[GRASS-SVN] r62031 - in grass/branches/releasebranch_7_0/raster/simwe: r.sim.sediment r.sim.water
svn_grass at osgeo.org
Wed Sep 17 18:54:37 PDT 2014
Author: neteler
Date: 2014-09-17 18:54:37 -0700 (Wed, 17 Sep 2014)
New Revision: 62031
grass/branches/releasebranch_7_0/raster/simwe/r.sim.sediment/main.c
grass/branches/releasebranch_7_0/raster/simwe/r.sim.water/main.c
r.sim.*: user message harmonization
Modified: grass/branches/releasebranch_7_0/raster/simwe/r.sim.sediment/main.c
--- grass/branches/releasebranch_7_0/raster/simwe/r.sim.sediment/main.c 2014-09-18 01:54:14 UTC (rev 62030)
+++ grass/branches/releasebranch_7_0/raster/simwe/r.sim.sediment/main.c 2014-09-18 01:54:37 UTC (rev 62031)
@@ -157,7 +157,7 @@
parm.maninval->type = TYPE_DOUBLE;
parm.maninval->answer = MANINVAL;
parm.maninval->required = NO;
- parm.maninval->description = _("Name of Manning's n value");
+ parm.maninval->description = _("Manning's n unique value");
parm.maninval->guisection = _("Input");
parm.outwalk = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -171,14 +171,14 @@
parm.observation->key = "observation";
parm.observation->required = NO;
parm.observation->description =
- _("Name of the sampling locations vector points map");
+ _("Name of sampling locations vector points map");
parm.observation->guisection = _("Input options");
parm.logfile = G_define_standard_option(G_OPT_F_OUTPUT);
parm.logfile->key = "logfile";
parm.logfile->required = NO;
parm.logfile->description =
- _("Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored.");
+ _("Name for sampling points output text file. For each observation vector point the time series of sediment transport is stored.");
parm.logfile->guisection = _("Output");
parm.tc = G_define_standard_option(G_OPT_R_OUTPUT);
Modified: grass/branches/releasebranch_7_0/raster/simwe/r.sim.water/main.c
--- grass/branches/releasebranch_7_0/raster/simwe/r.sim.water/main.c 2014-09-18 01:54:14 UTC (rev 62030)
+++ grass/branches/releasebranch_7_0/raster/simwe/r.sim.water/main.c 2014-09-18 01:54:37 UTC (rev 62031)
@@ -158,7 +158,7 @@
parm.manin = G_define_standard_option(G_OPT_R_INPUT);
parm.manin->key = "man";
parm.manin->required = NO;
- parm.manin->description = _("Name of the Manning's n raster map");
+ parm.manin->description = _("Name of Manning's n raster map");
parm.manin->guisection = _("Input");
parm.maninval = G_define_option();
@@ -180,14 +180,14 @@
- _("Name of the sampling points output text file. For each observation vector point the time series of water depth is stored.");
parm.depth = G_define_standard_option(G_OPT_R_OUTPUT);
