[GRASS-SVN] r65004 - grass/branches/releasebranch_6_4
svn_grass at osgeo.org
Mon Apr 6 14:10:08 PDT 2015
Author: neteler
Date: 2015-04-06 14:10:08 -0700 (Mon, 06 Apr 2015)
New Revision: 65004
grass/branches/releasebranch_6_4/INSTALL
grass/branches/releasebranch_6_4/REQUIREMENTS.html
REQUIREMENTS.html: updated
Modified: grass/branches/releasebranch_6_4/INSTALL
--- grass/branches/releasebranch_6_4/INSTALL 2015-04-06 21:01:20 UTC (rev 65003)
+++ grass/branches/releasebranch_6_4/INSTALL 2015-04-06 21:10:08 UTC (rev 65004)
@@ -282,6 +282,7 @@
Note that the support currently only applies to the core raster I/O code.
Individual programs may or may not work with large files - please report.
+For improved large file support, use GRASS GIS 7+.
(L) SUPPORT
@@ -308,6 +309,6 @@
http://grasswiki.osgeo.org/wiki/GRASS_6_Tutorial
-(C) 1999-2014 by The GRASS Development Team
+(C) 1999-2015 by The GRASS Development Team
Last changed: $Date$
Modified: grass/branches/releasebranch_6_4/REQUIREMENTS.html
--- grass/branches/releasebranch_6_4/REQUIREMENTS.html 2015-04-06 21:01:20 UTC (rev 65003)
+++ grass/branches/releasebranch_6_4/REQUIREMENTS.html 2015-04-06 21:10:08 UTC (rev 65004)
@@ -26,24 +26,25 @@
<ul>
<li><b>C-compiler</b> (cc, gcc, egcs, ...)
<br>gcc: <a href="http://www.gnu.org/software/gcc/gcc.html">http://www.gnu.org/software/gcc/gcc.html</a>
-<br>
+</li>
<li><b>GNU make</b> is recommended (at least version 3.81)
<br><a href="http://www.gnu.org/software/make/make.html">http://www.gnu.org/software/make/make.html</a>
-<br>
+</li>
<li><b>zlib</b> compression library (already installed on most modern systems)
-<br>It is used to internally compress GRASS raster maps:
+<br>It is used to internally compress GRASS raster maps.
<br>libz: <a href="http://www.zlib.net">http://www.zlib.net</a>
-<br>
+</li>
-<li><b>flex</b> lexical analyzer generator (flex) - note: lex is no longer supported, please use flex instead:
+<li><b>flex</b> lexical analyzer generator (flex)
+<br>Note: lex is no longer supported, please use flex instead.
<br>flex: <a href="http://www.gnu.org/software/flex/flex.html">http://www.gnu.org/software/flex/flex.html</a>
-<br>
+</li>
<li><b>parser generator</b> (yacc, bison)
<br>bison: <a href="http://www.gnu.org/software/bison/bison.html">http://www.gnu.org/software/bison/bison.html</a>
-<br>
+</li>
<li><b>libncurses4.x/5.x</b> (already installed on modern systems)
<br><a href="http://www.gnu.org/software/ncurses/ncurses.html">http://www.gnu.org/software/ncurses/ncurses.html</a>
@@ -58,21 +59,22 @@
construction which does not require X11
<br>
-<li><b>PROJ4</b> - Projection Library<br>
+<li><b>PROJ4</b> - Cartographic Projection Library<br>
<a href="http://trac.osgeo.org/proj">http://trac.osgeo.org/proj</a>
-<br>
+</li>
-<li><b>GDAL and OGR</b> for import and export of most external raster and vector
+<li><b>GDAL/OGR</b> for import and export of most external raster and vector
map formats<br>
-<a href="http://gdal.osgeo.org">http://gdal.osgeo.org</a>
+<a href="http://gdal.org">http://gdal.org</a>
+</li>
<li><b>XDR</b> for raster I/O management (commonly provided on *NIX systems)<br>
<a href="https://svn.r-project.org/R/trunk/src/extra/xdr">https://svn.r-project.org/R/trunk/src/extra/xdr</a>
+</li>
</ul>
-<h3>
-Optional requirements:</h3>
+<h3>Optional requirements:</h3>
<ul>
<li><b>Tcl/Tk 8.x libraries</b> (including the 'wish' program) to use the GRASS GUI
@@ -94,94 +96,106 @@
<li><b>C++ Compiler</b> (required for the r.terraflow module)<br>
+</li>
<li><b>FFTW 2.x or 3.x</b> (library for computing the Discrete Fourier Transform), required
for i.fft and i.ifft and other modules<br>
<a href="http://www.fftw.org">http://www.fftw.org</a>
+</li>
+<li><b>GEOS</b> (Geometry Engine library), needed for v.buffer and adds extended options
+to the v.select module<br>
+<a href="http://trac.osgeo.org/geos">http://trac.osgeo.org/geos</a>
+</li>
-<li><b>LAPACK / BLAS</b> (libraries for numerical computing) for GMATH library (GRASS numerical lib)<br>
+<li><b>LAPACK / BLAS</b> (libraries for numerical computing) for GMATH library (GRASS Numerical Library)<br>
<a href="http://www.netlib.org/lapack">http://www.netlib.org/lapack</a> (usually available on Linux distros)
<br>
-<I>Note: LAPACK/BLAS support is intended for future module implementations, no need to
-use it at time!</I>
+<i>Note:</i> LAPACK/BLAS support is at time only needed for selected Addons
<li><b>libpng</b> (for r.out.png and the PNG driver), usually already installed.<br>
<a href="http://www.libpng.org/pub/png/libpng.html">http://www.libpng.org/pub/png/libpng.html</a>
+</li>
<li><b>libtiff</b> (for r.out.tiff), usually already installed.<br>
<a href="http://www.remotesensing.org/libtiff">http://www.remotesensing.org/libtiff</a>
+</li>
<li><b>readline</b> for extra command prompt functionality
<br><a href="http://tiswww.case.edu/~chet/readline/rltop.html">http://tiswww.case.edu/~chet/readline/rltop.html</a>
<br><a href="ftp://ftp.gnu.org/gnu/readline">ftp://ftp.gnu.org/gnu/readline</a>
+</li>
<li><b>PostgreSQL libraries</b> (for the PostgreSQL database interface)<br>
<a href="http://www.postgresql.org">http://www.postgresql.org</a>
+</li>
-<li><b>mySQL libraries</b> (for the mySQL database interface)<br>
+<li><b>MySQL libraries</b> (for the MySQL database interface)<br>
<a href="http://www.mysql.org">http://www.mysql.org</a>
+</li>
-<li><b>sqlite libraries</b> (for the sqlite database interface)<br>
+<li><b>SQLite libraries</b> (for the SQLite database interface)<br>
<a href="http://www.sqlite.org">http://www.sqlite.org</a>
+</li>
<li><b>unixODBC</b> (for the ODBC database interface)<br>
<a href="http://www.unixodbc.org">http://www.unixodbc.org</a>
+</li>
<li><b>Motif or Lesstif libraries</b> (for the "xganim" <!-- and ogl3d -->
module)<br>
<a href="http://www.lesstif.org">http://www.lesstif.org</a>
+</li>
-<li><b>R language</b> (for the R statistical language interface)<br>
+<li><b>R Statistics</b> (for the R statistical language interface)<br>
<a href="http://cran.r-project.org">http://cran.r-project.org</a>
+</li>
<li><b>FreeType2</b> (for TrueType font support and d.text.freetype)<br>
-<a href="http://www.freetype.org">http://www.freetype.org</a>
+ <a href="http://freetype.sourceforge.net">http://freetype.sourceforge.net</a>
+</li>
<li><b>Python >= 2.4</b> (for wxGUI and ctypes interface)<br>
Note: Python 3 is not supported<br>
<a href="http://www.python.org">http://www.python.org</a>
+</li>
<li><b>Ctypes</b> (for ctypes interface)<br>
Ctypes can be added as a third-party module in Python 2.3 and 2.4
- <a href="http://pypi.python.org/pypi/ctypes/1.0.2">http://pypi.python.org/pypi/ctypes/1.0.2</a><br>
<a href="http://docs.python.org/library/ctypes.html">http://docs.python.org/library/ctypes.html</a>
+</li>
<li><b>wxPython >= 2.8.1.1</b> (for wxGUI, see file
gui/wxpython/README)<br>
<a href="http://www.wxpython.org">http://www.wxpython.org</a>
+</li>
<li><b>NumPy >= 1.0.4</b> (for various wxGUI components, see
file gui/wxpython/README)<br>
<a href="http://numpy.scipy.org">http://numpy.scipy.org</a>
+</li>
<li><b>Python Imaging Library</b> (for wxGUI Cartographic Composer (preview mode), see
<a href="http://www.pythonware.com/products/pil">http://www.pythonware.com/products/pil</a>
+</li>
<li><b>FFMPEG</b> (for direct rendering of animations from NVIZ),
- including libavcodec, libavformat, libswscale <BR>
-<a href="http://ffmpeg.org">http://ffmpeg.org</a><BR>
+ including libavcodec, libavformat, libswscale <br>
+<a href="http://ffmpeg.org">http://ffmpeg.org</a><br>
+</li>
-<li><b>Cairo >= 1.5.8</b> (Cairo graphics library<BR>
-<a href="http://cairographics.org">http://cairographics.org</a><BR>
+<li><b>Cairo >= 1.5.8</b> (Cairo graphics library<br>
+<a href="http://cairographics.org">http://cairographics.org</a><br>
+</li>
+<li><b>AVCE00 and E00Compr Libraries</b> (avcimport)<br>
+<a href="http://avce00.maptools.org">http://avce00.maptools.org</a><br>
+</li>
-<li><b>AVCE00 and E00Compr Libraries</b> (avcimport)<BR>
-<a href="http://avce00.maptools.org">http://avce00.maptools.org</a><BR>
</ul>
@@ -200,10 +214,10 @@
<p>
-<hr WIDTH="100%">
-<br><i>© GRASS Development Team 2001-2011</i>
+<hr width="100%">
+<i>© GRASS Development Team 2001-2015</i>
<p>Please report bugs here:
-<br><a href="http://grass.osgeo.org/bugtracking/index.php">http://grass.osgeo.org/bugtracking/index.php</a>
+<br><a href="http://grass.osgeo.org/development/bug-tracking/">http://grass.osgeo.org/development/bug-tracking/</a>
<p>
<i>Last changed: $Date$</i>
