[GRASS-SVN] r64988 - grass-addons/grass7/vector/v.isochrones
svn_grass at osgeo.org
Sun Apr 5 13:38:00 PDT 2015
Author: neteler
Date: 2015-04-05 13:38:00 -0700 (Sun, 05 Apr 2015)
New Revision: 64988
grass-addons/grass7/vector/v.isochrones/v.isochrones.py
v.isochrones Addon: out -> output in v.to.rast call
Modified: grass-addons/grass7/vector/v.isochrones/v.isochrones.py
--- grass-addons/grass7/vector/v.isochrones/v.isochrones.py 2015-04-05 20:20:15 UTC (rev 64987)
+++ grass-addons/grass7/vector/v.isochrones/v.isochrones.py 2015-04-05 20:38:00 UTC (rev 64988)
@@ -193,7 +193,7 @@
grass.run_command('g.region', vect=isos_extract,
flags='a')
grass.run_command('v.to.rast', input_=isos_extract,
- use='cat', out=isos_extract_rast, overwrite=True)
+ use='cat', output=isos_extract_rast, overwrite=True)
grass.run_command('r.grow.distance', input=isos_extract_rast,
value=isos_grow_cat, distance=isos_grow_distance,
flags='m', overwrite=True)
@@ -279,7 +279,7 @@
# transform to raster
input=roads,
- out=tmp_cost_map,
+ output=tmp_cost_map,
use='attr',
attrcolumn=tmp_cost_column,
type='line',
