[GRASS-SVN] r62135 - grass/trunk/lib/python/pygrass/vector/testsuite
svn_grass at osgeo.org
Tue Sep 30 01:48:22 PDT 2014
Author: zarch
Date: 2014-09-30 01:48:22 -0700 (Tue, 30 Sep 2014)
New Revision: 62135
Added:
grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py
pygrass: Add test on __getitem__ method in VectorTopo class
Added: grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py (rev 0)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py 2014-09-30 08:48:22 UTC (rev 62135)
@@ -0,0 +1,35 @@
+# -*- coding: utf-8 -*-
+Created on Wed Jun 18 17:21:42 2014
+ at author: pietro
+from grass.gunittest import TestCase, test
+from grass.pygrass.vector import VectorTopo
+class VectorTopoTestCase(TestCase):
+ vname = "points_of_interest"
+ def test_getitem_slice(self):
+ """Test that getitem handle correctly the slice starting from 1"""
+ vcoords = ((646341.7386813264, 218873.73056803632),
+ (637772.0990144431, 218842.80557760992))
+ with VectorTopo(self.vname, mode="r") as vect:
+ coords = tuple([pnt.coords() for pnt in vect[:3]])
+ self.assertTupleEqual(vcoords, coords)
+ coords = tuple([pnt.coords() for pnt in vect[1:3]])
+ def test_getitem_raise(self):
+ """Test that getitem raise a value error if the key is not
+ an integer or a slice"""
+ with self.assertRaises(ValueError):
+ vect['value']
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/lib/python/pygrass/vector/testsuite/test_vector.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
