -c input=test_double output=test_double_uncompressed.pack
 # Remove generated maps and re-import
-g.remove rast=test_int,test_float,test_double
+g.remove -f type=rast pattern=test_int,test_float,test_double
 # Second we check the import with r.unpack
 r.unpack --o --v input=test_int.pack
@@ -42,5 +42,5 @@
 #r.out.ascii --o input=test_float_uncompressed output=test_float_uncompressed.ref dp=1
 #r.out.ascii --o input=test_double_uncompressed output=test_double_uncompressed.ref dp=1
-g.remove rast=test_int,test_float,test_double,test_int_uncompressed,test_float_uncompressed,test_double_uncompressed
-rm *.pack
+g.remove -f type=rast pattern=test_int,test_float,test_double,test_int_uncompressed,test_float_uncompressed,test_double_uncompressed
+rm *.pack
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -178,7 +178,7 @@
 def cleanup():
-    grass.run_command('g.mremove', flags = 'f',
 		      type = "rast", pattern = 'tmp.r3xyz.%d.*' % os.getpid(),
 		      quiet = True)
@@ -310,7 +310,7 @@
     grass.verbose(_("Assembling 3D cube ..."))
     #input order: lower most strata first
-    slices = grass.read_command('g.mlist', type = 'rast', sep = ',',
+    slices = grass.read_command('g.list', type = 'rast', sep = ',',
 				pattern = 'tmp.r3xyz.%d.*' % os.getpid()).rstrip('\n')
     grass.debug(slices)
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.html
--- grass/trunk/scripts/v.dissolve/v.dissolve.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -50,7 +50,7 @@
 <div class="code"><pre>
 # patch tiles after import:
-v.patch -e `g.mlist type=vect pat="clc2000_*" separator=","` out=clc2000_patched
+v.patch -e `g.list type=vect pat="clc2000_*" separator=","` out=clc2000_patched
 # remove duplicated tile boundaries:
 v.clean clc2000_patched out=clc2000_clean tool=snap,break,rmdupl thresh=.01
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -40,7 +40,7 @@
 def cleanup():
     nuldev = file(os.devnull, 'w')
-    grass.run_command('g.remove', vect = '%s_%s' % (output, tmp), quiet = True, stderr = nuldev)
+    grass.run_command('g.remove', flags = 'f', type = 'vect', pattern = '%s_%s' % (output, tmp), quiet = True, stderr = nuldev)
 def main():
     global output, tmp
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.py
--- grass/trunk/scripts/v.out.gps/v.out.gps.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -99,10 +99,12 @@
     # only try to remove map if it exists to avoid ugly warnings
     if tmp_vogb:
 	if grass.find_file(tmp_vogb, element = 'vector')['name']:
-	    grass.run_command('g.remove', vect = tmp_vogb, quiet = True)
+                          pattern = tmp_vogb, quiet = True)
     if tmp_extr:
 	if grass.find_file(tmp_extr, element = 'vector')['name']:
 tmp = None
 tmp_proj = None
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -69,8 +69,10 @@
 def cleanup():
     if rastertmp:
-        grass.run_command('g.remove', rast=rastertmp, quiet=True)
-    grass.run_command('g.remove', rast='MASK', quiet=True, stderr=nuldev)
+        grass.run_command('g.remove', flags='f', type='rast',
+                          pattern=rastertmp, quiet=True)
+                      pattern='MASK', quiet=True, stderr=nuldev)
     if mask_found:
         grass.message(_("Restoring previous MASK..."))
         grass.run_command('g.rename', rast=(tmpname + "_origmask", 'MASK'),
@@ -279,7 +281,8 @@
     exitcode = grass.run_command('db.execute', input=sqltmp,
                                  database=fi['database'], driver=fi['driver'])
     if exitcode == 0:
         grass.verbose((_("Statistics calculated from raster map <%s>") % raster) +
Modified: grass/trunk/scripts/v.to.lines/v.to.lines.py
--- grass/trunk/scripts/v.to.lines/v.to.lines.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/v.to.lines/v.to.lines.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -89,22 +89,26 @@
     if 0 != grass.run_command('v.category', layer="2", type='boundary',
                               option='add', input=input, out=input_tmp,
                               quiet=quiet):
-        grass.run_command('g.remove', vect=input_tmp, quiet=quiet)
+                          pattern=input_tmp, quiet=quiet)
         grass.fatal(_("Error creating layer 2"))
     if 0 != grass.run_command('v.db.addtable', map=input_tmp, layer="2",
                               columns="left integer,right integer",
                               quiet=quiet):
         grass.fatal(_("Error creating new table for layer 2"))
     if 0 != grass.run_command('v.to.db', map=input_tmp, option="sides",
                               columns="left,right", layer="2", quiet=quiet):
         grass.fatal(_("Error populating new table for layer 2"))
     if 0 != grass.run_command('v.type', input=input_tmp, output=out_type,
                               from_type='boundary', to_type='line',
                               quiet=quiet, layer="2"):
-        grass.run_command('g.remove', vect=remove_names, quiet=quiet)
+                          pattern=remove_names, quiet=quiet)
         grass.fatal(_("Error converting polygon to line"))
     report = grass.read_command('v.category', flags='g', input=out_type,
                                 option='report', quiet=quiet).split('\n')
@@ -117,24 +121,29 @@
         if 0 != grass.run_command('v.edit', map=out_type, tool='delete',
                                   type='centroid', layer=2, quiet=quiet,
                                   cats='{mi}-{ma}'.format(mi=min_cat, ma=max_cat)):
             grass.fatal(_("Error removing centroids"))
     try:
         if 0 != grass.run_command('v.db.droptable', map=out_type, layer=1,
                                   flags='f', quiet=True):
             grass.fatal(_("Error removing table from layer 1"))
     except:
         grass.warning(_("No table for layer %d" % 1))
     if 0 != grass.run_command('v.category', input=out_type, option='transfer',
                               output=output, layer="2,1", quiet=quiet,
                               overwrite=overwrite):
         grass.fatal(_("Error adding categories"))
     if point:
-        grass.run_command('g.remove', vect=out_temp, quiet=quiet)
+                          pattern=out_temp, quiet=quiet)
Modified: grass/trunk/scripts/v.unpack/test_suite/test.v.unpack.sh
--- grass/trunk/scripts/v.unpack/test_suite/test.v.unpack.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/v.unpack/test_suite/test.v.unpack.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -19,7 +19,7 @@
 db.copy from_table=probe_orig to_table=probe_3_3
 # Removing un-needed vectors and tables
-g.remove vect=probe_orig
+g.remove -f type=vect pattern=probe_orig
 v.db.droptable -f map=probe_3 table=probe_3 layer=1
 # Adding tables to layer
@@ -37,7 +37,7 @@
 v.pack --o -c input=probe_3 output=probe_3_uncompressed.pack
 # We need to clean before import
-g.remove vect=probe_1,probe_2,probe_3
+g.remove -f type=vect pattern=probe_1,probe_2,probe_3
 # Test the import with v.unpack
 v.unpack --o input=probe_1.pack
@@ -55,5 +55,5 @@
 v.unpack --o input=probe_3.pack output=probe_3_uncompressed
 v.category input=probe_3_uncompressed option=report
-g.remove vect=probe_1_uncompressed,probe_2_uncompressed,probe_3_uncompressed
+g.remove -f type=vect pattern=probe_1_uncompressed,probe_2_uncompressed,probe_3_uncompressed
 rm *.pack
Modified: grass/trunk/scripts/v.unpack/v.unpack.py
--- grass/trunk/scripts/v.unpack/v.unpack.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/scripts/v.unpack/v.unpack.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -90,7 +90,8 @@
         grass.fatal(_("Vector map <%s> already exists") % map_name)
     elif overwrite == '1' and gfile['file']:
         grass.warning(_("Vector map <%s> already exists and will be overwritten") % map_name)
-        grass.run_command('g.remove', quiet=True, vect=map_name)
+        grass.run_command('g.remove', flags='f', quiet=True, type='vect',
+                          pattern=map_name)
         shutil.rmtree(new_dir, True)
     # extract data
Modified: grass/trunk/temporal/t.list/t.list.html
--- grass/trunk/temporal/t.list/t.list.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.list/t.list.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -47,7 +47,6 @@
 <em>
 <a href="t.create.html">t.create</a>,
 <a href="t.info.html">t.info</a>,
 <a href="t.rast.list.html">t.rast.list</a>,
Modified: grass/trunk/temporal/t.merge/testsuite/test.t.merge.sh
--- grass/trunk/temporal/t.merge/testsuite/test.t.merge.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.merge/testsuite/test.t.merge.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -49,4 +49,4 @@
 t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
 t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+g.remove -f type=rast pattern=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
--- grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -418,7 +418,7 @@
     # Remove empty maps
     if len(empty_maps) > 0:
         for map in empty_maps:
-            grass.run_command("g.mremove", type="rast",  pattern=map.get_name(), quiet=True)
+            grass.run_command("g.remove", flags='f', type="rast",  pattern=map.get_name(), quiet=True)
Modified: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
--- grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -500,7 +500,7 @@
     # Remove empty maps
Modified: grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh
--- grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.gapfill/test.t.rast.gapfill.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -31,4 +31,4 @@
 t.unregister --v type=rast maps=prec_1,prec_2,prec_3,prec_6,prec_7
 t.remove --v type=strds input=precip_abs
-g.remove rast=prec_1,prec_2,prec_3,prec_6,prec_7
+g.remove -f type=rast pattern=prec_1,prec_2,prec_3,prec_6,prec_7
Modified: grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -75,7 +75,7 @@
 # Cleaning up
 t.remove type=strds input=precip_rel
 rm -rf test
 rm strds_export.tar.bz2
 rm strds_export.tar.gz
Modified: grass/trunk/temporal/t.rast.import/test.t.rast.import.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -74,7 +74,7 @@
 # Cleaning up
 rm -rf test
Modified: grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -59,7 +59,7 @@
 rm -rf test
 rm strds_export_pack.tar.gz
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.html
--- grass/trunk/temporal/t.rast.list/t.rast.list.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -168,7 +168,6 @@
 <em>
 <a href="t.list.html">t.list</a>,
Modified: grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
--- grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -47,7 +47,7 @@
 t.info type=strds input=precip_abs4
 # Let the test fail
 t.rast.mapcalc -sn inputs=precip_abs1,precip_abs2 output=precip_abs4 \
            expression=" (precip_abs1 + precip_abs2) * null()" base=new_prec \
            method=equal nprocs=5
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -185,7 +185,7 @@
             else:
-        grass.run_command("g.remove", rast=names, quiet=True)
+        grass.run_command("g.remove", flags='f', type='rast', pattern=names, quiet=True)
     dbif.close()
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -144,8 +144,8 @@
             count += 1
     if use_granularity:
-        grass.run_command("g.remove", rast=null_map)
-    grass.run_command("g.remove", rast=map_name)
+        grass.run_command("g.remove", flags='f', type='rast', pattern=null_map)
+    grass.run_command("g.remove", flags='f', type='rast', pattern=map_name)
Modified: grass/trunk/temporal/t.rast.series/test.t.rast.series.sh
--- grass/trunk/temporal/t.rast.series/test.t.rast.series.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.series/test.t.rast.series.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -32,4 +32,4 @@
 t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6,prec_sum,prec_max
-g.remove rast=prec_sum,prec_max,prec_average
+g.remove -f type=rast pattern=prec_sum,prec_max,prec_average
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -148,7 +148,7 @@
         if ret != 0:
             grass.fatal(_("Unable to create 3D raster map <%s>" % output))
     title = _("Space time voxel cube")
     descr = _("This space time voxel cube was created with t.rast.to.rast3")
Modified: grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -68,7 +68,7 @@
         """Remove generated data"""
         #self.runModule("t.remove",  flags="rf",  type="strds",
         #                           inputs="precip_i,precip_f,precip_d")
-        #self.runModule('g.mremove', type='rast', pattern='prec_*', flags='f')
+        #self.runModule('g.remove', type='rast', pattern='prec_*', flags='f')
         self.del_temp_region()
     def otest_3m(self):
@@ -257,7 +257,7 @@
     def tearDown(self):
         #self.runModule("t.remove",  flags="rf",  type="strds", inputs="precip_d")
     def otest_years(self):
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.html
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -7,7 +7,6 @@
 <em>
Modified: grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh
--- grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.register/test.t.register.vector.file.layer.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -71,4 +71,4 @@
 t.unregister --v type=vect maps=lidar_abs_1:1,lidar_abs_1:2,lidar_abs_1:3,lidar_abs_1:4,lidar_abs_1:5,lidar_abs_1:6
 t.remove type=stvds input=lidar_abs_ds1
-g.remove vect=lidar_abs_1,lidar_abs_orig
+g.remove -f type=vect pattern=lidar_abs_1,lidar_abs_orig
Modified: grass/trunk/temporal/t.register/test.t.register.vector.sh
--- grass/trunk/temporal/t.register/test.t.register.vector.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.register/test.t.register.vector.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -63,6 +63,6 @@
 t.unregister --v type=vect maps=lidar_abs_1,lidar_abs_2,lidar_abs_3
 t.remove --v type=stvds input=lidar_abs_ds1,lidar_abs_ds2,lidar_abs_ds3,lidar_abs_ds4,lidar_abs_ds5,lidar_abs_ds6,lidar_abs_ds7
 t.unregister --v type=vect maps=lidar_abs_4,lidar_abs_5,lidar_abs_6
-g.remove vect=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6
+g.remove -f type=vect pattern=lidar_abs_1,lidar_abs_2,lidar_abs_3,lidar_abs_4,lidar_abs_5,lidar_abs_6
Modified: grass/trunk/temporal/t.remove/t.remove.html
--- grass/trunk/temporal/t.remove/t.remove.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.remove/t.remove.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -25,9 +25,9 @@
   description="Monthly sum of precipitation for the \
   North Carolina sample data location"
-#Register maps from sample dataset (selecting a subset with g.mlist)
+#Register maps from sample dataset (selecting a subset with g.list)
 t.register -i type=rast input=precip_months_sum \
-  maps=$(g.mlist type=rast pattern=201*_precip separator=comma) \
+  maps=$(g.list type=rast pattern=201*_precip separator=comma) \
   start="2010-01-01" increment="1 months"
 #Create some new data by aggregating with 1 years granularity
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.remove/t.remove.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -106,8 +106,8 @@
     statement = ""
-    # Create the pygrass Module object for g.mremove
-    remove = pyg.Module("g.mremove", quiet=True, run_=False)
+    # Create the pygrass Module object for g.remove
+    remove = pyg.Module("g.remove", quiet=True, run_=False)
     for name in dataset_list:
         name = name.strip()
Modified: grass/trunk/temporal/t.rename/test.t.rename.sh
--- grass/trunk/temporal/t.rename/test.t.rename.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.rename/test.t.rename.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -49,4 +49,4 @@
 t.remove --v type=strds input=precip_abs3,precip_abs4
Modified: grass/trunk/temporal/t.support/test.t.support.sh
--- grass/trunk/temporal/t.support/test.t.support.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.support/test.t.support.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -54,7 +54,7 @@
 t.info type=strds input=precip_abs2
 # Remove three maps
 # Booth space time datasets should be updated and 3 maps must have been unregistered
 t.support --v -m type=strds input=precip_abs1
@@ -63,4 +63,4 @@
 t.remove --v type=strds input=precip_abs1,precip_rel1
-g.remove rast=prec_4,prec_5,prec_6
+g.remove -f type=rast pattern=prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
--- grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -39,6 +39,6 @@
 t.remove type=stvds input=prec_observer
 t.unregister type=vect maps=prec_observer:1,prec_observer:2,prec_observer:3,prec_observer:4,prec_observer:5,prec_observer:6
-g.remove vect=prec_observer,test_extract
+g.remove -f type=vect pattern=prec_observer,test_extract
Modified: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh
--- grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -42,6 +42,6 @@
 t.remove type=stvds input=prec_observer,test_extract_1,test_extract_2,test_extract_3
-g.mremove -f type=vect pattern=test_*
+g.remove -f type=vect pattern=test_*
Modified: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
--- grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -44,5 +44,5 @@
 # @postprocess
 t.unregister type=vect maps=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
 t.remove type=stvds input=soil_abs1,soil_abs2,soil_abs3
-g.remove vect=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
-g.remove vect=new_vect_1,new_vect_2,new_vect_3,new_vect_4,new_vect_5,new_vect_6
+g.remove -f type=vect pattern=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
+g.remove -f type=vect pattern=new_vect_1,new_vect_2,new_vect_3,new_vect_4,new_vect_5,new_vect_6
Modified: grass/trunk/temporal/t.vect.import/testsuite/test.t.vect.import.sh
--- grass/trunk/temporal/t.vect.import/testsuite/test.t.vect.import.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.import/testsuite/test.t.vect.import.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -59,7 +59,7 @@
 # Cleaning up
 rm -rf test
 t.unregister type=vect file="${n1}"
 rm stvds_export_gml.tar.bz2
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.html
--- grass/trunk/temporal/t.vect.list/t.vect.list.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -7,7 +7,6 @@
 <em>
Modified: grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh
--- grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -121,4 +121,4 @@
 t.unregister type=vect maps=soils:1,soils:2,soils:3,soils:4,soils:5,soils:6
 t.remove type=stvds input=soils_abs1,soils_abs2,soils_abs3,soils_abs4,soils_abs5
-g.remove vect=soil_orig,soils
+g.remove -f type=vect pattern=soil_orig,soils
Modified: grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh
--- grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -106,4 +106,4 @@
 #t.unregister type=vect maps=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
 #t.remove type=stvds input=lidar_abs1,lidar_abs2,lidar_abs3,lidar_abs4,lidar_abs5
-#g.remove vect=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
+#g.remove -f type=vect pattern=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
Modified: grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh
--- grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -36,5 +36,5 @@
-#g.remove vect=prec_observer
-#g.mremove -f type=rast pattern=test_prec_*
+#g.remove -f type=vect pattern=prec_observer
+#g.remove -f type=rast pattern=test_prec_*
Modified: grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh
--- grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -31,5 +31,5 @@
-#g.remove vect=prec_observer,test_extract
-#g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+#g.remove -f type=vect pattern=prec_observer,test_extract
+#g.remove -f type=rast pattern=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.vect.univar/testsuite/test.t.vect.univar.sh
--- grass/trunk/temporal/t.vect.univar/testsuite/test.t.vect.univar.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.univar/testsuite/test.t.vect.univar.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -27,5 +27,5 @@
 # @postprocess
 t.unregister type=vect maps=rpoints1,rpoints2,rvoronoi1,rvoronoi2
 t.remove type=stvds input=random_data
-g.remove vect=rpoints1,rpoints2,rvoronoi1,rvoronoi2
+g.remove -f type=vect pattern=rpoints1,rpoints2,rvoronoi1,rvoronoi2
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -184,8 +184,8 @@
        rastermap))
                 if aggreagated_map_name:
-                    ret = grass.run_command("g.remove",
-                                            rast=aggreagated_map_name)
+                    ret = grass.run_command("g.remove", flags='f', type=rast,
+                                            pattern=aggreagated_map_name)
                     if ret != 0:
                         dbif.close()
                         grass.fatal(_("Unable to remove raster map <%s>")
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -77,5 +77,5 @@
 t.unregister type=rast maps=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
 t.remove type=strds input=sand_frac_abs_1,sand_frac_abs_2
-g.remove rast=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
-g.remove vect=soils,soil_orig
+g.remove -f type=rast pattern=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
+g.remove -f type=vect pattern=soils,soil_orig
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -54,5 +54,5 @@
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -55,5 +55,5 @@
 t.remove type=strds input=precip_rel1
Modified: grass/trunk/testsuite/raster/raster_md5test.sh
--- grass/trunk/testsuite/raster/raster_md5test.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/testsuite/raster/raster_md5test.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -48,7 +48,7 @@
 cleanup()
@@ -64,11 +64,11 @@
  fi
Modified: grass/trunk/testsuite/raster/rhemisphere.sh
--- grass/trunk/testsuite/raster/rhemisphere.sh	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/testsuite/raster/rhemisphere.sh	2014-09-17 16:24:34 UTC (rev 62015)
@@ -24,7 +24,7 @@
 cleanup()
- g.remove --q rast=$TMP > /dev/null
+ g.remove --q -f type=rast pattern=$TMP > /dev/null
Modified: grass/trunk/tools/thumbnails.py
--- grass/trunk/tools/thumbnails.py	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/tools/thumbnails.py	2014-09-17 16:24:34 UTC (rev 62015)
@@ -30,9 +30,11 @@
     if tmp_img:
         grass.try_remove(tmp_img)
     if tmp_grad_rel:
-        grass.run_command('g.remove', rast = tmp_grad_rel, quiet = True)
+                          pattern = tmp_grad_rel, quiet = True)
     if tmp_grad_abs:
-        grass.run_command('g.remove', rast = tmp_grad_abs, quiet = True)
+                          pattern = tmp_grad_abs, quiet = True)
 # def rotate(src, dst):
 #     grass.call(["convert", "-rotate", "90", src, dst])
Modified: grass/trunk/vector/v.distance/v.distance.html
--- grass/trunk/vector/v.distance/v.distance.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/vector/v.distance/v.distance.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -149,7 +149,7 @@
 # we need to give the lines category numbers, create a table, and create
 #  a column in that table to hold the distance data.
 v.category vdistance_vectors_raw out=vdistance_vectors type=line op=add
-g.remove v=vdistance_vectors_raw
+g.remove -f type=vect pattern=vdistance_vectors_raw
 v.db.addtable map=vdistance_vectors column="length DOUBLE"
 v.to.db map=vdistance_vectors option=length column=length
Modified: grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html
--- grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html	2014-09-17 14:07:36 UTC (rev 62014)
+++ grass/trunk/vector/v.lrs/v.lrs.create/v.lrs.create.html	2014-09-17 16:24:34 UTC (rev 62015)
@@ -43,7 +43,7 @@
 # vector line needs to be polyline
 v.build.polylines busroute_tmp2 out=busroute_tmp3
 v.category busroute_tmp3 out=busroute op=add
-g.remove vect=busroute_tmp,busroute_tmp2,busroute_tmp3
+g.remove -f type=vect pattern=busroute_tmp,busroute_tmp2,busroute_tmp3
 </pre></div>
 The result can be visualized:
