[GRASS-SVN] r65040 - grass/branches/releasebranch_7_0/lib/python/docs/src
svn_grass at osgeo.org
Thu Apr 9 11:27:17 PDT 2015
Author: wenzeslaus
Date: 2015-04-09 11:27:17 -0700 (Thu, 09 Apr 2015)
New Revision: 65040
grass/branches/releasebranch_7_0/lib/python/docs/src/script_intro.rst
pythonlib: mention standard options in doc (backport r63403, backport related part of r63871, finishes r63872)
Modified: grass/branches/releasebranch_7_0/lib/python/docs/src/script_intro.rst
--- grass/branches/releasebranch_7_0/lib/python/docs/src/script_intro.rst 2015-04-09 16:36:29 UTC (rev 65039)
+++ grass/branches/releasebranch_7_0/lib/python/docs/src/script_intro.rst 2015-04-09 18:27:17 UTC (rev 65040)
@@ -97,9 +97,9 @@
#%module
#% description: Adds the values of two rasters (A + B)
- #% keywords: raster
- #% keywords: algebra
- #% keywords: sum
+ #% keyword: raster
+ #% keyword: algebra
+ #% keyword: sum
#%end
#%option G_OPT_R_INPUT
#% key: araster
@@ -132,7 +132,28 @@
if __name__ == "__main__":
sys.exit(main())
+The options which has something like ``G_OPT_R_INPUT`` after the word
+``option`` are called standard options. Their list is accessible
+in GRASS GIS `C API documentation`_ of ``STD_OPT`` enum from ``gis.h`` file.
+Always use standard options if possible. They are not only easier to use
+but also ensure consistency across the modules and easier maintanenace
+in case of updates to the parameters parsing system.
+Typically, you change ``description`` (and/or ``label``), sometimes ``key``
+and ``answer``. There are also standard flags to be used
+with ``flag`` which work in the same way.
+The examples of syntax of options and flags (without the ``G_OPT...`` part)
+can be obtained from any GRASS module using special ``--script`` flag.
+Alternatively, you can use GRASS source code to look how different scripts
+actually define and use their parameters.
Note that the previous code samples were missing some whitespace which
Python PEP8 style guide requires but this last sample fulfills all the
requirements. You should always use *pep8* tool to check your syntax and
-style or set your editor to do it for you.
+style or set your editor to do it for you. Note also that although
+a some mistakes in Python code can be discovered only when executing
+the code due to the dynamic nature of Python, there is a large number
+of tools such as *pep8* or *pylint* which can help you to identify problems
+in you Python code.
+.. _C API documentation: http://grass.osgeo.org/programming7/gis_8h.html
