[GRASS-SVN] r65099 - grass-addons/grass6/raster/r.ipso
Sun Apr 19 07:57:27 PDT 2015
Author: madi
Date: 2015-04-19 07:57:27 -0700 (Sun, 19 Apr 2015)
New Revision: 65099
   grass-addons/grass6/raster/r.ipso/r.ipso.py
fixed findint function to handle the case in which the function presents two min
Modified: grass-addons/grass6/raster/r.ipso/r.ipso.py
--- grass-addons/grass6/raster/r.ipso/r.ipso.py	2015-04-19 14:53:08 UTC (rev 65098)
+++ grass-addons/grass6/raster/r.ipso/r.ipso.py	2015-04-19 14:57:27 UTC (rev 65099)
@@ -59,6 +59,7 @@
 import matplotlib.pyplot as plt
 import grass.script as grass
 import numpy as np
+from operator import itemgetter
 def main():
     stats = grass.read_command('r.stats', input = options['map'], fs = 'space', nv = '*', nsteps = '255', flags = 'inc').split('\n')[:-1]
@@ -122,8 +123,14 @@
 def findint(kl,f):
-    Xf = np.abs(kl-f); Xf = np.where(Xf==Xf.min())
-    z1 , z2 , f1 , f2 = kl[float(Xf[0])][0] , kl[float(Xf[0]-1)][0] , kl[float(Xf[0])][1] , kl[float(Xf[0]-1)][1]
+    Xf = np.abs(kl-f)
+    Xf = np.where(Xf==Xf.min())
+    item = itemgetter(0)(Xf)
+    Xf = item[0]  # added this further step to handle the case the function has 2 min
+    z1 = kl[float(Xf)][0]
+    z2 = kl[float(Xf-1)][0]
+    f1 = kl[float(Xf)][1]
+    f2 = kl[float(Xf-1)][1]
     z = z1 + ((z2 - z1) / (f2 - f1)) * (f - f1)
     return z
