[GRASS-SVN] r62111 - grass/trunk/lib/python/docs/src
Sat Sep 27 09:54:16 PDT 2014
Author: huhabla
Date: 2014-09-27 09:54:16 -0700 (Sat, 27 Sep 2014)
New Revision: 62111
Added:
   grass/trunk/lib/python/docs/src/temporal.rst
Added sphinx documentation for the temporal framework
Added: grass/trunk/lib/python/docs/src/temporal.rst
--- grass/trunk/lib/python/docs/src/temporal.rst	                        (rev 0)
+++ grass/trunk/lib/python/docs/src/temporal.rst	2014-09-27 16:54:16 UTC (rev 62111)
@@ -0,0 +1,371 @@
+The GRASS GIS Temporal Framework
+Introduction
+The GRASS GIS Temporal Framework implements the temporal GIS functionality of GRASS GIS
+and provides an API to implement spatio-temporal processing modules. The framework
+introduces space time datasets that represent time series of raster, 3D raster or vector maps.
+This framework provides the following functionalities:
+- Assign time stamp to maps and register maps in the temporal database
+- Modification of time stamps
+- Creation, renaming and deletion of space time datasets
+- Registration and un-registration of maps in space time datasets
+- Query of maps that are registered in space time datasets using SQL where statements
+- Analysis of the spatio-temporal topology of space time datasets
+- Sampling of space time datasets
+- Computation of temporal and spatial relationships between registered maps
+- Higher level functions that are shared between modules
+Most of the functions described above are member functions of dedicated map layer and space time dataset classes.
+Temporal API
+The temporal framework API consists of several dedicated modules. Each module contains one or several classes
+as well as function definition. The API can be roughly divided in a low level and high level part. However, several
+functions from the low level module are used in module implementation as well.
+Low level API
+The low level API implements the core functionality on which the high level API is based on.
+**python::temporal::core**
+    The core functionality of the temporal framework:
+    - Initialization function :func:`init()`
+    - Definition of global variables
+    - Several global functions to access TGIS specific variables
+    - Interfaces to the TGIS C-library and PyGRASS messenger objects
+    - Database interface connection class :class:`~temporal.core.SQLDatabaseInterfaceConnection` to sqlite3 and postgresql
+      database backends
+    - Functions to create the temporal database
+**python::temporal::base**
+    Implements of basic dataset informations and SQL conversion of such information:
+    - Definition of the SQL serialize class :class:`~temporal.base.DictSQLSerializer` that converts the content of temporal
+      classes into SQL SELECT, INSERT or UPDATE statements
+    - Definition of :class:`~temporal.base.SQLDatabaseInterface` that is the base class for all temporal datatype subclasses
+    - Contains classes for all datasets [#allds]_ that contain
+      basic informations (id, name, mapset, creator, ...)
+**python::temporal::spatial_extent**
+    Implements of 2d and 3d spatial extents of all datasets:
+    - Implements class :class:`~temporal.spatial_extent.SpatialExtent` that is the base class for all dataset specific spatial extent classes
+      It provides spatial topological logic and operations for 2D and 3D extents
+    - Implements spatial extent classes for all datasets [#allds]_
+**python::temporal::temporal_extent**
+    Implements of the temporal extent of all datasets for relative and absolute time:
+    - Implements class :class:`~temporal.temporal_extent.TemporalExtent` that is the base class for all dataset specific temporal extent classes
+      It provides temporal topological logic and operations
+    - Implements temporal extent classes for relative time and absolute time for
+      all datasets [#allds]_
+**python::temporal::metadata**
+    Implements the metadata base classes and datatype specific derivatives fpr all datasets [#allds]_.
+**python::temporal::spatial_topology_dataset_connector**
+    Implements the interface to link datasets by spatial topological relations
+**python::temporal::temporal_topology_dataset_connector**
+    Implements the interface to link datasets by temporal topological relations
+**python::temporal::c_libraries_interface**
+    The RPC C-library interface for exit safe and fast access to raster, vector and 3D raster informations.
+**python::temporal::temporal_granularity**
+    The computation of the temporal granularity for a list
+    of :class:`~temporal.abstract_dataset.AbstractDataset` objects for absolute and relative is implemented here.
+**python::temporal::datetime_math**
+    This module contains function to parse, convert and process datetime objects
+    in the temporal framework.
+Spatio-temporal algebra classes for space time raster and vector datasets are defined in:
+- **python::temporal::temporal_algebra**
+- **python::temporal::temporal_vector_algebra**
+- **python::temporal::temporal_vector_operator**
+High level API
+The high level API utilizes the low level API
+**python::temporal::abstract_dataset**
+    - Implements the base class for all datasets [#allds]_ :class:`~temporal.abstract_dataset.AbstractDataset`.
+    - Implements the the select, insert and update functionality as well as
+      convenient functions to access the base, extent and metadata informations
+**python::temporal::abstract_map_dataset**
+    - Implements the base class :class:`~temporal.abstract_map_dataset.AbstractMapDataset` for all map layer specific classes
+    - Provides the interface to all map layer specific informations in the temporal database
+**python::temporal::abstract_space_time_dataset**
+    - Implements the base class :class:`~temporal.abstract_space_time_dataset.AbstractSpaceTimeDataset` for all Space Time Datasets classes
+    - Contains the creation and deletion functionality, the map registration and un-registration,
+      access methods to map layer objects and so on
+    - Provides the interface to all Space Time Dataset specific informations in the temporal database
+**python::temporal::space_time_datasets**
+    This module contains all classes that represent specific datasets [#allds]_. A module developer uses these
+    map layer and Space Time Dataset object representations to perform spatio-temporal tasks.
+**python::temporal::spatio_temporal_relationships**
+    The logic to compute spatio-temporal topology for a single list or two lists of :class:`~temporal.abstract_dataset.AbstractDataset` objects
+    is implemented in this module.
+    The class :class:`~temporal.spatio_temporal_relationships.SpatioTemporalTopologyBuilder` provides a convenient
+    interface for topology computation.
+**python::temporal::gui_support**
+    Helper functions to support the listing of space time datasets in the automatically generated GUI.
+Temporal Framework Testsuite
+All temporal framework specific unittests and doctests are located here:
+- **python::temporal::testsuite**
+Shared Module functionality
+Functionality that is shared between different temporal GRASS modules, such as
+map listing, space time dataset creation, map registration and unregistration,
+aggregation, extraction, map calculation, statistics as well as import and export of
+space time datasets are defined here:
+**python::temporal::aggregation**
+    Aggregation of Space Time Raster Datasets based on topological relations.
+    Used in *t.rast.aggregate* and *t.rast.aggregate.ds*
+**python::temporal::extract**
+    Extraction of subsets from Space Time Datasets including map algebra and vector selection statements.
+    Used in *t.rast.extract*, *t.rast3d.extract* and *t.vect.extract*.
+**python::temporal::factory**
+    Factory functions to create datasets of all types [#allds]_.
+**python::temporal::open_stds**
+    Convenient functions to open existing Space Time Datasets or to create new ones. Used in almost all temporal modules.
+**python::temporal::list_stds**
+    Convenient functions to list datasets of all types [#allds]_ registered in the temporal database.
+**python::temporal::mapcalc**
+    Simple temporal algebra for Scpae Time Raster and 3d Raster datasets. Used in *t.rast.mapcalc* and *t.rast3d.mapcalc*
+**python::temporal::register**
+    Convenient functions to register a single or multiple map layer in the temporal database and
+    SpaceTime Datasets. Used in several modules, most important *t.register*.
+**python::temporal::sampling**
+    Sampling functions used in several modules.
+**python::temporal::stds_export**
+    Functions to export of Space Time Datasets, used in *t.rast.export*, *t.rast3d.export* and *t.vect.export*.
+**python::temporal::stds_import**
+    Functions to import Space Time Datasets, used in *t.rast.import*, *t.rast3d.import* and *t.vect.import*.
+**python::temporal::univar_statistics**
+    Simple statistical analysis functions for Space Time Datasets, used in *t.rast.univar*, *t.rast3d.univar*
+    and *t.vect.univar*.
+.. [#allds] : Raster Map Layer, 3d Raster Map Layer, Vector Map Layer, Space time Raster Datasets (STRDS),
+              Space Time 3d Raster Datasets (STR3DS) and Space Time Vector Datasets (STVDS)
+Examples
+Howto start example
+This simple example shows how to open a space time raster dataset
+to access its registered maps.
+.. code-block:: python
+    # Lets import the temporal framework and
+    # the script framework
+    import grass.temporal as tgis
+    import grass.script as grass
+    # Make sure the temporal database exists
+    # and set the temporal GIS environment
+    tgis.init()
+    # We create the temporal database interface for fast processing
+    dbif = tgis.SQLDatabaseInterfaceConnection()
+    dbif.connect()
+    # The id of a space time raster dataset is build from its name and its mapset
+    id = "test at PERMANENT"
+    # We create a space time raster dataset object
+    strds = tgis.SpaceTimeRasterDataset(id)
+    # Check if the space time raster dataset is in the temporal database
+    if strds.is_in_db(dbif=dbif) == False:
+        dbif.close()
+        grass.fatal(_("Space time %s dataset <%s> not found") % (
+            strds.get_new_map_instance(None).get_type(), id))
+    # Fill the object with the content from the temporal database
+    strds.select(dbif=dbif)
+    # Print informations about the space time raster dataset to stdout
+    strds.print_info()
+    # Get all maps that are registered in the strds and print
+    # informations about the maps to stdout
+    maps = strds.get_registered_maps_as_objects(dbif=dbif)
+    # We iterate over the temporal sorted map list
+    for map in maps:
+        # We fill the map object with the content
+        # from the temporal database. We use the existing
+        # database connection, otherwise a new connection
+        # will be established for each map object
+        # which slows the processing down
+        map.select(dbif=dbif)
+        map.print_info()
+    # Close the database connection
+    dbif.close()
+Creation of a space time dataset
+This example shows howto create a space time dataset. The code is generic and works
+for different space time datasets (raster, 3D raster and vector):
+    # The id of the new space time dataset
+    id="test at PERMANENT"
+    # The title of the new space time dataset
+    title="This is a test dataset"
+    # The description of the space time dataset
+    description="The description"
+    # The type of the space time dataset (strds, str3ds or stvds)
+    type="strds"
+    # The temporal type of the space time dataset (absolute or relative)
+    temporal_type="absolute"
+    tgis.init()
+    # We use the dataset factory to create an new space time dataset instance of a specific type
+    stds = tgis.dataset_factory(type, id)
+    # We need a dtabase connection to insert the content of the space time dataset
+    dbif.connect()
+    # First we check if the dataset is already in the database
+    if stds.is_in_db(dbif=dbif) and overwrite == False:
+        dbif.close()
+        grass.fatal(_("Space time %s dataset <%s> is already in the database. "
+                        "Use the overwrite flag.") %
+                    (stds.get_new_map_instance(None).get_type(), name))
+    # We delete the exiting dataset and create a new one in case we are allowed to overwrite it
+    if stds.is_in_db(dbif=dbif) and overwrite == True:
+        grass.warning(_("Overwrite space time %s dataset <%s> "
+                        "and unregister all maps.") %
+        stds.delete(dbif=dbif)
+        stds = stds.get_new_instance(id)
+    # We set the initial values. This function also created the command history.
+    stds.set_initial_values(temporal_type=temporaltype, semantic_type="mean",
+                            title=title, description=description)
+    # Now we can insert the new space time dataset in the database
+    stds.insert(dbif=dbif)
+    dbif.close()
+Temporal shifting
+    type="strds"
+    tgis.init()
+    dbif.connect()
+    if stds.is_in_db(dbif) == False:
+        dbif.close()
+        grass.fatal(_("Space time dataset <%s> not found in temporal database") % (id))
+    stds.select(dbif=dbif)
+    stds.snap(dbif=dbif)
+    stds.update_command_string(dbif=dbif)
+    dbif.close()
+:Authors: Soeren Gebbert
+:TODO: add more documentation
