[GRASS-SVN] r65101 - grass/trunk/raster/r.thin
svn_grass at osgeo.org
Mon Apr 20 03:11:39 PDT 2015
Author: marisn
Date: 2015-04-20 03:11:39 -0700 (Mon, 20 Apr 2015)
New Revision: 65101
grass/trunk/raster/r.thin/io.c
grass/trunk/raster/r.thin/main.c
grass/trunk/raster/r.thin/thin_lines.c
r.thin: Remove unused error_prefix
Modified: grass/trunk/raster/r.thin/io.c
--- grass/trunk/raster/r.thin/io.c 2015-04-19 15:22:29 UTC (rev 65100)
+++ grass/trunk/raster/r.thin/io.c 2015-04-20 10:11:39 UTC (rev 65101)
@@ -41,8 +41,6 @@
#define PAD 2
#define MAX_ROW 7
- /*extern int errno; *//* included #include <errno.h> instead 1/2000 */
-extern char *error_prefix;
static int n_rows, n_cols;
static int work_file;
static char *work_file_name;
@@ -118,8 +116,8 @@
close(creat(work_file_name, 0666));
if ((work_file = open(work_file_name, 2)) < 0) {
unlink(work_file_name);
- G_fatal_error(_("%s: Unable to create temporary file <%s> -- errno = %d"),
- error_prefix, work_file_name, errno);
+ G_fatal_error(_("Unable to create temporary file <%s> -- errno = %d"),
+ work_file_name, errno);
buf_len = n_cols * sizeof(CELL);
buf = (CELL *) G_malloc(buf_len);
@@ -127,16 +125,14 @@
for (i = 0; i < PAD; i++) {
if (write(work_file, buf, buf_len) != buf_len) {
- G_fatal_error(_("%s: Error writing temporary file"),
- error_prefix);
+ G_fatal_error(_("Error writing temporary file"));
for (row = 0; row < n_rows; row++) {
Rast_get_c_row(cell_file, buf + PAD, row);
- error_prefix);
@@ -145,8 +141,7 @@
- error_prefix);
n_rows += (PAD << 1);
Modified: grass/trunk/raster/r.thin/main.c
--- grass/trunk/raster/r.thin/main.c 2015-04-19 15:22:29 UTC (rev 65100)
+++ grass/trunk/raster/r.thin/main.c 2015-04-20 10:11:39 UTC (rev 65101)
@@ -40,7 +40,6 @@
#include "local_proto.h"
#include <grass/glocale.h>
-char *error_prefix;
int main(int argc, char *argv[])
Modified: grass/trunk/raster/r.thin/thin_lines.c
--- grass/trunk/raster/r.thin/thin_lines.c 2015-04-19 15:22:29 UTC (rev 65100)
+++ grass/trunk/raster/r.thin/thin_lines.c 2015-04-20 10:11:39 UTC (rev 65101)
@@ -26,7 +26,6 @@
#define false 0
#define DELETED_PIX 9999
static int n_rows, n_cols, pad_size;
static int box_right, box_left, box_top, box_bottom;
@@ -65,8 +64,7 @@
} /* row-loop */
if (box_right < box_left || box_bottom < box_top) {
- G_fatal_error(_("%s: Unable to find bounding box for lines"),
- error_prefix);
+ G_fatal_error(_("Unable to find bounding box for lines"));
G_message(_("Bounding box: l = %d, r = %d, t = %d, b = %d"),
box_left, box_right, box_top, box_bottom);
