[GRASS-SVN] r65080 - grass-addons/grass7/raster/r.recode.attr
svn_grass at osgeo.org
Thu Apr 16 05:26:58 PDT 2015
Author: pvanbosgeo
Date: 2015-04-16 05:26:58 -0700 (Thu, 16 Apr 2015)
New Revision: 65080
grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py
correction
Modified: grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py
--- grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py 2015-04-16 12:26:01 UTC (rev 65079)
+++ grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py 2015-04-16 12:26:58 UTC (rev 65080)
@@ -2,7 +2,7 @@
# -*- coding: utf-8 -*-
# MODULE: r.recode_attribute
# AUTHOR(S): Paulo van Breugel <p.vanbreugel AT gmail.com>
# PURPOSE: Recode raster to one or more new layers using an
@@ -11,18 +11,18 @@
# COPYRIGHT: (C) 2014 Paulo van Breugel
# http://ecodiv.org
# http://pvanb.wordpress.com/
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
-#%Module
+#%Module
#% description: Recode raster using attribute table (csv file) as input
#% keyword: raster
#% keyword: recode
-#%End
+#%End
#%option
#% key: input
@@ -44,7 +44,7 @@
#% multiple: no
#%end
-#%option G_OPT_F_INPUT
+#%option G_OPT_F_OUTPUT
#% key: rules
#% label: Full path to rules file
#% required: yes
@@ -61,8 +61,8 @@
import grass.script as grass
def cleanup():
- grass.run_command('g.remove',
- type = 'raster',
+ grass.run_command('g.remove',
+ type = 'raster',
pattern = 'tmp_map',
flags='f',
quiet = True)
@@ -79,46 +79,46 @@
# main function
def main():
# check if GISBASE is set
if "GISBASE" not in os.environ:
# return an error advice
grass.fatal(_("You must be in GRASS GIS to run this program"))
- # input raster map and parameters
+ # input raster map and parameters
inputmap = options['input']
outBase = options['output']
rules = options['rules']
outNames = outBase.split(',')
lengthNames = len(outNames)
# Get attribute data
myData = np.genfromtxt(rules, delimiter=',', skip_header=1)
nmsData = np.genfromtxt(rules, delimiter=',', names=True)
dimData = myData.shape
nmsData = nmsData.dtype.names
# Create recode maps
numVar = xrange(dimData[1]-1)
for x in numVar:
y = x + 1
myRecode = np.column_stack((myData[:,0], myData[:,0], myData[:,y]))
tmpname = CreateFileName()
- np.savetxt(tmpname, myRecode, delimiter=":")
+ np.savetxt(tmpname, myRecode, delimiter=":")
if len(numVar) == lengthNames:
nmOutput = outNames[x]
else:
nmOutput = outNames[0] + '_' + nmsData[y]
grass.run_command('r.recode',
- input = inputmap,
+ input = inputmap,
output = nmOutput,
rules = '.numpy_grass_recode')
- os.remove('.numpy_grass_recode')
+ os.remove('.numpy_grass_recode')
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
