[GRASS-SVN] r64978 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Wed Apr 1 12:16:40 PDT 2015
Author: krejcmat
Date: 2015-04-01 12:16:40 -0700 (Wed, 01 Apr 2015)
New Revision: 64978
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
db connect
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-04-01 18:33:49 UTC (rev 64977)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-04-01 19:16:40 UTC (rev 64978)
@@ -1327,9 +1327,9 @@
self.pyConnection()
#if self.host:
- # self.grassConnectionRemote()
+ self.grassConnectionRemote()
#else:
- self.grassConnection()
+ #self.grassConnection()
self.grassTemporalConnection('postgres')
#self.firstPreparation()
#self.prepareDB()
@@ -1367,70 +1367,34 @@
grass.run_command('t.connect',
flags='d')
- def grassConnection(self):
+ def grassConnectionRemote(self):
conninfo = 'dbname=' + self.dbName
if self.host:
- conninfo += ',host=' + self.host
+ conninfo += ' host=' + self.host
if self.port:
- conninfo += ',port=' + str(self.port)
- #conninfo+='"'
- print '*' * 50
- print conninfo
- print self.user
- print self.password
- print '*' * 50
- if self.user or self.password:
- if grass.run_command('db.login',
- driver="pg",
- database=self.dbName,
- user=self.user,
- password=self.password) != 0:
- grass.warning("Cannot login")
- return False
- # Try to connect
- if grass.run_command('db.select',
- quiet=True,
- flags='c',
- driver="pg",
- database=conninfo,
- sql="select version()") != 0:
- grass.warning("Cannot connect to database.")
- return False
- if grass.run_command('db.connect', driver="pg", database=conninfo) != 0:
- grass.fatal("Unable to connect to the database by grass driver.")
- if grass.run_command('db.connect', driver="pg", database=self.dbName) != 0:
- return False
- def grassConnectionRemote(self):
- conninfo = 'dbname= ' + self.dbName
- if self.host:
- if self.port:
+ conninfo += ' port=' + str(self.port)
self.dbConnStr=conninfo
# Unfortunately we cannot test untill user/password is set
+ if self.user and not self.password:
driver="pg",
+ database=conninfo,
user=self.user,
+ password='')
+ elif self.user and self.password:
+ grass.run_command('db.login',
+ driver="pg",
+ user=self.user,
+ password=self.password)
else:
- quiet=True,
- driver="pg",
- user="", password="")
+ driver="pg",
+ user='',
+ password='')
