[GRASS-SVN] r62065 - grass-addons/grass7/raster/r.droka
svn_grass at osgeo.org
Wed Sep 24 02:53:59 PDT 2014
Author: kikapu
Date: 2014-09-24 02:53:59 -0700 (Wed, 24 Sep 2014)
New Revision: 62065
grass-addons/grass7/raster/r.droka/r.droka.py
R.droka update
Modified: grass-addons/grass7/raster/r.droka/r.droka.py
--- grass-addons/grass7/raster/r.droka/r.droka.py 2014-09-24 08:19:56 UTC (rev 62064)
+++ grass-addons/grass7/raster/r.droka/r.droka.py 2014-09-24 09:53:59 UTC (rev 62065)
@@ -34,24 +34,12 @@
#% required : yes
#%end
#%option
-#% key: x
+#% key: ang
#% type: double
-#% description: Est coordinate of source point
+#% description: Shadow angle
#% required: yes
#%end
#%option
-#% key: y
-#% type: double
-#% description: North coordinate of source point
-#% required: yes
-#%end
-#%option
-#% key: z
-#% type: double
-#% description: Elevation of source point
-#% required: yes
-#%end
-#%option
#% key: red
#% type: double
#% description: Reduction parameter
@@ -65,22 +53,62 @@
#% required: yes
#%end
#%option
-#% key: vel
+#% key: rocks
#% type: string
#% gisprompt: new,cell,raster
-#% description: Translational velocity (corrected)
+#% description: Rocks number
#% required : yes
#%end
#%option
-#% key: en
+#% key: vmax
#% type: string
-#% description: Kinematic energy (kJ) (corrected)
+#% description: Max translational velocity (corrected)
+#% required : yes
+#%end
+#%option
+#% key: vmean
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Mean translational velocity (corrected)
+#% required : yes
+#%end
+#%option
+#% key: emax
+#% type: string
+#% description: Max kinematic energy (kJ) (corrected)
#% required: yes
#%end
+#%option
+#% key: emean
+#% type: string
+#% description: Mean kinematic energy (kJ) (corrected)
+#% required: yes
+#%end
+#option
+# key: x
+# type: double
+# description: Est coordinate of source point
+# required: no
+#end
+#option
+# key: y
+# type: double
+# description: North coordinate of source point
+# required: no
+#end
+#option
+# key: z
+# type: double
+# description: Elevation of source point
+# required: no
+#end
-import os, sys, time, math, numpy , string, re
+import os, sys, time, math , string, re
+from grass.script import array as garray
+import numpy as np
try:
import grass.script as grass
except:
@@ -107,70 +135,110 @@
if not gfile['name']:
grass.fatal(_("Vector map <%s> not found") % infile)
- x = options['x']
- y = options['y']
- z = options['z']
- ang = 30
+ #x = options['x']
+ #y = options['y']
+ #z = options['z']
+ ang = options['ang']
red = options['red']
m = options['m']
- vel = str(options['vel'])
- en = str(options['en'])
+ rocks = str(options['rocks'])
+ vMax = str(options['vmax'])
+ vMean = str(options['vmean'])
+ eMax = str(options['emax'])
+ eMean = str(options['emean'])
- print 'x = ' , x
- print 'y = ' , y
- print 'z = ' , z
-# print 'ang = ' , ang
+ #print 'x = ' , x
+ #print 'y = ' , y
+ #print 'z = ' , z
+ print 'ang = ' , ang
print 'red = ' , red
print 'm = ' , m
- print 'vel = ' , vel
- print 'en = ' , en
- point = grass.read_command("v.out.ascii", input=start, format="standard")
- result = point.split("\n")
- coords = []
- for line in result:
- if re.findall(r'^.[0-9]+\.',line):
- coords.append(line.strip().split(" "))
- print coords
#creo raster (che sara' il DEM di input) con valore 1
grass.mapcalc('uno=$dem*0+1',
- dem = r_elevation)
+ dem = r_elevation)
+ what = grass.read_command('r.what', map=r_elevation, points=start)
+ quota = what.split('\n')
- # Calcolo cost (sostituire i punti di partenza in start_raster al pusto di punto)
- grass.run_command('r.cost' ,
- flags="k",
- input = 'uno',
- output = 'costo',
- start_points = start )
- #trasforma i valori di distanza celle in valori metrici utilizzando la risoluzione raster
- grass.mapcalc('costo_m=costo*(ewres()+nsres())/2')
- # calcola A=tangente angolo visuale (INPUT) * costo in metri
- grass.mapcalc('A=tan($ang)*costo_m',
- ang = ang)
- grass.mapcalc('C=$z-A',
- z = z)
- grass.mapcalc('D=C-$dem',
- # area di espansione
- grass.mapcalc('E=if(D>0,1,null())')
- # valore di deltaH (F)
- grass.mapcalc('F=D*E')
- # calcolo velocita
- grass.mapcalc('$vel=$red*sqrt(2*9.8*F)',
- vel = vel,
- red = red)
- # calcolo energia
- grass.mapcalc('$en=$m*9.8*F/1000',
- en = en,
- m = m)
+ #array per la somma dei massi
+ tot = garray.array()
+ tot.read(r_elevation)
+ tot[...] = (tot*0.0).astype(float)
+ somma = garray.array()
- for i in xrange(len(coords)):
- row = coords[i]
+ #array per le velocita
+ velocity = garray.array()
+ velMax = garray.array()
+ velMean = garray.array()
-#r.what map=DTM10_f211 at modulo_issa points=point at modulo_issa
+ #array per energia
+ energy = garray.array()
+ enMax = garray.array()
+ enMean = garray.array()
+ for i in xrange(len(quota)-1):
+ z = float(quota[i].split('||')[1])
+ point = quota[i].split('||')[0]
+ x = float(point.split('|')[0])
+ y = float(point.split('|')[1])
+ print x,y,z
+ # Calcolo cost (sostituire i punti di partenza in start_raster al pusto di punto)
+ grass.run_command('r.cost' ,
+ flags="k",
+ input = 'uno',
+ output = 'costo',
+ start_coordinates = str(x)+','+str(y),
+ overwrite = True )
+ #trasforma i valori di distanza celle in valori metrici utilizzando la risoluzione raster
+ grass.mapcalc('costo_m=costo*(ewres()+nsres())/2',
+ overwrite = True)
+ # calcola A=tangente angolo visuale (INPUT) * costo in metri
+ grass.mapcalc('A=tan($ang)*costo_m',
+ ang = ang,
+ overwrite = True)
+ grass.mapcalc('C=$z-A',
+ z = z,
+ overwrite = True)
+ grass.mapcalc('D=C-$dem',
+ dem = r_elevation,
+ overwrite = True)
+ # area di espansione
+ grass.mapcalc('E=if(D>0,1,null())',
+ overwrite = True)
+ # valore di deltaH (F)
+ grass.mapcalc('F=D*E',
+ overwrite = True)
+ #calcolo numero massi
+ grass.mapcalc('somma=if(vel>0,1,0)', overwrite = True)
+ somma.read('somma')
+ tot[...] = (somma + tot).astype(float)
+ # calcolo velocita
+ grass.mapcalc('vel = $red*sqrt(2*9.8*F)',
+ red = red, overwrite = True)
+ velocity.read('vel')
+ velMax[...] = (np.where(velocity>velMax,velocity,velMax)).astype(float)
+ velMean[...] = (velocity + velMean).astype(float)
+ # calcolo energia
+ grass.mapcalc('en=$m*9.8*F/1000',
+ m = m,
+ overwrite = True)
+ energy.read('en')
+ enMax[...] = (np.where(energy>enMax,energy,enMax)).astype(float)
+ enMean[...] = (energy + enMean).astype(float)
+ tot.write(rocks)
+ velMax.write(vMax)
+ velMean[...] = (velMean/i).astype(float)
+ velMean.write(vMean)
+ enMax.write(eMax)
+ enMean[...] = (enMean/i).astype(float)
+ enMean.write(eMean)
grass.run_command('g.remove' ,
rast=(
'uno',
@@ -180,7 +248,10 @@
'C',
'D',
'E',
- 'F'))
+ 'F',
+ 'en',
+ 'vel',
+ 'somma'))
if __name__ == "__main__":
options, flags = grass.parser()
