[GRASS-SVN] r62107 - grass/branches/releasebranch_6_4/mswindows
svn_grass at osgeo.org
Sat Sep 27 01:03:44 PDT 2014
Author: hellik
Date: 2014-09-27 01:03:44 -0700 (Sat, 27 Sep 2014)
New Revision: 62107
grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl
nsis: fix installing MS runtimes
Modified: grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl 2014-09-27 07:57:05 UTC (rev 62106)
+++ grass/branches/releasebranch_6_4/mswindows/GRASS-Installer.nsi.tmpl 2014-09-27 08:03:44 UTC (rev 62107)
@@ -918,17 +918,6 @@
Pop $0
StrCmp $0 "success" untar_ok untar_failed
- untar_ok:
- ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe" /q'
- ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe" /q'
- ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe" /q'
- CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTALL_DIR\extrabin"
- Delete "$TEMP\$ARCHIVE_NAME"
- RMDir /r "$TEMP\$ORIGINAL_UNTAR_FOLDER"
- ;the following doesn't work. Maybe because the installer is still running?
- RMDir "$TEMP\$ORIGINAL_UNTAR_FOLDER"
- Goto end
download_failed:
DetailPrint "$0" ;print error message to log
MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME."
@@ -940,6 +929,19 @@
untar_failed:
+ untar_ok:
+ DetailPrint "Archive successfully unzipped."
+ DetailPrint "Installing vcredist_2005_x86.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe" /q'
+ DetailPrint "Installing vcredist_2008_x86.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe" /q'
+ DetailPrint "Installing vcredist_2010_x86.exe ..."
+ ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe" /q'
+ DetailPrint "Copying runtime files ..."
+ CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTALL_DIR\extrabin"
+ DetailPrint "MS runtime files installed."
+ Goto end
end:
@@ -1050,7 +1052,18 @@
SectionEnd
+;Clean downloaded MS runtime files by .onInstSuccess
+Function .onInstSuccess
+ ${If} ${SectionIsSelected} ${SecMSRuntime}
+ Delete "$TEMP\$ARCHIVE_NAME"
+ RMDir /r "$TEMP\$ORIGINAL_UNTAR_FOLDER"
+ RMDir "$TEMP\$ORIGINAL_UNTAR_FOLDER"
+ ${EndIf}
+FunctionEnd
;Uninstaller Section
Section "Uninstall"
