[GRASS-SVN] r65077 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Thu Apr 16 04:20:01 PDT 2015
Author: zarch
Date: 2015-04-16 04:20:00 -0700 (Thu, 16 Apr 2015)
New Revision: 65077
grass/trunk/lib/python/pygrass/vector/geometry.py
pygrass: Check returned value from Vect_point_on_line function
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2015-04-16 09:59:59 UTC (rev 65076)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2015-04-16 11:20:00 UTC (rev 65077)
@@ -630,11 +630,12 @@
str_err = "The distance exceed the lenght of the line, that is: %f"
raise ValueError(str_err % maxdist)
pnt = Point(0, 0, -9999)
- libvect.Vect_point_on_line(self.c_points, distance,
- pnt.c_points.contents.x,
- pnt.c_points.contents.y,
- pnt.c_points.contents.z,
- angle, slope)
+ if not libvect.Vect_point_on_line(self.c_points, distance,
+ pnt.c_points.contents.x,
+ pnt.c_points.contents.y,
+ pnt.c_points.contents.z,
+ angle, slope):
+ raise ValueError("Vect_point_on_line give an error.")
pnt.is2D = self.is2D
return pnt
