[GRASS-SVN] r62026 - in grass/trunk: display/d.info include/defs lib/display
svn_grass at osgeo.org
Wed Sep 17 15:43:22 PDT 2014
Author: glynn
Date: 2014-09-17 15:43:22 -0700 (Wed, 17 Sep 2014)
New Revision: 62026
grass/trunk/display/d.info/main.c
grass/trunk/include/defs/display.h
grass/trunk/lib/display/r_raster.c
grass/trunk/lib/display/setup.c
Change handling of display frame, graphical clip window
Replace D_get_window with D_get_frame
Add D_get_clip_window, D_set_clip_window
Add D_set_clip_window_to_map_window, D_set_clip_window_to_screen_window
Store initial frame size within display library
Change D_setup* functions to set graphical clip window
Modified: grass/trunk/display/d.info/main.c
--- grass/trunk/display/d.info/main.c 2014-09-17 20:43:55 UTC (rev 62025)
+++ grass/trunk/display/d.info/main.c 2014-09-17 22:43:22 UTC (rev 62026)
@@ -71,7 +71,7 @@
"Use d.mon to select graphics device."));
if (rflag->answer || dflag->answer || fflag->answer)
- D_get_window(&t, &b, &l, &r);
+ D_get_frame(&t, &b, &l, &r);
if (rflag->answer)
Modified: grass/trunk/include/defs/display.h
--- grass/trunk/include/defs/display.h 2014-09-17 20:43:55 UTC (rev 62025)
+++ grass/trunk/include/defs/display.h 2014-09-17 22:43:22 UTC (rev 62026)
@@ -149,8 +149,6 @@
void D_close_driver(void);
int D_save_command(const char *);
-void D_get_window(double *, double *, double *, double *);
void D__erase(void);
void D_text_size(double, double);
@@ -162,4 +160,10 @@
void D_font_list(char ***, int *);
void D_font_info(char ***, int *);
+void D_get_clip_window(double *, double *, double *, double *);
+void D_set_clip_window(double, double, double, double);
+void D_get_frame(double *, double *, double *, double *);
+void D_set_clip_window_to_map_window(void);
+void D_set_clip_window_to_screen_window(void);
#endif /* GRASS_DISPLAYDEFS_H */
Modified: grass/trunk/lib/display/r_raster.c
--- grass/trunk/lib/display/r_raster.c 2014-09-17 20:43:55 UTC (rev 62025)
+++ grass/trunk/lib/display/r_raster.c 2014-09-17 22:43:22 UTC (rev 62026)
@@ -36,6 +36,10 @@
static int read_env_file(const char *);
+static struct {
+ double t, b, l, r;
+} screen;
static void init(void)
const char *fenc = getenv("GRASS_ENCODING");
@@ -60,10 +64,11 @@
D_text_rotation(0);
if (frame) {
- double t, b, l, r;
- sscanf(frame, "%lf,%lf,%lf,%lf", &t, &b, &l, &r);
- COM_Set_window(t, b, l, r);
+ sscanf(frame, "%lf,%lf,%lf,%lf", &screen.t, &screen.b, &screen.l, &screen.r);
+ COM_Set_window(screen.t, screen.b, screen.l, screen.r);
+ else
+ COM_Get_window(&screen.t, &screen.b, &screen.l, &screen.r);
int read_env_file(const char *path)
@@ -266,19 +271,6 @@
- \brief Get clipping frame
- \param[out] t top
- \param[out] b bottom
- \param[out] l left
- \param[out] r right
-void D_get_window(double *t, double *b, double *l, double *r)
- return COM_Get_window(t, b, l, r);
\brief Draw text
Writes <em>text</em> in the current color and font, at the current text
@@ -334,3 +326,96 @@
COM_Font_info(list, count);
+ * \brief get graphical clipping window
+ * Queries the graphical clipping window (origin is top right)
+ * \param[out] t top edge of clip window
+ * \param[out] b bottom edge of clip window
+ * \param[out] l left edge of clip window
+ * \param[out] r right edge of clip window
+ * \return ~
+void D_get_clip_window(double *t, double *b, double *l, double *r)
+ COM_Get_window(t, b, l, r);
+ * \brief set graphical clipping window
+ * Sets the graphical clipping window to the specified rectangle
+ * (origin is top right)
+ * \param t top edge of clip window
+ * \param b bottom edge of clip window
+ * \param l left edge of clip window
+ * \param r right edge of clip window
+ * \return ~
+void D_set_clip_window(double t, double b, double l, double r)
+ if (t < screen.t) t = screen.t;
+ if (b > screen.b) b = screen.b;
+ if (l < screen.l) l = screen.l;
+ if (r > screen.r) r = screen.r;
+ COM_Set_window(t, b, l, r);
+ * \brief get graphical window (frame)
+ * Queries the graphical frame (origin is top right)
+ * \param[out] t top edge of frame
+ * \param[out] b bottom edge of frame
+ * \param[out] l left edge of frame
+ * \param[out] r right edge of frame
+ * \return ~
+void D_get_frame(double *t, double *b, double *l, double *r)
+ *t = screen.t;
+ *b = screen.b;
+ *l = screen.l;
+ *r = screen.r;
+ * \brief set graphical clipping window to map window
+ * Sets the graphical clipping window to the pixel window that corresponds
+ * to the current database region.
+ * \param ~
+ * \return ~
+ D_set_clip_window(
+ D_get_d_north(), D_get_d_south(),
+ D_get_d_west(), D_get_d_east());
+ * \brief set clipping window to screen window
+ * Sets the clipping window to the pixel window that corresponds to the
+ * full screen window. Off screen rendering is still clipped.
+ * \param ~
+ * \return ~
Modified: grass/trunk/lib/display/setup.c
--- grass/trunk/lib/display/setup.c 2014-09-17 20:43:55 UTC (rev 62025)
+++ grass/trunk/lib/display/setup.c 2014-09-17 22:43:22 UTC (rev 62026)
@@ -46,15 +46,19 @@
struct Cell_head region;
double dt, db, dl, dr;
- D_get_window(&dt, &db, &dl, &dr);
+ D_get_frame(&dt, &db, &dl, &dr);
G_get_set_window(®ion);
Rast_set_window(®ion);
D_do_conversions(®ion, dt, db, dl, dr);
+ D_set_clip_window_to_screen_window();
if (clear)
D_erase(DEFAULT_BG_COLOR);
+ D_set_clip_window_to_map_window();
@@ -73,15 +77,19 @@
D_set_src(dt, db, dl, dr);
D_set_dst(dt, db, dl, dr);
D_update_conversions();
if (clear)
@@ -105,7 +113,7 @@
D_set_src(st, sb, sl, sr);
@@ -115,6 +123,10 @@
if (clear)
