[GRASS-SVN] r65123 - grass-addons/grass7/gui/wxpython/wx.mwprecip
    svn_grass at osgeo.org
    Thu Apr 23 05:50:27 PDT 2015
Author: krejcmat
Date: 2015-04-23 05:50:27 -0700 (Thu, 23 Apr 2015)
New Revision: 65123
   grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
   grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
fix temporal description
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py	2015-04-23 06:21:30 UTC (rev 65122)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py	2015-04-23 12:50:27 UTC (rev 65123)
@@ -1024,11 +1024,10 @@
         # GMessage('OK')
         comp = Computor(self.baseline, self.twin, self.dbConn, self.settings['dataExport'])
-        bool, msg = comp.GetStatus()
-        if bool:
+        state, msg = comp.GetStatus()
+        if state:
             self.initGrassLayerMgr()
             self.initTemporalMgr()
         GMessage(msg)
         #self.initgrassManagement()
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py	2015-04-23 06:21:30 UTC (rev 65122)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py	2015-04-23 12:50:27 UTC (rev 65123)
@@ -1205,8 +1205,7 @@
         for win in f.read().splitlines():
             layerNum += 1
             win = self.database.schema + '.' + win
-            print self.database.dbConnStr
+            print win
             RunCommand('v.db.connect',
                        driver='pg',
                        map=self.database.linkVecMapName,
@@ -1253,15 +1252,14 @@
         # print temporalType
         # print semanticType
-        # ret, err = \
         RunCommand('t.create',
-                   type='stvds',
-                   output=self.datasetName,
-                   title=self.datasetTitle,
-                   description=self.datasetTdescription,
-                   temporaltype=temporalType,
-                   semantictype=semanticType,
-                   overwrite=True)
+                           type='stvds',
+                           output=self.datasetName,
+                           title=self.datasetTitle,
+                           description='test mw ',
+                           temporaltype=temporalType,
+                           semantictype=semanticType,
+                           overwrite=True)
         # getErrorMsg=True)
         #print ret
         #print err
@@ -1272,18 +1270,20 @@
         timeOfLay = self.timeWinConf.timestamp_min
         regTMP = ""
         regFilePath = os.path.join(self.database.pathworkSchemaDir, "temporal_reg_file")
-        # print '---'
-        # print self.timeWinConf.numWindows + 1
         for layer in range(1, self.timeWinConf.numWindows + 1, 1):
             mapsName = str(self.database.linkVecMapName + ':' + str(layer) + '@' + gisenv_grass['MAPSET'])
             timeOfLay += timedelta(seconds=self.timeWinConf.intervalStr)
             regTMP += mapsName + '|' + str(timeOfLay) + '\n'
         io1 = open(regFilePath, 'w+')
         io1.writelines(regTMP), io1.close
         io1.close()
         print 'datasetName', self.datasetName
         print regFilePath
+        #sys.exit()
         RunCommand('t.register',
                    input=self.datasetName,
                    type='vector',
@@ -1347,6 +1347,9 @@
         return time
     def grassTemporalConnection(self, db='postgres'):
+        grass.run_command('t.connect',flags='d')
         if db == 'postgres':
             conninfo = 'dbname=' + self.dbName
             if self.user:
@@ -1366,6 +1369,7 @@
         if db == 'sql':
                               flags='d')
     def grassConnectionRemote(self):
         self.dbConnStr  = self.dbName
