[GRASS-SVN] r65118 - grass/trunk/raster/r.compress
svn_grass at osgeo.org
Tue Apr 21 09:36:21 PDT 2015
Author: neteler
Date: 2015-04-21 09:36:21 -0700 (Tue, 21 Apr 2015)
New Revision: 65118
grass/trunk/raster/r.compress/r.compress.html
r.compress manual: mention GRASS_ZLIB_LEVEL
Modified: grass/trunk/raster/r.compress/r.compress.html
--- grass/trunk/raster/r.compress/r.compress.html 2015-04-21 14:00:05 UTC (rev 65117)
+++ grass/trunk/raster/r.compress/r.compress.html 2015-04-21 16:36:21 UTC (rev 65118)
@@ -156,6 +156,17 @@
Since GRASS GIS 7.0.0, the default compression method for
Integer (CELL) maps is deflate and not any more the RLE compression.
+<h4>DEFLATE compression level</h4>
+If the environment variable <tt>GRASS_ZLIB_LEVEL</tt> exists and
+its value can be parsed as an integer, it determines the compression
+level used when newly generated raster maps are compressed using zlib
+compression. This applies to all raster map types (CELL, FCELL, DCELL).
+<p>
+If the variable does not exist, or the value cannot be parsed as an
+integer, zlib's default compression level will be used.
<h2>EXAMPLES</h2>
Printing of current compression state:
