[GRASS-SVN] r64986 - in grass-addons: grass6/vector grass6/vector/v.tin.to.rast grass7/vector grass7/vector/v.tin.to.rast
Sun Apr 5 13:01:17 PDT 2015
Author: amuriy
Date: 2015-04-05 13:01:17 -0700 (Sun, 05 Apr 2015)
New Revision: 64986
Added:
   grass-addons/grass6/vector/v.tin.to.rast/
   grass-addons/grass6/vector/v.tin.to.rast/Makefile
   grass-addons/grass6/vector/v.tin.to.rast/description.html
   grass-addons/grass6/vector/v.tin.to.rast/v.tin.to.rast.py
   grass-addons/grass7/vector/v.tin.to.rast/
   grass-addons/grass7/vector/v.tin.to.rast/Makefile
   grass-addons/grass7/vector/v.tin.to.rast/description.html
   grass-addons/grass7/vector/v.tin.to.rast/v.tin.to.rast.py
v.tin.to.rast added for grass6 and grass7
Added: grass-addons/grass6/vector/v.tin.to.rast/Makefile
--- grass-addons/grass6/vector/v.tin.to.rast/Makefile	                        (rev 0)
+++ grass-addons/grass6/vector/v.tin.to.rast/Makefile	2015-04-05 20:01:17 UTC (rev 64986)
@@ -0,0 +1,15 @@
+# Uncoment and fix MODULE_TOPDIR line OR provide MODULE_TOPDIR variable for make
+# fix this relative to include/
+# or use absolute path to the GRASS source code
+# MODULE_TOPDIR = ../../..
+PGM = v.tin.to.rast
+LIBES = $(VECTLIB) $(GISLIB)
+DEPENDENCIES= $(VECTDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass6/vector/v.tin.to.rast/description.html
--- grass-addons/grass6/vector/v.tin.to.rast/description.html	                        (rev 0)
+++ grass-addons/grass6/vector/v.tin.to.rast/description.html	2015-04-05 20:01:17 UTC (rev 64986)
@@ -0,0 +1,41 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>GRASS GIS manual: v.tin.to.rast</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
+<h2>NAME</h2>
+<em><b>v.tin.to.rast</b></em>  - Converts (rasterize) a TIN map into a raster map
+<h2>KEYWORDS</h2>
+TIN, vector, raster, conversion
+<h2>SYNOPSIS</h2>
+<b>v.tin.to.rast</b><br>
+<b>v.tin.to.rast help</b><br>
+<b>v.tin.to.rast</b> <b>input</b>=<em>tin</em> <b>output</b>=<em>raster</em>  [--<b>overwrite</b>]  [--<b>verbose</b>]  [--<b>quiet</b>]
+<h3>Flags:</h3>
+<DL>
+<DT><b>--overwrite</b></DT>
+<DD>Allow output files to overwrite existing files</DD>
+<DT><b>--verbose</b></DT>
+<DD>Verbose module output</DD>
+<DT><b>--quiet</b></DT>
+<DD>Quiet module output</DD>
+</DL>
+<h3>Parameters:</h3>
+<DL>
+<DT><b>input</b>=<em>tin</em></DT>
+<DD>Name of input TIN map</DD>
+<DT><b>output</b>=<em>raster</em></DT>
+<DD>Name of output raster map</DD>
+</DL>
+</body>
+</html>
Added: grass-addons/grass6/vector/v.tin.to.rast/v.tin.to.rast.py
--- grass-addons/grass6/vector/v.tin.to.rast/v.tin.to.rast.py	                        (rev 0)
+++ grass-addons/grass6/vector/v.tin.to.rast/v.tin.to.rast.py	2015-04-05 20:01:17 UTC (rev 64986)
@@ -0,0 +1,194 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:     v.tin.to.rast
+# AUTHOR(S):  Antonio Alliegro Civil Engineer
+#             Salerno, Italy
+#             antonioall(at)libero.it
+#             Alexander Muriy
+#             (Institute of Environmental Geoscience, Moscow, Russia)
+#             amuriy(at)gmail.com
+# PURPOSE:    Converts (rasterize) a TIN map into a raster map
+# COPYRIGHT:  (C) 2011-2015 Antonio Alliegro, 2015 Alexander Muriy,
+#             and the GRASS Development Team
+#             This program is free software under the GNU General
+#             Public License (>=v2). Read the file COPYING that
+#             comes with GRASS for details.
+#%module
+#% description: Converts (rasterize) a TIN map into a raster map
+#% keywords: TIN, vector, raster, conversion
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: tin
+#% description: Name of input TIN map
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% key_desc: raster
+#% description: Name of output raster map
+#% required: yes
+#%end
+import sys
+import os
+import atexit
+try:
+    import grass.script as grass
+except:
+    try:
+        from grass.script import core as grass
+    except:
+        if not os.environ.has_key("GISBASE"):
+            print "You must be in GRASS GIS to run this program."
+            sys.exit(1)
+grass_version = grass.version().get('version')[0:3]
+if grass_version != '6.4':
+    grass.fatal(_("Sorry, this script works in GRASS 6.4.* only"))
+else:
+    from grass.lib.gis    import *
+    from grass.lib.vector import *
+def cleanup():
+    nuldev = file(os.devnull, 'w')
+    if tmp:
+        grass.run_command('g.remove', rast = '%s' % tmp,
+                          quiet = True, stderr = nuldev)
+def main():
+    global nuldev, tmp
+    tmp = "v_tin_to_rast_%d" % os.getpid()
+    input = options['input']
+    output = options['output']
+    # initialize GRASS library
+    G_gisinit('')
+    # check if vector map exists
+    mapset = G_find_vector2(input, "")
+    if not mapset:
+        grass.fatal("Vector map <%s> not found" % input)
+    # define map structure
+    map_info = pointer(Map_info())
+    # set vector topology to level 2
+    Vect_set_open_level(2)
+    # opens the vector map
+    Vect_open_old(map_info, input, mapset)
+    Vect_maptype_info(map_info, input, mapset)
+    # check if vector map is 3D
+    if Vect_is_3d(map_info):
+        grass.message("Vector map <%s> is 3D" % input)
+    else:
+        grass.fatal("Vector map <%s> is not 3D" % input)
+    # allocation of the output buffer using the values of the current region
+    window = pointer(Cell_head())
+    G_get_window(window)
+    nrows = window.contents.rows
+    ncols = window.contents.cols
+    xref = window.contents.west
+    yref = window.contents.south
+    xres = window.contents.ew_res
+    yres = window.contents.ns_res
+    outrast = []
+    for i in range(nrows):
+        outrast[i:] = [G_allocate_d_raster_buf()]
+    # create new raster
+    outfd = G_open_raster_new(output, DCELL_TYPE)
+    if outfd < 0:
+        grass.fatal("Impossible to create a raster <%s>" % output)
+    # insert null values in cells
+    grass.message(_("Step 1/4: Inserting null values in cells..."))
+        G_set_d_null_value(outrast[i], ncols)
+        G_percent(i, nrows, 2)
+    #####  main work #####
+    grass.message(_("Step 2/4: TIN preprocessing..."))
+    z = c_double()
+    G_percent(0, nrows, 2)
+    Vect_tin_get_z(map_info, xref, yref, byref(z), None, None)
+    grass.message(_("Step 3/4: Converting TIN to raster..."))
+        for j in range(ncols):
+            x = xref + j * xres
+            y = yref + i * yres
+            Vect_tin_get_z(map_info, x, y, byref(z), None, None)
+            outrast[i][j] = z
+    grass.message(_("Step 4/4: Writing raster map..."))
+    for i in range(nrows - 1, -1, -1):
+        if G_put_d_raster_row(outfd, outrast[i]) < 0:
+            grass.fatal(_("Error writing raster <%s>" % output))
+        G_percent(nrows - i, nrows, 2)
+    # clear buffer
+        G_free(outrast[i])
+    # close raster
+    G_close_cell(outfd)
+    # close vector
+    Vect_close(map_info)
+    # cut output raster to TIN vertical range
+    vtop = grass.read_command('v.info', flags = 'g',
+                              map = input).rsplit()[4].split('=')[1]
+    vbottom = grass.read_command('v.info', flags = 'g',
+                                 map = input).rsplit()[5].split('=')[1]
+    grass.mapcalc("$tmp = if($vbottom < $output && $output < $vtop, $output, null())",
+                  tmp = tmp, output = output, vbottom = vbottom, vtop = vtop,
+    grass.parse_command('g.rename', rast = (tmp, output),
+    # write cmd history:
+    grass.run_command('r.support', map = output,
+                      title = "%s" % output, history="",
+                      description = "generated by v.tin.to.rast")
+    grass.raster_history(output)
+    grass.message(_("Done."))
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
Property changes on: grass-addons/grass6/vector/v.tin.to.rast/v.tin.to.rast.py
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass7/vector/v.tin.to.rast/Makefile
--- grass-addons/grass7/vector/v.tin.to.rast/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.tin.to.rast/Makefile	2015-04-05 20:01:17 UTC (rev 64986)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=v.tin.to.rast
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.tin.to.rast/description.html
--- grass-addons/grass7/vector/v.tin.to.rast/description.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.tin.to.rast/description.html	2015-04-05 20:01:17 UTC (rev 64986)
@@ -0,0 +1,41 @@
+<html>
+<head>
+</head>
+<h2>NAME</h2>
+<h2>KEYWORDS</h2>
+<h2>SYNOPSIS</h2>
+<h3>Flags:</h3>
+<DL>
+</DL>
+<DL>
+</DL>
+</body>
+</html>
Added: grass-addons/grass7/vector/v.tin.to.rast/v.tin.to.rast.py
--- grass-addons/grass7/vector/v.tin.to.rast/v.tin.to.rast.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.tin.to.rast/v.tin.to.rast.py	2015-04-05 20:01:17 UTC (rev 64986)
@@ -0,0 +1,187 @@
+#             Salerno, Italy
+#             Alexander Muriy
+#%module
+#% keywords: TIN
+#% keywords: vector
+#% keywords: raster
+#% keywords: conversion
+#%end
+#%option G_OPT_V_INPUT
+#% label: Name of input TIN map
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
+import sys
+import os
+import atexit
+try:
+except:
+    try:
+    except:
+            sys.exit(1)
+grass_version = grass.version().get('version')[0:2]
+if grass_version != '7.':
+    grass.fatal(_("Sorry, this script works in GRASS 7.* only"))
+else:
+    from grass.lib.raster import *
+def cleanup():
+    if tmp:
+def main():
+    G_gisinit('')
+    if not mapset:
+    else:
+    outrast = []
+        outrast[i:] = [Rast_allocate_d_buf()]
+    outfd = Rast_open_new(output, DCELL_TYPE)
+    if outfd < 0:
+        Rast_set_d_null_value(outrast[i], ncols)
+    z = c_double()
+            outrast[i][j] = z
+        Rast_put_d_row(outfd, outrast[i])
+    # clear buffer
+    # close raster
+    Rast_close(outfd)
+    # close vector
+    main()
Property changes on: grass-addons/grass7/vector/v.tin.to.rast/v.tin.to.rast.py
