[GRASS-SVN] r65105 - grass/trunk/raster/r.thin
Mon Apr 20 07:08:53 PDT 2015
Author: neteler
Date: 2015-04-20 07:08:53 -0700 (Mon, 20 Apr 2015)
New Revision: 65105
   grass/trunk/raster/r.thin/r.thin.html
r.thin manual: cosmetics
Modified: grass/trunk/raster/r.thin/r.thin.html
--- grass/trunk/raster/r.thin/r.thin.html	2015-04-20 14:01:41 UTC (rev 65104)
+++ grass/trunk/raster/r.thin/r.thin.html	2015-04-20 14:08:53 UTC (rev 65105)
@@ -1,14 +1,14 @@
 <h2>DESCRIPTION</h2>
 <em>r.thin</em> scans the named <em>input</em> raster map layer and
-thins non-null cells that denote linear features into linear features
+thins non-NULL cells that denote linear features into linear features
 having a single cell width. Raster lines often need to be thinned
 (skeletonizing raster features) to a single pixel width before they can
 be transformed to vector data.
 <p>
-<em>r.thin</em> will thin only the non-null cells of the
-named <em>input</em> raster map layer within the current
+<em>r.thin</em> will thin only the non-NULL (no data) raster cells
+of the named <em>input</em> raster map layer within the current
 geographic region settings.  The cell width of the thinned
 <em>output</em> raster map layer will be equal to the cell
 resolution of the currently set geographic region.  All of
@@ -19,11 +19,9 @@
 <em>r.thin</em> will create a new <em>output</em> raster
 data file containing the thinned linear features.
 <em>r.thin</em> assumes that linear features are encoded
-with positive values on a background of null's in the
-<em>input</em> raster data file, hence it creates a null/1
+with positive values on a background of NULL's in the
+<em>input</em> raster data file, hence it creates a NULL/1
 output map.
-Note - behaviour of <em>r.thin</em> was changed in GRASS 7 to
-use null instead of 0 for input and output.
 <h2>NOTES</h2>
@@ -115,11 +113,11 @@
 <h2>SEE ALSO</h2>
 <em>
-  <a href="g.region.html">g.region</a>,
-  <a href="r.to.vect.html">r.to.vect</a>,
-  <a href="v.clean.html">v.clean</a>,
-  <a href="wxGUI.vdigit.html">wxGUI vector digitizer</a>,
-  <a href="v.build.html">v.build</a>
+<a href="g.region.html">g.region</a>,
+<a href="r.to.vect.html">r.to.vect</a>,
+<a href="v.clean.html">v.clean</a>,
+<a href="wxGUI.vdigit.html">wxGUI vector digitizer</a>,
+<a href="v.build.html">v.build</a>
 </em>
 <h2>AUTHOR</h2>
