[GRASS-SVN] r62062 - in grass-addons/grass7/vector: . v.lidar.mcc
Wed Sep 24 00:26:31 PDT 2014
Author: sbl
Date: 2014-09-24 00:26:30 -0700 (Wed, 24 Sep 2014)
New Revision: 62062
Added:
   grass-addons/grass7/vector/v.lidar.mcc/
   grass-addons/grass7/vector/v.lidar.mcc/Makefile
   grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.html
   grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.py
v.lidar.mcc - new addon for lidar point cloud filtering
Added: grass-addons/grass7/vector/v.lidar.mcc/Makefile
--- grass-addons/grass7/vector/v.lidar.mcc/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.lidar.mcc/Makefile	2014-09-24 07:26:30 UTC (rev 62062)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.lidar.mcc
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.lidar.mcc/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.html
--- grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.html	2014-09-24 07:26:30 UTC (rev 62062)
@@ -0,0 +1,69 @@
+<h2>DESCRIPTION</h2>
+<p>
+<em>v.lidar.mcc</em> is a modified implementation of the Multiscale Curvature Classification (MCC) algorithm proposed by Evans & Hudak 2007.
+</p>
+<p>
+The aim of the MCC-procedure is to filter non-ground returns caused by vegetation cover from point clouds
+produced with any kind of LiDAR instrument (e.g. also instruments without intensity information).<br>
+</p>
+<p>
+The basic principle of the algorithm is to classify those points as non-ground points which deviate more than a user-defined
+threshold (<b>t</b>) from a surface which was interpolated from the full point cloud as a thin plate (here implemented with a bilinear spline
+interpolation with Tykhonov regularization through <em><a href="v.outlier.html">v.outlier</a></em>). Tension (<b>f</b>) and spline steps (<b>s</b>) parameter
+are passed to the relevant parameters in <em><a href="v.outlier.html">v.outlier</a></em>.
+</p>
+<p>
+On each scale domain <em>v.lidar.mcc</em> calls <em><a href="v.outlier.html">v.outlier</a></em> repeatedly until the algorithm converges, i.e.
+less than the amount of points (percentage of input points to the iteration) defined in the convergence threshold (<b>j</b>) are classified as non-ground points.
+Scale domains are defined in relation to the current region. With a number of scale domains <b>(nl)</b> greater than 1 scale domains are distributed evenly "around"
+the current region. With the default number of three scale domains, the first scale domaine uses half the resolution of the current region, scale domain
+two uses the current region and scale domain three uses 1,5 times the resolution of the current region.
+</p>
+<h2>NOTES</h2>
+<p>
+The optimal settings for the parameters of <em>v.lidar.mcc</em> depend very much on the resolution of the current region and the density of the LiDAR data,
+as well as terrain and vegetation.
+Therefore, a bit of try and error is usually required in order to find the optimal settings.
+In general spline steps (<b>s</b>) and curvature tolerance threshold (<b>t</b>) parameters have most influence on the results, where larger spline steps and
+a lower curvature tolerance threshold lead to more points clasified as non-ground points, but possibly also to increased clasification errors in complex terrain.
+</p>
+<p>
+The algorithm by Evans & Hudak 2007 was developed for filtering LiDAR data in dense forest areas where not necessarily all pixels
+have a ground return point which is why a simple local minimum filering often is not sufficient.
+</p>
+<p>
+In principle the algorithm works also on shrub-vegetation, however due to the lower vegetation type the curvature threshold will have to be
+lowered. In this case special attention should be payed to edges and peaks in the terrain which may be affected by low curvature tolerance thresholds.
+Therfore using a smaller cell size and wider spline steps is recommended for filtering lower structures like shrubs.
+</p>
+<p>The effect and output of the filtering process can be visually inspected already during iterations when the resulting layer with non-ground points is
+displayed while the classification is running.<br>
+However, especially the first runs on scale domains with a small pixels size can be relatively time consuming.
+</p>
+<h2>EXAMPLES</h2>
+TBD
+<h2>SEE ALSO</h2>
+<em>
+  <a href="v.surf.bspline.html">v.surf.bspline</a>,
+  <a href="v.outlier.html">v.outlier</a>,
+  <a href="v.lidar.edgedetection.html">v.lidar.edgedetection</a>
+</em>
+<h2>AUTHOR</h2>
+Stefan Blumentrath, Norwegian Institute for Nature Research (NINA), Oslo, Norway
+<h2>REFERENCES</h2>
+Evans, J. S. & Hudak, A. T. 2007: A Multiscale Curvature Algorithm for Classifying Discrete Return LiDAR in Forested Environments.
+IEEE TRANSACTIONS ON GEOSCIENCE AND REMOTE SENSING 45(4): 1029 - 1038.
+<a href="http://www.fs.fed.us/rm/pubs_other/rmrs_2007_evans_j001.pdf">http://www.fs.fed.us/rm/pubs_other/rmrs_2007_evans_j001.pdf</a><br>
+<a href="http://sourceforge.net/p/mcclidar/wiki/Home/">http://sourceforge.net/p/mcclidar/wiki/Home/</a>
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.py
--- grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.py	2014-09-24 07:26:30 UTC (rev 62062)
@@ -0,0 +1,243 @@
+#!/usr/bin/env python
+# MODULE:       v.lidar.mcc
+# AUTHOR:       Stefan Blumentrath, Norwegian Institute for Nature Research (NINA),
+#               Oslo
+# PURPOSE:      Reclassify points of a LiDAR point cloud as ground / non-ground
+#               using a multiscale curvature based classification algorithm
+# COPYRIGHT:    (c) 2013 Stefan Blumentrath, NINA, and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%module
+#% description: Reclassify points of a LiDAR point cloud as ground / non-ground sing a multiscale curvature based classification algorithm.
+#% keywords: vector
+#% keywords: lidar
+#% keywords: classification
+#%end
+#%flag
+#% key: n
+#% description: Filter negative outliers (default is positive)
+#%end
+#%option G_OPT_V_INPUT
+#% description: Input vector point map
+#% label: Input point layer.
+#% required: yes
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: g_output
+#% label: Output ground return points
+#% description: Output vector point map containing points classified as ground return.
+#% required: yes
+#%end
+#% key: ng_output
+#% label: Output non-ground return points
+#% description: Output vector point map containing points NOT classified as ground return.
+#% required: yes
+#%end
+#%option nl
+#% key: nl
+#% label: Number of scale domains (nl)
+#% description: nl
+#% type: integer
+#% required: no
+#% answer : 3
+#%end
+#%option t
+#% key: t
+#% type: double
+#% label: Curvature tolerance threshold (t)
+#% required: no
+#% answer : 0.3
+#%end
+#%option j
+#% key: j
+#% label: Convergence threshold (j)
+#% type: double
+#% required: no
+#% answer : 0.1
+#%end
+#%option f
+#% key: f
+#% label: Tension parameter (f)
+#% type: double
+#% required: no
+#% answer : 2
+#%end
+#%option s
+#% key: s
+#% label: Spline steps parameter (s)
+#% type: integer
+#% required: no
+#% answer : 10
+#%end
+import sys
+import os
+import atexit
+# GRASS binding
+try:
+    import grass.script as grass
+except ImportError:
+    sys.exit(_("No GRASS-python library found"))
+if not os.environ.has_key("GISBASE"):
+    print "You must be in GRASS GIS to run this program."
+    sys.exit(1)
+GUIModulesPath = os.path.join(os.getenv("GISBASE"), "etc", "gui", "wxpython")
+sys.path.append(GUIModulesPath)
+GUIPath = os.path.join(os.getenv("GISBASE"), "etc", "gui", "wxpython", "scripts")
+sys.path.append(GUIPath)
+### i18N
+import gettext
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+def cleanup():
+    nuldev = file(os.devnull, 'w')
+    grass.run_command('g.remove', vect = '%s,%s,%s' % (temp_ng, temp_ncin, temp_ncout), quiet = True, stderr = nuldev)
+def main():
+    global temp_ng, temp_ncin, temp_ncout
+    # Initalise temporary verctor map names
+    temp_ng = "v_lidar_mcc_tmp_ng_" + str(os.getpid())
+    temp_ncin = "v_lidar_mcc_tmp_ncin_" + str(os.getpid())
+    temp_ncout = "v_lidar_mcc_tmp_ncout_" + str(os.getpid())
+    input = options['input']
+    g_output = options['g_output']
+    ng_output = options['ng_output']
+    # does map exist?
+    if not grass.find_file(input, element = 'vector')['file']:
+        grass.fatal(_("Vector map <%s> not found") % input)
+    # Count points in input map
+    n_input = grass.vector_info(input)['points']
+    # does map contain points ?
+    if not ( n_input > 0 ):
+        grass.fatal(_("Vector map <%s> does not contain points") % input)
+    flag_n=flags['n']
+    ### Scale domain (l)
+    # Evans & Hudak 2007 used scale domains 1 to 3
+    l = int(1)
+    l_stop = int(options['nl'])
+    if ( l_stop < 1 ):
+        grass.fatal("The minimum number of scale domains is 1.")
+    ### Curvature tolerance threshold (t)
+    # Evans & Hudak 2007 used a t-value of 0.3
+    t = float(options['t'])
+    ###Increase of curvature tolerance threshold for each
+    ti = t / 3.0
+    ### Convergence threshold (j)
+    # Evans & Hudak 2007 used a convergence threshold of 0.3
+    j = float(options['j'])
+    if ( j <= 0 ):
+        grass.fatal("The convergence threshold has to be > 0.")
+    ### Tension parameter (f)
+    # Evans & Hudak 2007 used a tension parameter 1.5
+    f = float(options['f'])
+    if ( f <= 0 ):
+        grass.fatal("The tension parameter has to be > 0.")
+    ### Spline steps parameter (s)
+    # Evans & Hudak 2007 used the 12 nearest neighbors
+    # (used spline steps $res * 5 before)
+    s = int(options['s'])
+    if ( s <= 0 ):
+        grass.fatal("The spline step parameter has to be > 0.")
+    ###Read desired resolution from region
+    #Evans & Hudak 2007 used a desired resolution (delta) of 1.5
+    gregion = grass.region()
+    x_res_fin=gregion['ewres']
+    y_res_fin=gregion['nsres']
+    # Defineresolution steps in iteration
+    n_res_steps = ( l_stop + 1 ) / 2
+    # Pass ame of input map to v.outlier
+    nc_points = input
+    # Create output map for non-ground points
+    grass.run_command("v.edit", tool="create", map=ng_output, quiet = True )
+    # Loop through scale domaines
+    while ( l <= l_stop ) :
+        i = 1
+        convergence = 100
+        if (l < ( ( l_stop + 1 ) / 2 ) ) :
+            xres = x_res_fin / ( n_res_steps - ( l - 1 ) )
+            yres = y_res_fin / ( n_res_steps - ( l - 1 ) )
+        elif ( l == ( ( l_stop + 1 ) / 2 ) ) :
+             xres = x_res_fin
+             yres = y_res_fin
+        else :
+            xres = x_res_fin * ( ( l + 1 ) - n_res_steps )
+            yres = y_res_fin * ( ( l + 1 ) - n_res_steps )
+        grass.use_temp_region()
+        grass.run_command("g.region", s=gregion['s'], w=gregion['w'], nsres=yres, ewres=xres, flags="a")
+        xs_s = xres * s
+        ys_s = yres * s
+        grass.message("Processing scale domain " + str(l) + "...")
+        # Repeat application of v.outlier until convergence level is reached
+        while ( convergence > j ) :
+            grass.verbose("Number of input points in iteration " + str(i) + ": " + str(n_input) )
+            # Run v.outlier
+            if flag_n == False :
+                grass.run_command("v.outlier", input = nc_points, output = temp_ncout, outlier=temp_ng, ew_step=xs_s, ns_step=ys_s, lambda_i=f, thres_o=t, filter="positive", overwrite = True, quiet = True, stderr = nuldev )
+            else :
+                grass.run_command("v.outlier", input = nc_points, output = temp_ncout, outlier=temp_ng, ew_step=xs_s, ns_step=ys_s, lambda_i=f, thres_o=t, filter="negative", overwrite = True, quiet = True, stderr = nuldev )
+            # Get information about results for calculating convergence level
+            ng=grass.vector_info(temp_ng)['points']
+            nc = n_input - ng
+            n_input = nc
+            grass.run_command('g.remove', vect = temp_ncin, quiet = True, stderr = nuldev)
+            grass.run_command("g.rename", vect=temp_ncout + "," + temp_ncin, quiet = True, stderr = nuldev )
+            nc_points = temp_ncin
+            # Give information on process status
+            grass.verbose("Unclassified points after iteration " + str(i) + ": " + str(nc) )
+            grass.verbose("Points classified as non ground after iteration " + str(i) + ": " + str(ng) )
+            # Set convergence level
+            if ( nc > 0 ) :
+                convergence = float( float(ng) / float(nc) )
+                # Patch non-ground points to non-ground output map
+                grass.run_command("v.patch", input = temp_ng, output = ng_output, flags = "ab", overwrite = True, quiet = True, stderr = nuldev )
+            else :
+                convergence = 0
+            # Give information on convergence level
+            grass.verbose("Convergence level after run " + str(i) + " in scale domain " + str(l) + ": " + str( round( convergence, 3 ) ) )
+            # Increase iterator
+            i = i + 1
+        # Adjust curvature tolerance and reset scale domain
+        t = t + ti
+        l = l + 1
+        # Delete temporary region
+        grass.del_temp_region()
+    # Rename temporary map of points whichhave not been classified as non-ground to output vector map containing ground points
+    grass.run_command("g.rename", vect=nc_points + "," + g_output, quiet = True, stderr = nuldev )
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.lidar.mcc/v.lidar.mcc.py
   + text/x-python
   + native
