[GRASS-SVN] r65092 - grass/branches/releasebranch_7_0/lib/python/docs/src
svn_grass at osgeo.org
Sun Apr 19 02:17:08 PDT 2015
Author: martinl
Date: 2015-04-19 02:17:08 -0700 (Sun, 19 Apr 2015)
New Revision: 65092
grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_vector.rst
pygrass docs: fix syntax typos (cosmetics)
(merge r65091 from trunk)
Modified: grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_vector.rst
--- grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_vector.rst 2015-04-19 09:15:28 UTC (rev 65091)
+++ grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_vector.rst 2015-04-19 09:17:08 UTC (rev 65092)
@@ -191,7 +191,7 @@
loaded unless explicitly specified, in case they are not needed.
Accessing a vector map's table(s) requires finding any links to tables, then
-requesting the table from each of the returned links:
+requesting the table from each of the returned links: ::
from grass.pygrass.vector import VectorTopo
>>> municip = VectorTopo('census')
@@ -207,7 +207,7 @@
contains all the links of a vector map. Each link is also a class
(:class:`~pygrass.vector.table.Link`) that contains a specific link's
parameters. The ``table()`` method of the link class return the linked table as
-a table object (`class:`~pygrass.vector.table.Table`).
+a table object (:class:`~pygrass.vector.table.Table`).
Geometry Classes
