[GRASS-SVN] r64971 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Wed Apr 1 05:38:35 PDT 2015
Author: zarch
Date: 2015-04-01 05:38:35 -0700 (Wed, 01 Apr 2015)
New Revision: 64971
grass/trunk/lib/python/pygrass/modules/interface/parameter.py
Fix undefined limits in the Parameter class
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2015-04-01 11:23:17 UTC (rev 64970)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2015-04-01 12:38:35 UTC (rev 64971)
@@ -138,11 +138,12 @@
if 'values' in diz:
try:
# Check for integer ranges: "3-30" or float ranges: "0.0-1.0"
- isrange = re.match("(?P<min>-*\d+.*\d*)-(?P<max>\d+.*\d*)",
+ isrange = re.match("(?P<min>-*\d+.*\d*)*-(?P<max>\d+.*\d*)*",
diz['values'][0])
if isrange:
mn, mx = isrange.groups()
- self.min, self.max = float(mn), float(mx)
+ self.min = None if mn is None else float(mn)
+ self.max = None if mx is None else float(mx)
self.values = None
self.isrange = diz['values'][0]
# No range was found
