[GRASS-SVN] r64999 - grass/branches/releasebranch_6_4
svn_grass at osgeo.org
Mon Apr 6 13:35:51 PDT 2015
Author: neteler
Date: 2015-04-06 13:35:50 -0700 (Mon, 06 Apr 2015)
New Revision: 64999
grass/branches/releasebranch_6_4/config.guess
grass/branches/releasebranch_6_4/config.sub
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/branches/releasebranch_6_4/config.guess
--- grass/branches/releasebranch_6_4/config.guess 2015-04-06 19:21:23 UTC (rev 64998)
+++ grass/branches/releasebranch_6_4/config.guess 2015-04-06 20:35:50 UTC (rev 64999)
@@ -1,8 +1,8 @@
#! /bin/sh
# Attempt to guess a canonical system name.
-# Copyright 1992-2014 Free Software Foundation, Inc.
+# Copyright 1992-2015 Free Software Foundation, Inc.
-timestamp='2014-03-23'
+timestamp='2015-03-04'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
@@ -24,12 +24,12 @@
# program. This Exception is an additional permission under section 7
# of the GNU General Public License, version 3 ("GPLv3").
-# Originally written by Per Bothner.
+# Originally written by Per Bothner; maintained since 2000 by Ben Elliston.
# You can get the latest version of this script from:
# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
-# Please send patches with a ChangeLog entry to config-patches at gnu.org.
+# Please send patches to <config-patches at gnu.org>.
me=`echo "$0" | sed -e 's,.*/,,'`
@@ -50,7 +50,7 @@
GNU config.guess ($timestamp)
-Copyright 1992-2014 Free Software Foundation, Inc.
+Copyright 1992-2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
@@ -168,20 +168,27 @@
# Note: NetBSD doesn't particularly care about the vendor
# portion of the name. We always set it to "unknown".
sysctl="sysctl -n hw.machine_arch"
- UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
- /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
+ UNAME_MACHINE_ARCH=`(uname -p 2>/dev/null || \
+ /sbin/$sysctl 2>/dev/null || \
+ /usr/sbin/$sysctl 2>/dev/null || \
+ echo unknown)`
case "${UNAME_MACHINE_ARCH}" in
armeb) machine=armeb-unknown ;;
arm*) machine=arm-unknown ;;
sh3el) machine=shl-unknown ;;
sh3eb) machine=sh-unknown ;;
sh5el) machine=sh5le-unknown ;;
+ earmv*)
+ arch=`echo ${UNAME_MACHINE_ARCH} | sed -e 's,^e\(armv[0-9]\).*$,\1,'`
+ endian=`echo ${UNAME_MACHINE_ARCH} | sed -ne 's,^.*\(eb\)$,\1,p'`
+ machine=${arch}${endian}-unknown
*) machine=${UNAME_MACHINE_ARCH}-unknown ;;
esac
# The Operating System including object format, if it has switched
# to ELF recently, or will in the future.
- arm*|i386|m68k|ns32k|sh3*|sparc|vax)
+ arm*|earm*|i386|m68k|ns32k|sh3*|sparc|vax)
eval $set_cc_for_build
if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
| grep -q __ELF__
@@ -197,6 +204,13 @@
os=netbsd
esac
+ # Determine ABI tags.
+ case "${UNAME_MACHINE_ARCH}" in
+ earm*)
+ expr='s/^earmv[0-9]/-eabi/;s/eb$//'
+ abi=`echo ${UNAME_MACHINE_ARCH} | sed -e "$expr"`
+ esac
# The OS release
# Debian GNU/NetBSD machines have a different userland, and
# thus, need a distinct triplet. However, they do not need
@@ -213,7 +227,7 @@
# Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
# contains redundant information, the shorter form:
# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
- echo "${machine}-${os}${release}"
+ echo "${machine}-${os}${release}${abi}"
exit ;;
*:Bitrig:*:*)
UNAME_MACHINE_ARCH=`arch | sed 's/Bitrig.//'`
@@ -579,8 +593,9 @@
else
IBM_ARCH=powerpc
fi
- if [ -x /usr/bin/oslevel ] ; then
- IBM_REV=`/usr/bin/oslevel`
+ if [ -x /usr/bin/lslpp ] ; then
+ IBM_REV=`/usr/bin/lslpp -Lqc bos.rte.libc |
+ awk -F: '{ print $3 }' | sed s/[0-9]*$/0/`
else
IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
fi
@@ -932,6 +947,9 @@
crisv32:Linux:*:*)
echo ${UNAME_MACHINE}-axis-linux-${LIBC}
exit ;;
+ e2k:Linux:*:*)
+ echo ${UNAME_MACHINE}-unknown-linux-${LIBC}
+ exit ;;
frv:Linux:*:*)
exit ;;
Modified: grass/branches/releasebranch_6_4/config.sub
--- grass/branches/releasebranch_6_4/config.sub 2015-04-06 19:21:23 UTC (rev 64998)
+++ grass/branches/releasebranch_6_4/config.sub 2015-04-06 20:35:50 UTC (rev 64999)
@@ -1,8 +1,8 @@
#! /bin/sh
# Configuration validation subroutine script.
-timestamp='2014-04-03'
+timestamp='2015-03-08'
@@ -25,7 +25,7 @@
# Configuration subroutine to validate and canonicalize a configuration type.
# Supply the specified configuration type as an argument.
@@ -68,7 +68,7 @@
version="\
GNU config.sub ($timestamp)
@@ -117,7 +117,7 @@
case $maybe_os in
nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc | linux-newlib* | \
linux-musl* | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | \
- knetbsd*-gnu* | netbsd*-gnu* | \
+ knetbsd*-gnu* | netbsd*-gnu* | netbsd*-eabi* | \
kopensolaris*-gnu* | \
storm-chaos* | os2-emx* | rtmk-nova*)
os=-$maybe_os
@@ -259,8 +259,8 @@
| bfin \
| c4x | c8051 | clipper \
| d10v | d30v | dlx | dsp16xx \
- | epiphany \
- | fido | fr30 | frv \
+ | e2k | epiphany \
+ | fido | fr30 | frv | ft32 \
| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
| hexagon \
| i370 | i860 | i960 | ia64 \
@@ -283,8 +283,10 @@
| mips64vr5900 | mips64vr5900el \
| mipsisa32 | mipsisa32el \
| mipsisa32r2 | mipsisa32r2el \
+ | mipsisa32r6 | mipsisa32r6el \
| mipsisa64 | mipsisa64el \
| mipsisa64r2 | mipsisa64r2el \
+ | mipsisa64r6 | mipsisa64r6el \
| mipsisa64sb1 | mipsisa64sb1el \
| mipsisa64sr71k | mipsisa64sr71kel \
| mipsr5900 | mipsr5900el \
@@ -300,6 +302,7 @@
| pdp10 | pdp11 | pj | pjl \
| powerpc | powerpc64 | powerpc64le | powerpcle \
| pyramid \
+ | riscv32 | riscv64 \
| rl78 | rx \
| score \
| sh | sh[1234] | sh[24]a | sh[24]aeb | sh[23]e | sh[34]eb | sheb | shbe | shle | sh[1234]le | sh3ele \
@@ -310,6 +313,7 @@
| tahoe | tic4x | tic54x | tic55x | tic6x | tic80 | tron \
| ubicom32 \
| v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
+ | visium \
| we32k \
| x86 | xc16x | xstormy16 | xtensa \
| z8k | z80)
@@ -324,6 +328,9 @@
c6x)
basic_machine=tic6x-unknown
+ leon|leon[3-9])
+ basic_machine=sparc-$basic_machine
m6811 | m68hc11 | m6812 | m68hc12 | m68hcs12x | nvptx | picochip)
basic_machine=$basic_machine-unknown
os=-none
@@ -374,7 +381,7 @@
| c[123]* | c30-* | [cjt]90-* | c4x-* \
| c8051-* | clipper-* | craynv-* | cydra-* \
| d10v-* | d30v-* | dlx-* \
- | elxsi-* \
+ | e2k-* | elxsi-* \
| f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
| h8300-* | h8500-* \
| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
@@ -401,8 +408,10 @@
| mips64vr5900-* | mips64vr5900el-* \
| mipsisa32-* | mipsisa32el-* \
| mipsisa32r2-* | mipsisa32r2el-* \
+ | mipsisa32r6-* | mipsisa32r6el-* \
| mipsisa64-* | mipsisa64el-* \
| mipsisa64r2-* | mipsisa64r2el-* \
+ | mipsisa64r6-* | mipsisa64r6el-* \
| mipsisa64sb1-* | mipsisa64sb1el-* \
| mipsisa64sr71k-* | mipsisa64sr71kel-* \
| mipsr5900-* | mipsr5900el-* \
@@ -432,6 +441,7 @@
| ubicom32-* \
| v850-* | v850e-* | v850e1-* | v850es-* | v850e2-* | v850e2v3-* \
| vax-* \
+ | visium-* \
| we32k-* \
| x86-* | x86_64-* | xc16x-* | xps100-* \
| xstormy16-* | xtensa*-* \
@@ -508,6 +518,9 @@
basic_machine=i386-pc
os=-aros
+ asmjs)
+ basic_machine=asmjs-unknown
aux)
basic_machine=m68k-apple
os=-aux
@@ -769,6 +782,9 @@
basic_machine=m68k-isi
os=-sysv
+ leon-*|leon[3-9]-*)
+ basic_machine=sparc-`echo $basic_machine | sed 's/-.*//'`
m68knommu)
basic_machine=m68k-unknown
os=-linux
@@ -824,6 +840,10 @@
basic_machine=powerpc-unknown
os=-morphos
+ moxiebox)
+ basic_machine=moxie-unknown
+ os=-moxiebox
msdos)
os=-msdos
@@ -1356,7 +1376,7 @@
| -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
| -sym* | -kopensolaris* | -plan9* \
| -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
- | -aos* | -aros* \
+ | -aos* | -aros* | -cloudabi* \
| -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
| -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
| -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
@@ -1369,7 +1389,7 @@
| -cygwin* | -msys* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
| -mingw32* | -mingw64* | -linux-gnu* | -linux-android* \
| -linux-newlib* | -linux-musl* | -linux-uclibc* \
- | -uxpv* | -beos* | -mpeix* | -udk* \
+ | -uxpv* | -beos* | -mpeix* | -udk* | -moxiebox* \
| -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
| -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
| -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
