[GRASS-SVN] r62058 - grass/trunk/scripts/r3.in.xyz
svn_grass at osgeo.org
Tue Sep 23 11:34:37 PDT 2014
Author: annakrat
Date: 2014-09-23 11:34:37 -0700 (Tue, 23 Sep 2014)
New Revision: 62058
grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
r3.in.xyz: remove tabs from code, make it pep8 compatible
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py 2014-09-23 18:20:40 UTC (rev 62057)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py 2014-09-23 18:34:37 UTC (rev 62058)
@@ -178,9 +178,9 @@
def cleanup():
- grass.run_command('g.remove', flags = 'f',
- type = "rast", pattern = 'tmp.r3xyz.%d.*' % os.getpid(),
- quiet = True)
+ grass.run_command('g.remove', flags='f',
+ type="rast", pattern='tmp.r3xyz.%d.*' % os.getpid(),
+ quiet=True)
def main():
@@ -204,12 +204,11 @@
ignore_broken = flags['i']
if workers is 1 and "WORKERS" in os.environ:
- workers = int(os.environ["WORKERS"])
+ workers = int(os.environ["WORKERS"])
if not os.path.exists(infile):
- grass.fatal(_("Unable to read input file <%s>") % infile)
+ grass.fatal(_("Unable to read input file <%s>") % infile)
addl_opts = {}
if pth:
addl_opts['pth'] = '%s' % pth
@@ -224,31 +223,29 @@
if ignore_broken:
addl_opts['flags'] = 'i'
if scan_only or shell_style:
if shell_style:
- doShell = 'g'
- else:
- doShell = ''
- grass.run_command('r.in.xyz', flags = 's' + doShell, input = infile,
- output = 'dummy', sep = fs, x = x, y = y, z = z,
- **addl_opts)
- sys.exit()
+ doShell = 'g'
+ else:
+ doShell = ''
+ grass.run_command('r.in.xyz', flags='s' + doShell, input=infile,
+ output='dummy', sep=fs, x=x, y=y, z=z,
+ **addl_opts)
+ sys.exit()
- if dtype is 'float':
- data_type = 'FCELL'
+ if dtype == 'float':
+ data_type = 'FCELL'
else:
- data_type = 'DCELL'
+ data_type = 'DCELL'
- region = grass.region(region3d = True)
+ region = grass.region(region3d=True)
if region['nsres'] != region['nsres3'] or region['ewres'] != region['ewres3']:
- grass.run_command('g.region', flags = '3p')
+ grass.run_command('g.region', flags='3p')
grass.fatal(_("The 2D and 3D region settings are different. Can not continue."))
grass.verbose(_("Region bottom=%.15g top=%.15g vertical_cell_res=%.15g (%d depths)")
- % (region['b'], region['t'], region['tbres'], region['depths']))
+ % (region['b'], region['t'], region['tbres'], region['depths']))
grass.verbose(_("Creating slices ..."))
@@ -268,59 +265,56 @@
depths = range(1, 1 + region['depths'])
for i in depths:
- tmp_layer_name = 'tmp.r3xyz.%d.%s' % (os.getpid(), '%05d' % i)
+ tmp_layer_name = 'tmp.r3xyz.%d.%s' % (os.getpid(), '%05d' % i)
- zrange_min = region['b'] + (region['tbres'] * (i-1))
+ zrange_min = region['b'] + (region['tbres'] * (i - 1))
if i < region['depths']:
zrange_max = region['b'] + (region['tbres'] * i) - eps
else:
- zrange_max = region['b'] + (region['tbres'] * i)
+ zrange_max = region['b'] + (region['tbres'] * i)
# spawn depth layer import job in the background
#grass.debug("slice %d, <%s> %% %d" % (band, image[band], band % workers))
grass.message(_("Processing horizontal slice %d of %d [%.15g,%.15g) ...")
- % (i, region['depths'], zrange_min, zrange_max))
+ % (i, region['depths'], zrange_min, zrange_max))
- proc[i] = grass.start_command('r.in.xyz', input = infile, output = tmp_layer_name,
- sep = fs, method = method, x = x, y = y, z = z,
- percent = percent, type = data_type,
- zrange = '%.15g,%.15g' % (zrange_min, zrange_max),
- **addl_opts)
+ proc[i] = grass.start_command('r.in.xyz', input=infile, output=tmp_layer_name,
+ sep=fs, method=method, x=x, y=y, z=z,
+ percent=percent, type=data_type,
+ zrange='%.15g,%.15g' % (zrange_min, zrange_max),
+ **addl_opts)
- grass.debug("i=%d, %%=%d (workers=%d)" % (i, i % workers, workers))
- #print sys.getsizeof(proc) # sizeof(proc array) [not so big]
+ grass.debug("i=%d, %%=%d (workers=%d)" % (i, i % workers, workers))
+ #print sys.getsizeof(proc) # sizeof(proc array) [not so big]
- if i % workers is 0:
- # wait for the ones launched so far to finish
- for p_i in depths[:i]:
- pout[p_i] = proc[p_i].communicate()[0]
- if proc[p_i].wait() is not 0:
- grass.fatal(_("Trouble importing data. Aborting."))
+ if i % workers is 0:
+ # wait for the ones launched so far to finish
+ for p_i in depths[:i]:
+ pout[p_i] = proc[p_i].communicate()[0]
+ if proc[p_i].wait() is not 0:
+ grass.fatal(_("Trouble importing data. Aborting."))
# wait for jSobs to finish, collect any stray output
for i in depths:
- pout[i] = proc[i].communicate()[0]
- if proc[i].wait() is not 0:
+ pout[i] = proc[i].communicate()[0]
+ if proc[i].wait() is not 0:
del proc
grass.verbose(_("Assembling 3D cube ..."))
#input order: lower most strata first
- slices = grass.read_command('g.list', type = 'rast', sep = ',',
- pattern = 'tmp.r3xyz.%d.*' % os.getpid()).rstrip(os.linesep)
+ slices = grass.read_command('g.list', type='rast', sep=',',
+ pattern='tmp.r3xyz.%d.*' % os.getpid()).rstrip(os.linesep)
grass.debug(slices)
- if grass.run_command('r.to.rast3', input = slices, output = output) is 0:
- grass.message(_("Done. 3D raster map <%s> created.") % output)
+ if grass.run_command('r.to.rast3', input=slices, output=output) is 0:
+ grass.message(_("Done. 3D raster map <%s> created.") % output)
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
main()
