[GRASS-SVN] r62049 - in grass-addons/grass7/raster: . r.droka
Mon Sep 22 03:58:21 PDT 2014
Author: kikapu
Date: 2014-09-22 03:58:20 -0700 (Mon, 22 Sep 2014)
New Revision: 62049
Added:
   grass-addons/grass7/raster/r.droka/
   grass-addons/grass7/raster/r.droka/Makefile
   grass-addons/grass7/raster/r.droka/r.droka.html
   grass-addons/grass7/raster/r.droka/r.droka.py
Calculates run-out distance of a falling rock mass
Added: grass-addons/grass7/raster/r.droka/Makefile
--- grass-addons/grass7/raster/r.droka/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.droka/Makefile	2014-09-22 10:58:20 UTC (rev 62049)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.droka
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.droka/r.droka.html
Added: grass-addons/grass7/raster/r.droka/r.droka.py
--- grass-addons/grass7/raster/r.droka/r.droka.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.droka/r.droka.py	2014-09-22 10:58:20 UTC (rev 62049)
@@ -0,0 +1,187 @@
+#!/usr/bin/env python
+# MODULE:	r.droka
+# AUTHOR(S):	original idea by: HUNGR (1993)
+#		implementation by:
+#               Andrea Filipello -filipello at provincia.verbania.it
+#               Daniele Strigaro - daniele.strigaro at gmail.com
+# PURPOSE:	Calculates run-out distance of a falling rock mass
+# COPYRIGHT:	(C) 2009 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#%  description: Calculates run-out distance of a falling rock mass
+#%  keywords: rock mass, rockfall
+#%End
+#%option
+#% key: dem
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Digital Elevation Model
+#% required: yes
+#%end
+#%option
+#% key: start
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of existing rock mass start point
+#% required : yes
+#%end
+#%option
+#% key: x
+#% type: double
+#% description: Est coordinate of source point
+#% required: yes
+#%end
+#%option
+#% key: y
+#% type: double
+#% description: North coordinate of source point
+#% required: yes
+#%end
+#%option
+#% key: z
+#% type: double
+#% description: Elevation of source point
+#% required: yes
+#%end
+#%option
+#% key: red
+#% type: double
+#% description: Reduction parameter
+#% options : 0-1
+#% required: yes
+#%end
+#%option
+#% key: m
+#% type: double
+#% description: Rock block mass (Kg/m^3)
+#% required: yes
+#%end
+#%option
+#% key: vel
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Translational velocity (corrected)
+#% required : yes
+#%end
+#%option
+#% key: en
+#% type: string
+#% description: Kinematic energy (kJ) (corrected)
+#% required: yes
+#%end
+import os, sys, time, math, numpy , string, re
+try:
+    import grass.script as grass
+except:
+    try:
+        from grass.script import core as grass
+	#from grass.script import core as gcore
+    except:
+        sys.exit("grass.script can't be imported.")
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+def main():
+    # leggo variabili
+    r_elevation = options['dem'].split('@')[0]
+    mapname = options['dem'].replace("@", " ")
+    mapname = mapname.split()
+    mapname[0] = mapname[0].replace(".", "_")
+    start = options['start']
+    start_ = start.split('@')[0]
+    gfile = grass.find_file(start, element = 'vector')
+    if not gfile['name']:
+        grass.fatal(_("Vector map <%s> not found") % infile)
+    x = options['x']
+    y = options['y']
+    z = options['z']
+    ang = 30
+    red = options['red']
+    m = options['m']
+    vel = str(options['vel'])
+    en = str(options['en'])
+    print 'x = ' , x
+    print 'y = ' , y
+    print 'z = ' , z
+#    print 'ang = ' , ang
+    print 'red = ' , red
+    print 'm = ' , m
+    print 'vel = ' , vel
+    print 'en = ' , en
+    point = grass.read_command("v.out.ascii", input=start, format="standard")
+    result = point.split("\n")
+    coords = []
+    for line in result:
+        if re.findall(r'^.[0-9]+\.',line):
+            coords.append(line.strip().split("   "))
+    print coords
+    #creo raster (che sara' il DEM di input) con valore 1
+    grass.mapcalc('uno=$dem*0+1',
+        dem = r_elevation)
+    # Calcolo cost (sostituire i punti di partenza in start_raster al pusto di punto)
+    grass.run_command('r.cost' ,
+        flags="k",
+        input = 'uno',
+        output = 'costo',
+        start_points = start )
+    #trasforma i valori di distanza celle in valori metrici utilizzando la risoluzione raster
+    grass.mapcalc('costo_m=costo*(ewres()+nsres())/2')
+    # calcola A=tangente angolo visuale (INPUT) * costo in metri
+    grass.mapcalc('A=tan($ang)*costo_m',
+        ang = ang)
+    grass.mapcalc('C=$z-A',
+        z = z)
+    grass.mapcalc('D=C-$dem',
+    # area di espansione
+    grass.mapcalc('E=if(D>0,1,null())')
+    # valore di deltaH (F)
+    grass.mapcalc('F=D*E')
+    # calcolo velocita
+    grass.mapcalc('$vel=$red*sqrt(2*9.8*F)',
+        vel = vel,
+        red = red)
+    # calcolo energia
+    grass.mapcalc('$en=$m*9.8*F/1000',
+        en = en,
+        m = m)
+    for i in xrange(len(coords)):
+        row = coords[i]
+#r.what map=DTM10_f211 at modulo_issa points=point at modulo_issa
+    grass.run_command('g.remove' ,
+        rast=(
+            'uno',
+            'costo',
+            'costo_m',
+            'A',
+            'C',
+            'D',
+            'E',
+            'F'))
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
