[GRASS-SVN] r62095 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Fri Sep 26 08:27:55 PDT 2014
Author: martinl
Date: 2014-09-26 08:27:55 -0700 (Fri, 26 Sep 2014)
New Revision: 62095
grass/trunk/vector/v.select/copy_tabs.c
fix r62093: close DB driver on failure (db_set_error_handler_driver)
fix indentation
Modified: grass/trunk/vector/v.select/copy_tabs.c
--- grass/trunk/vector/v.select/copy_tabs.c 2014-09-26 14:04:35 UTC (rev 62094)
+++ grass/trunk/vector/v.select/copy_tabs.c 2014-09-26 15:27:55 UTC (rev 62095)
@@ -11,7 +11,6 @@
int i, ttype, ntabs;
struct field_info *IFi, *OFi;
- dbDriver *Driver;
ntabs = 0;
@@ -40,6 +39,8 @@
for (i = 0; i < nfields; i++) {
int ret;
+ dbDriver *Driver;
if (fields[i] == 0)
continue;
@@ -68,18 +69,21 @@
Vect_map_add_dblink(Out, OFi->number, OFi->name, OFi->table,
IFi->key, OFi->database, OFi->driver);
- Driver = db_start_driver_open_database(OFi->driver,
- Vect_subst_var(OFi->database, Out));
- if (Driver == NULL)
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- OFi->database, OFi->driver);
- if (db_create_index2(Driver, OFi->table, OFi->key) != DB_OK)
- G_warning(_("Unable to create index"));
- if (db_grant_on_table
+ /* create index on key column */
+ Driver = db_start_driver_open_database(OFi->driver,
+ Vect_subst_var(OFi->database, Out));
+ if (Driver == NULL)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ OFi->database, OFi->driver);
+ db_set_error_handler_driver(Driver);
+ if (db_create_index2(Driver, OFi->table, OFi->key) != DB_OK)
+ G_warning(_("Unable to create index"));
+ if (db_grant_on_table
(Driver, OFi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
- G_fatal_error(_("Unable to grant privileges on table <%s>"),
- OFi->table);
+ G_fatal_error(_("Unable to grant privileges on table <%s>"),
+ OFi->table);
db_close_database_shutdown_driver(Driver);
