[GRASS-SVN] r62051 - grass/branches/releasebranch_7_0/gui/wxpython/gui_core
Mon Sep 22 08:13:28 PDT 2014
Author: annakrat
Date: 2014-09-22 08:13:28 -0700 (Mon, 22 Sep 2014)
New Revision: 62051
   grass/branches/releasebranch_7_0/gui/wxpython/gui_core/preferences.py
wxGUI: don't save default window layout when window is minimized, checking size is not enough on Windows 8 (merge trunk, r62050)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/preferences.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/preferences.py	2014-09-22 15:08:30 UTC (rev 62050)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/preferences.py	2014-09-22 15:13:28 UTC (rev 62051)
@@ -1353,13 +1353,11 @@
                 pos  = mapdisp.GetPosition()
                 size = mapdisp.GetSize()
-                # window size must be larger than zero
-                if size[0] > 0 and size[1] > 0:
+                # window size must be larger than zero, not minimized
+                if not mapdisp.IsIconized() and (size[0] > 0 and size[1] > 0):
                     dim += ',%d,%d,%d,%d' % (pos[0], pos[1], size[0], size[1])
             self.settings.Set(group = 'general', key = 'defWindowPos', subkey = 'dim', value = dim)
-        else:
-            self.settings.Set(group = 'general', key = 'defWindowPos', subkey = 'dim', value = '')
         return True
