[GRASS-SVN] r65082 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Thu Apr 16 08:34:12 PDT 2015
Author: krejcmat
Date: 2015-04-16 08:34:12 -0700 (Thu, 16 Apr 2015)
New Revision: 65082
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
support of new db.login
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-04-16 12:27:17 UTC (rev 65081)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-04-16 15:34:12 UTC (rev 65082)
@@ -22,7 +22,6 @@
from mw_util import *
class PointInterpolation():
def __init__(self, database, step, methodDist=False):
grass.message("Interpolating points along lines...")
@@ -1210,7 +1209,6 @@
print self.database.dbConnStr
RunCommand('v.db.connect',
driver='pg',
- database=self.database.dbConnStr,
map=self.database.linkVecMapName,
table=win,
key='linkid',
@@ -1348,15 +1346,17 @@
time = roundTime(time, 30)
return time
- def grassTemporalConnection(self, db):
+ def grassTemporalConnection(self, db='postgres'):
if db == 'postgres':
- conninfo = 'dbname= ' + self.dbName
+ conninfo = 'dbname=' + self.dbName
if self.user:
- conninfo += ' user= ' + self.user
+ conninfo += ' user=' + self.user
if self.password:
- conninfo += ' passwd= ' + self.password
+ conninfo += ' password=' + self.password
if self.host:
conninfo += ' host=' + self.host
+ if self.port:
+ conninfo += ' port=' + str(self.port)
if grass.run_command('t.connect',
driver='pg',
@@ -1368,35 +1368,44 @@
flags='d')
def grassConnectionRemote(self):
- conninfo = 'dbname=' + self.dbName
- if self.host:
- conninfo += ' host=' + self.host
- if self.port:
- conninfo += ' port=' + str(self.port)
- self.dbConnStr=conninfo
- # Unfortunately we cannot test untill user/password is set
+ self.dbConnStr = self.dbName
if self.user and not self.password:
grass.run_command('db.login',
driver="pg",
- database=conninfo,
+ database=self.dbName,
user=self.user,
- password='')
+ password='',
+ overwrite=True)
elif self.user and self.password:
- grass.run_command('db.login',
- driver="pg",
- user=self.user,
- password=self.password)
+ if self.port and self.host:
+ grass.run_command('db.login',
+ driver="pg",
+ user=self.user,
+ password=self.password,
+ host=self.host,
+ port=self.port,
+ overwrite=True
+ else:
+ driver="pg",
+ user=self.user,
+ overwrite=True)
else:
- driver="pg",
- user='',
- password='')
+ driver="pg",
+ user='',
+ password='',
+ overwrite=True)
- if grass.run_command('db.connect', driver="pg", database=conninfo) != 0:
+ if grass.run_command('db.connect', driver="pg", database=self.dbName,overwrite=True) != 0:
grass.fatal("Unable to connect to the database by grass driver.")
