[GRASS-SVN] r64984 - in grass-addons/grass7/vector: . v.vol.idw
svn_grass at osgeo.org
Sat Apr 4 07:47:14 PDT 2015
Author: jnoortheen
Date: 2015-04-04 07:47:14 -0700 (Sat, 04 Apr 2015)
New Revision: 64984
Added:
grass-addons/grass7/vector/v.vol.idw/
grass-addons/grass7/vector/v.vol.idw/Makefile
grass-addons/grass7/vector/v.vol.idw/main.c
grass-addons/grass7/vector/v.vol.idw/v.vol.idw.html
Added the v.vol.idw to the svn server
Added: grass-addons/grass7/vector/v.vol.idw/Makefile
--- grass-addons/grass7/vector/v.vol.idw/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.vol.idw/Makefile 2015-04-04 14:47:14 UTC (rev 64984)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = v.vol.idw
+LIBES = $(VECTORLIB) $(RASTER3DLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(VECTORDEP) $(RASTER3DDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
\ No newline at end of file
Added: grass-addons/grass7/vector/v.vol.idw/main.c
--- grass-addons/grass7/vector/v.vol.idw/main.c (rev 0)
+++ grass-addons/grass7/vector/v.vol.idw/main.c 2015-04-04 14:47:14 UTC (rev 64984)
@@ -0,0 +1,302 @@
+ * MODULE: v.to.rast3
+ * AUTHOR(S): Original s.to.rast3: Jaro Hofierka, Geomodel s.r.o. (original contributor)
+ * 9/2005 Upgrade to GRASS 6 by Radim Blazek
+ * Soeren Gebbert <soeren.gebbert gmx.de>
+ * OGR support by Martin Landa <landa.martin gmail.com>
+ * PURPOSE: Converts vector points to 3D raster
+ * COPYRIGHT: (C) 1999-2010 by the GRASS Development Team
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/raster3d.h>
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+int npts = 0, npoints_alloc = 0, search_points = 12, nsearch;
+void newpoint(double, double, double, double );
+struct Point
+ double w, z, east, north;
+ double dist;
+struct Point *points = NULL;
+struct Point *list;
+int main(int argc, char *argv[])
+ struct GModule *module;
+ struct Option *input, *output, *field, *column, *npoints;
+ int nfield;
+ RASTER3D_Region region;
+ struct Map_info InMap; /*input map*/
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ RASTER3D_Map *map3d = NULL;
+ float *data, value;
+ int lev, col, row, Nc, Nr, Nl, sz, i, n, max, cnt, current_row, current_depth;
+ double x, y, z, w, lev_res, dx, dy, dz, dist, maxdist, sum1, sum2;
+ int nrec, ctype, cat;
+ struct field_info *Fi;
+ dbDriver *Driver;
+ dbCatValArray cvarr;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("vector"));
+ G_add_keyword(_("Volume"));
+ G_add_keyword(_("voxel"));
+ G_add_keyword(_("interpolation"));
+ G_add_keyword(_("IDW"));
+ module->description =
+ _("Interpolates point data to a 3D raster map using "
+ "Inverse Distance Weighting (IDW) algorithm.");
+ input = G_define_standard_option(G_OPT_V_INPUT);
+ input->required = YES;
+ input->label = _("Name of input 3D vector points map");
+ input->description = NULL;
+ field = G_define_standard_option(G_OPT_V_FIELD);
+ field->required = NO;
+ field->label = _("Number of vector layer field attribute to use for calculation");
+ field->description = NULL;
+ output = G_define_standard_option(G_OPT_R3_OUTPUT);
+ output->key = "output";
+ output->required = YES;
+ output->description = _("Name for output 3D raster map");
+ column = G_define_standard_option(G_OPT_DB_COLUMN);
+ column->required = YES;
+ column->description = _("Name of attribute column (data type must be numeric)");
+ npoints = G_define_option() ;
+ npoints->key = "npoints" ;
+ npoints->key_desc = "count" ;
+ npoints->type = TYPE_INTEGER ;
+ npoints->required = YES ;
+ npoints->description="Number of interpolation points";
+ npoints->answer = "12";
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ if (G_legal_filename(output->answer) < 0)
+ G_fatal_error(_("%s=%s - illegal name\n"), output->key, output->answer);
+ if(sscanf(npoints->answer,"%d", &search_points) != 1 || search_points<1){
+ G_usage();
+ G_fatal_error(_("Illegal number (%s) of interpolation points"), npoints->answer);}
+ list = (struct Point *) G_calloc (search_points, sizeof (struct Point));
+ Vect_set_open_level(1);
+ if (Vect_open_old2(&InMap, input->answer, "", field->answer) < 0)
+ G_fatal_error(_("Unable to open vector map <%s>"), input->answer);
+ if (!Vect_is_3d(&InMap))
+ G_fatal_error(_("Vector is not 3D"));
+ nfield = Vect_get_field_number(&InMap, field->answer); /*layer number; mostly one*/
+ db_CatValArray_init(&cvarr);
+ Fi = Vect_get_field(&InMap, nfield); /*The particular level of layer*/
+ if (Fi == NULL)
+ G_fatal_error(_("Database connection not defined for layer <%s>"), field->answer);
+ Driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (Driver == NULL)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"), Fi->database, Fi->driver);
+ db_set_error_handler_driver(Driver);
+ /* Note: do not check if the column exists in the table because it may be expression */
+ nrec = db_select_CatValArray(Driver, Fi->table, Fi->key, column->answer, NULL, &cvarr);/*Number of selected records*/
+ G_debug(2, "nrec = %d", nrec);
+ if (nrec < 0)
+ G_fatal_error(_("Unable to select data from table"));
+ ctype = cvarr.ctype;
+ if (ctype == -1)
+ G_fatal_error(_("Cannot read column type of smooth column"));
+ if (ctype == DB_C_TYPE_DATETIME)
+ G_fatal_error
+ (_("Column type of smooth column (datetime) is not supported"));
+ if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_("Column type not supported"));
+ db_close_database_shutdown_driver(Driver);
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ Vect_rewind(&InMap);
+ while(1)
+ int ival, type, ret;
+ if (-1 == (type = Vect_read_next_line(&InMap, Points, Cats)))
+ G_fatal_error(_("Unable to read vector map"));
+ if (type == -2)
+ break; /* EOF */
+ if (!(type & GV_POINTS))
+ continue;
+ Vect_cat_get(Cats, 1, &cat);
+ if (cat < 0)
+ G_warning(_("Point without category"));
+ continue;
+ x = Points->x[0];
+ y = Points->y[0];
+ z = Points->z[0];
+ if (ctype == DB_C_TYPE_INT){
+ ret = db_CatValArray_get_value_int(&cvarr, cat, &ival);
+ w = ival;}
+ else
+ {ret = db_CatValArray_get_value_double(&cvarr, cat, &w);}/*ret will be 0 if completed successfully*/
+ newpoint(w, z, x, y);/*adding the each point to the points array*/
+ Vect_close(&InMap);
+ /*Terminate if the vector map is empty*/
+ if (npts == 0)
+ G_fatal_error(_("%s: no data points found\n"), argv[0]);
+ Rast3d_get_window(®ion);
+ Rast3d_read_window(®ion, NULL);
+ fprintf(stderr,"Region from getWindow: %d %d %d\n", region.rows, region.cols, region.depths);
+ map3d = Rast3d_open_new_opt_tile_size(output->answer, RASTER3D_USE_CACHE_DEFAULT, ®ion, FCELL_TYPE, 32);
+ if (map3d == NULL)
+ G_fatal_error(_("Unable to create output map"));
+ /*output 3d raster variables declaration*/
+ Nc = region.cols;
+ Nr = region.rows;
+ Nl = region.depths;
+ lev_res = region.tb_res;
+ sz = Nr * Nc * Nl;
+ /*start the interpolation*/
+ data = (float *) malloc( sz * sizeof(float) );
+ if (!data)
+ G_fatal_error(_("Error: out of memory\n"));
+ nsearch = npts < search_points ? npts : search_points; /*nsearch will get the value one of the minimum */
+ fprintf (stderr, "Interpolating raster map <%s> ... %d levels ... ", output->answer, Nl);
+ cnt=0;
+ z = region.top + lev_res/2.0;
+ for (lev = 0; lev < Nl; lev++)
+ z -=lev_res;
+ y = region.north + region.ns_res/2.0;
+ for (row = 0; row < Nr; row++)
+ G_percent (row, Nr, 2);
+ y -= region.ns_res;
+ x = region.west - region.ew_res/2.0;
+ for (col = 0; col < Nc; col++)
+ x += region.ew_res;
+ /*Filling the list upto nsearch*/
+ for (i = 0; i < nsearch ; i++)
+ dy = points[i].north - y;
+ dx = points[i].east - x;
+ dz = points[i].z - z;
+ list[i].dist = dy*dy + dx*dx + dz*dz;
+ list[i].w = points[i].w;
+ /* find the maximum distance */
+ maxdist = list[max=0].dist;
+ for (n = 1; n < nsearch; n++)
+ if (maxdist < list[n].dist)
+ maxdist = list[max=n].dist;
+ /* go thru rest of the points now */
+ for ( ; i < npts; i++)
+ dist = dy*dy + dx*dx + dz*dz;
+ if (dist < maxdist)
+ /* replace the largest dist */
+ list[max].w = points[i].w;
+ list[max].dist = dist;
+ /* interpolate */
+ sum1 = 0.0;
+ sum2 = 0.0;
+ for (n = 0; n < nsearch; n++)
+ if(dist = list[n].dist)
+ sum1 += list[n].w / dist;
+ sum2 += 1.0/dist;
+ else
+ sum1 = list[n].w;
+ sum2 = 1.0;
+ break;
+ data[cnt] = (sum1/sum2);
+ value = data[cnt];
+ cnt++;
+ Rast3d_put_float (map3d, col, row, lev, value);
+ }/*cols*/
+ }/*rows*/
+ }/*levels*/
+ free(data);
+ if (!Rast3d_close(map3d))
+ G_fatal_error(_("Unable to close new 3d raster map"));
+ fprintf (stderr, "Done\n");
+ exit(EXIT_SUCCESS);
+void newpoint(double w, double z, double east,double north)
+ if (npoints_alloc <= npts)
+ npoints_alloc += 128;
+ points = (struct Point *) G_realloc (points, npoints_alloc * sizeof (struct Point));
+ points[npts].north = north;
+ points[npts].east = east;
+ points[npts].z = z;
+ points[npts].w = w;
+ npts++;
Added: grass-addons/grass7/vector/v.vol.idw/v.vol.idw.html
--- grass-addons/grass7/vector/v.vol.idw/v.vol.idw.html (rev 0)
+++ grass-addons/grass7/vector/v.vol.idw/v.vol.idw.html 2015-04-04 14:47:14 UTC (rev 64984)
@@ -0,0 +1,45 @@
+<h2>DESCRIPTION</h2>
+<em>v.vol.idw</em>fills a RASTER3D raster volume matrix with
+interpolated values generated from a set of irregularly spaced data
+points using numerical approximation (weighted averaging)
+techniques. The interpolated value of a tile is determined
+by values of nearby data points and the distance of the
+cell from those input points. In comparison with other
+methods, numerical approximation allows representation of
+more complex volumes (particularly those with anomalous
+features), restricts the spatial influence of any errors,
+and generates the interpolated volume from the data
+points.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+v.vol.idw input=map output=rastermap3d column=col_name npoints=36
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="v.in.ascii.html">v.in.ascii</a>,
+<a href="v.in.db.html">v.in.db</a>,
+<a href="v.surf.idw.html">v.surf.idw</a>,
+<a href="v.vol.rst.html">v.vol.rst</a>,
+<a href="v.to.rast3.html">v.to.rast3</a>
+</em>
+<h2>AUTHOR</h2>
+Jaro Hofierka, Department of Geography and Regional Development,
+University of Presov, Presov, Slovakia,
+<a href="mailto:hofierka at geomodel.sk">hofierka at geomodel.sk</a>
+<br>
+<p>
+ Modifications for raster3d library and vector format: <br>
+ Noortheen Raja J, Institute of Remote Sensing,College of Engineering, Guindy,
+ Anna University, India.
+ <a href="mailto:jnoortheen at gmail.com">jnoortheen at gmail.com</a>
+<p><i>Last changed: $Date: 2015-03-28 09:56:09 -0700 (Sat, 28 Mar 2015) $</i>
