[GRASS-SVN] r62041 - grass/trunk/raster/r.walk
svn_grass at osgeo.org
Sat Sep 20 05:09:28 PDT 2014
Author: mmetz
Date: 2014-09-20 05:09:28 -0700 (Sat, 20 Sep 2014)
New Revision: 62041
grass/trunk/raster/r.walk/heap.c
grass/trunk/raster/r.walk/main.c
r.walk: fix fp format in messages
Modified: grass/trunk/raster/r.walk/heap.c
--- grass/trunk/raster/r.walk/heap.c 2014-09-20 12:07:06 UTC (rev 62040)
+++ grass/trunk/raster/r.walk/heap.c 2014-09-20 12:09:28 UTC (rev 62041)
@@ -39,8 +39,8 @@
-#include <grass/gis.h>
#include <stdlib.h>
+#include <grass/gis.h>
#include <grass/glocale.h>
#include "cost.h"
@@ -92,11 +92,7 @@
long sift_up(long start, struct cost * child_pnt)
register long parent, child;
- int r, c;
- r = child_pnt->row;
- c = child_pnt->col;
child = start;
while (child > 1) {
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2014-09-20 12:07:06 UTC (rev 62040)
+++ grass/trunk/raster/r.walk/main.c 2014-09-20 12:09:28 UTC (rev 62041)
@@ -384,7 +384,7 @@
G_fatal_error(_("Missing required value: got %d instead of 4"),
par_number);
else {
- G_message(_("Walking costs are a=%lf b=%lf c=%lf d=%lf"), a, b, c, d);
+ G_message(_("Walking costs are a=%g b=%g c=%g d=%g"), a, b, c, d);
/* Getting lambda */
@@ -392,7 +392,7 @@
G_fatal_error(_("Missing required value: %d"), par_number);
else {
- G_message(_("Lambda is %lf"), lambda);
+ G_message(_("Lambda is %g"), lambda);
/* Getting slope_factor */
@@ -400,7 +400,7 @@
else {
- G_message(_("Slope_factor is %lf"), slope_factor);
+ G_message(_("Slope_factor is %g"), slope_factor);
if ((opt6->answer == NULL) ||
@@ -482,9 +482,9 @@
G_debug(1, " %d rows, %d cols", nrows, ncols);
G_format_resolution(window.ew_res, buf, window.proj);
- G_debug(1, " EW resolution %s (%lf)", buf, window.ew_res);
+ G_debug(1, " EW resolution %s (%g)", buf, window.ew_res);
G_format_resolution(window.ns_res, buf, window.proj);
- G_debug(1, " NS resolution %s (%lf)", buf, window.ns_res);
+ G_debug(1, " NS resolution %s (%g)", buf, window.ns_res);
/* this is most probably the limitation of r.walk for large datasets
* segment size needs to be reduced to avoid unecessary disk IO
@@ -1489,7 +1489,7 @@
* Rast_write_colors (cum_cost_layer,"",&colors);
- G_done_msg(_("Peak cost value: %f."), peak);
+ G_done_msg(_("Peak cost value: %g."), peak);
exit(EXIT_SUCCESS);
@@ -1520,7 +1520,7 @@
if (east < window.west || east > window.east ||
north < window.south || north > window.north) {
- G_warning(_("Warning, ignoring point outside window: %.4f,%.4f"),
+ G_warning(_("Warning, ignoring point outside window: %g, %g"),
east, north);
continue;
