[GRASS-SVN] r62087 - grass/trunk/general/g.remove
svn_grass at osgeo.org
Thu Sep 25 09:34:08 PDT 2014
Author: hcho
Date: 2014-09-25 09:34:08 -0700 (Thu, 25 Sep 2014)
New Revision: 62087
grass/trunk/general/g.remove/g.remove.html
grass/trunk/general/g.remove/main.c
g.remove: Add more examples in the manual; Clarify the description of pattern=
Modified: grass/trunk/general/g.remove/g.remove.html
--- grass/trunk/general/g.remove/g.remove.html 2014-09-25 15:31:40 UTC (rev 62086)
+++ grass/trunk/general/g.remove/g.remove.html 2014-09-25 16:34:08 UTC (rev 62087)
@@ -1,33 +1,34 @@
<h2>DESCRIPTION</h2>
<em>g.remove</em> removes data files matching a pattern given by wildcards or
-POSIX Extended Regular Expressions. If the <b>-f</b> force flag is not given
-then nothing is removed, instead the list of selected file names is printed to
-<tt>stdout</tt> as a preview of the files to be deleted.
+POSIX Extended Regular Expressions. The <b>pattern</b> option can also take a
+list of map names separated by a comma. If the <b>-f</b> force flag is not
+given then nothing is removed, instead the list of selected file names is
+printed to <tt>stdout</tt> as a preview of the files to be deleted.
<h2>EXAMPLES</h2>
-Delete all raster maps starting with "<tt>tmp_</tt>" in the current mapset:
+Delete <tt>map1</tt> and <tt>map2</tt> raster maps in the current mapset:
+<div class="code"><pre>
+g.remove -f type=rast pattern=tmp1,tmp2
+</pre></div>
+Delete all raster and vector maps starting with "<tt>tmp_</tt>" in the current
+mapset:
-# show matching raster maps but do not delete yet (as verification)
-g.remove type=rast pattern="tmp_*"
+# show matching raster and vector maps but do not delete yet (as verification)
+g.remove type=rast,vect pattern="tmp_*"
-# actually delete the matching raster maps
-g.remove -f type=rast pattern="tmp_*"
+# actually delete the matching raster and vector maps
+g.remove -f type=rast,vect pattern="tmp_*"
</pre></div>
-Delete all raster maps starting with "<tt>stream_</tt>" in the current mapset,
+Delete all vector maps starting with "<tt>stream_</tt>" in the current mapset,
but exclude those ending with "<tt>_final</tt>":
-g.remove -f type=rast pattern="stream_*" exclude="*_final"
+g.remove -f type=vect pattern="stream_*" exclude="*_final"
</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-</em>
<h2>AUTHOR</h2>
Huidae Cho<br>
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c 2014-09-25 15:31:40 UTC (rev 62086)
+++ grass/trunk/general/g.remove/main.c 2014-09-25 16:34:08 UTC (rev 62087)
@@ -78,7 +78,7 @@
opt.pattern->key = "pattern";
opt.pattern->type = TYPE_STRING;
opt.pattern->required = YES;
- opt.pattern->description = _("Map name search pattern");
+ opt.pattern->description = _("Map name search pattern or map names separated by a comma");
opt.pattern->guisection = _("Pattern");
opt.exclude = G_define_option();
