[GRASS-SVN] r62075 - grass/trunk/raster/r.topmodel
svn_grass at osgeo.org
Wed Sep 24 07:27:05 PDT 2014
Author: hcho
Date: 2014-09-24 07:27:05 -0700 (Wed, 24 Sep 2014)
New Revision: 62075
grass/trunk/raster/r.topmodel/r.topmodel.html
r.topmodel: Removed outdated info
Modified: grass/trunk/raster/r.topmodel/r.topmodel.html
--- grass/trunk/raster/r.topmodel/r.topmodel.html 2014-09-24 14:08:13 UTC (rev 62074)
+++ grass/trunk/raster/r.topmodel/r.topmodel.html 2014-09-24 14:27:05 UTC (rev 62075)
@@ -122,13 +122,9 @@
The <b>topidx</b> map can optionally be used for creating a new topographic
index statistics file. This map has to be already clipped to the catchment
boundary. The entire range of topographic index values will be divided into
-<b>ntopidxclasses</b> and the number of cells in each class will be reported in
-the <b>outtopidxstats</b> file using the following command:
-<div class="code"><pre>
-r.stats -Anc input=[topidx] output=[outtopidxstats] nsteps=[ntopidxclasses]
-</pre></div>
-These three parameters can be omitted unless a new topidxstats file needs to be
-created.
+<b>ntopidxclasses</b> and the area ratio of each class will be reported in the
+<b>outtopidxstats</b> file. These three parameters can be omitted unless a new
+topidxstats file needs to be created.
</dd>
</dl>
