[GRASS-SVN] r62017 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Wed Sep 17 09:47:11 PDT 2014
Author: wenzeslaus
Date: 2014-09-17 09:47:11 -0700 (Wed, 17 Sep 2014)
New Revision: 62017
grass/trunk/lib/python/gunittest/multireport.py
grass/trunk/lib/python/gunittest/reporters.py
gunittest: improve handling of extereme cases (when no tests were executed)
Modified: grass/trunk/lib/python/gunittest/multireport.py
--- grass/trunk/lib/python/gunittest/multireport.py 2014-09-17 16:30:52 UTC (rev 62016)
+++ grass/trunk/lib/python/gunittest/multireport.py 2014-09-17 16:47:11 UTC (rev 62017)
@@ -208,7 +208,7 @@
summary_file = os.path.join(report, 'test_keyvalue_result.txt')
if not os.path.exists(summary_file):
sys.stderr.write('WARNING: Key-value summary not available in'
- ' report <%s>, skipping.\n')
+ ' report <%s>, skipping.\n' % summary_file)
# skipping incomplete reports
# use only results list for further processing
continue
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py 2014-09-17 16:30:52 UTC (rev 62016)
+++ grass/trunk/lib/python/gunittest/reporters.py 2014-09-17 16:47:11 UTC (rev 62017)
@@ -373,8 +373,14 @@
self.main_time = self.main_end_time - self.main_start_time
assert self.test_files == self.files_fail + self.files_pass
- self.file_pass_per = 100 * float(self.files_pass) / self.test_files
- self.file_fail_per = 100 * float(self.files_fail) / self.test_files
+ if self.test_files:
+ self.file_pass_per = 100 * float(self.files_pass) / self.test_files
+ self.file_fail_per = 100 * float(self.files_fail) / self.test_files
+ else:
+ # if no tests were executed, probably something bad happend
+ # try to report at least something
+ self.file_pass_per = None
+ self.file_fail_per = None
def start_file_test(self, module):
self.file_start_time = datetime.datetime.now()
@@ -393,7 +399,9 @@
def percent_to_html(percent):
- if percent > 100 or percent < 0:
+ if percent is None:
+ return '<span style="color: {color}">unknown percentage</span>'
+ elif percent > 100 or percent < 0:
return "? {:.2f}% ?".format(percent)
elif percent < 40:
color = 'red'
@@ -564,18 +572,26 @@
st=self.successes, ft=self.failures + self.errors,
total=self.total, pt=pass_per
+ # this is the second place with this function
+ # TODO: provide one implementation
+ def format_percentage(percentage):
+ if percentage is not None:
+ return "{nsper:.0f}%".format(nsper=percentage)
+ else:
+ return "unknown percentage"
- summary_sentence = ('Executed {nfiles} test files in {time:}.'
- ' From them'
- ' {nsfiles} files ({nsper:.0f}%) were successful'
- ' and {nffiles} files ({nfper:.0f}%) failed.'
+ summary_sentence = ('\nExecuted {nfiles} test files in {time:}.'
+ '\nFrom them'
+ ' {nsfiles} files ({nsper}) were successful'
+ ' and {nffiles} files ({nfper}) failed.\n'
.format(
nfiles=self.test_files,
time=self.main_time,
nsfiles=self.files_pass,
nffiles=self.files_fail,
- nsper=self.file_pass_per,
- nfper=self.file_fail_per))
+ nsper=format_percentage(self.file_pass_per),
+ nfper=format_percentage(self.file_fail_per)))
self.main_index.write('<tbody>{tfoot}</table>'
'<p>{summary}</p>'
@@ -881,17 +897,23 @@
def finish(self):
super(GrassTestFilesTextReporter, self).finish()
+ else:
'\nFrom them'
- ' and {nffiles} files ({nfper:.0f}%) failed.\n'
.format(
self._stream.write(summary_sentence)
