[GRASS-SVN] r65029 - grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical
svn_grass at osgeo.org
Thu Apr 9 06:03:28 PDT 2015
Author: osfraid
Date: 2015-04-09 06:03:28 -0700 (Thu, 09 Apr 2015)
New Revision: 65029
grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.html
grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.py
add new version of r.green.biomassfor.theoretical and html file
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.html
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.html 2015-04-09 02:56:37 UTC (rev 65028)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.html 2015-04-09 13:03:28 UTC (rev 65029)
@@ -0,0 +1,72 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>GRASS GIS manual: r.green.biomassfor.theoretical.py</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<div id="container">
+<a href="index.html"><img src="grass_logo.png" alt="GRASS logo"></a>
+<hr class="header">
+<h2>NOME</h2>
+<em><b>r.green.biomassfor.theoretical.py</b></em> - Estimates potential bioenergy depending on forest increment, forest management and forest treatment
+<h2>PAROLE CHIAVE</h2>
+<h2>SINOPSI</h2>
+<div id="name"><b>r.green.biomassfor.theoretical.py</b><br></div>
+<b>r.green.biomassfor.theoretical.py --help</b><br>
+<div id="synopsis"><b>r.green.biomassfor.theoretical.py</b> [<b>energy_tops_hf</b>=<em>float</em>] <b>increment</b>=<em>name</em> <b>yield_surface</b>=<em>name</em> <b>management</b>=<em>name</em> <b>treatment</b>=<em>name</em> <b>output_prefix</b>=<em>name</em> [<b>energy_cormometric_vol_hf</b>=<em>float</em>] [<b>energy_tops_cop</b>=<em>float</em>] [--<b>overwrite</b>] [--<b>help</b>] [--<b>verbose</b>] [--<b>quiet</b>] [--<b>ui</b>]
+</div>
+<div id="flags">
+<h3>Flag:</h3>
+<dl>
+<dt><b>--overwrite</b></dt>
+<dd>Permetti al file di output di sovrascrivere file esistenti</dd>
+<dt><b>--help</b></dt>
+<dd>Print usage summary</dd>
+<dt><b>--verbose</b></dt>
+<dd>Output verboso del modulo</dd>
+<dt><b>--quiet</b></dt>
+<dd>Output quieto del modulo</dd>
+<dt><b>--ui</b></dt>
+<dd>Force launching GUI dialog</dd>
+</dl>
+</div>
+<div id="parameters">
+<h3>Parametri:</h3>
+<dl>
+<dt><b>energy_tops_hf</b>=<em>float</em></dt>
+<dd>Energy for tops and branches in high forest in MWh/m³</dd>
+<dd>Default: <em>0.49</em></dd>
+<dt><b>increment</b>=<em>name</em> <b>[required]</b></dt>
+<dd>Map of increment</dd>
+<dt><b>yield_surface</b>=<em>name</em> <b>[required]</b></dt>
+<dd>Map of stand surface (ha)</dd>
+<dt><b>management</b>=<em>name</em> <b>[required]</b></dt>
+<dd>Map of forest management (1: high forest, 2:coppice)</dd>
+<dt><b>treatment</b>=<em>name</em> <b>[required]</b></dt>
+<dd>Map of forest treatment (1: final felling, 2:thinning)</dd>
+<dt><b>output_prefix</b>=<em>name</em> <b>[required]</b></dt>
+<dd>Prefix for potential bioenergy (HF,CC and total)</dd>
+<dt><b>energy_cormometric_vol_hf</b>=<em>float</em></dt>
+<dd>Energy for the whole tree in high forest (tops, branches and stem) in MWh/m³</dd>
+<dd>Default: <em>1.97</em></dd>
+<dt><b>energy_tops_cop</b>=<em>float</em></dt>
+<dd>Energy for tops and branches for Coppices in MWh/m³</dd>
+<dd>Default: <em>0.55</em></dd>
+</dl>
+</div>
+</body>
+</html>
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.py 2015-04-09 02:56:37 UTC (rev 65028)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.theoretical/r.green.biomassfor.theoretical.py 2015-04-09 13:03:28 UTC (rev 65029)
@@ -81,9 +81,6 @@
-#ECOCC = 'ecological_bioenergyC = if(management==2, yield_pix1*%f)'
def main(opts, flgs):
ow = overwrite()
@@ -94,15 +91,14 @@
treatment=opts['treatment']
yield_surface=opts['yield_surface']
- p_bioenergyHF=output+'_p_bioenergyHF'
- p_bioenergyC=output+'_p_bioenergyC'
- p_bioenergy=output+'_p_bioenergy'
+ p_bioenergyHF=output+'_t_bioenergyHF'
+ p_bioenergyC=output+'_t_bioenergyC'
+ p_bioenergy=output+'_t_bioenergy'
#import pdb; pdb.set_trace()
ECOHF = p_bioenergyHF+' = if('+management+'==1 && '+treatment+'==1 || '+management+' == 1 && '+treatment+'==99999, yield_pixp*%f, if('+management+'==1 && '+treatment+'==2, yield_pixp*%f + yield_pixp*%f))'
- #ECOHF = 'ecological_bioenergyHF = if(management==1 && treatment==1 || management == 1 && treatment==99999,yield_pix1*'+opts['energy_tops_hf']+', if(management==1 && treatment==2, yield_pix1*'+opts['energy_tops_hf']+' + yield_pix1*'+opts['energy_cormometric_vol_hf']+'))'
ECOCC = p_bioenergyC+' = if('+management+'==2, yield_pixp*'+opts['energy_tops_cop']+')'
@@ -125,7 +121,7 @@
T = np.array(pT)
- print "Resulted maps: "+output+"_p_bioenergyHF, "+output+"_p_bioenergyC, "+output+"_p_bioenergy"
+ print "Resulted maps: "+output+"_t_bioenergyHF, "+output+"_t_bioenergyC, "+output+"_t_bioenergy"
print ("Total bioenergy stimated (Mwh): %.2f" % np.nansum(T))
if __name__ == "__main__":
