[GRASS-SVN] r65125 - grass/branches/releasebranch_7_0/scripts/v.in.e00
svn_grass at osgeo.org
Thu Apr 23 07:34:13 PDT 2015
Author: annakrat
Date: 2015-04-23 07:34:13 -0700 (Thu, 23 Apr 2015)
New Revision: 65125
grass/branches/releasebranch_7_0/scripts/v.in.e00/v.in.e00.py
v.in.e00: fix various errors (merge from trunk, r65055, r65124)
Modified: grass/branches/releasebranch_7_0/scripts/v.in.e00/v.in.e00.py
--- grass/branches/releasebranch_7_0/scripts/v.in.e00/v.in.e00.py 2015-04-23 14:27:08 UTC (rev 65124)
+++ grass/branches/releasebranch_7_0/scripts/v.in.e00/v.in.e00.py 2015-04-23 14:34:13 UTC (rev 65125)
@@ -31,24 +31,25 @@
#%end
#%option G_OPT_V_TYPE
#% options: point,line,area
+#% answer: point
#% required: yes
#%end
#%option G_OPT_V_OUTPUT
-#% required : no
#%end
import os
import shutil
import glob
from grass.script.utils import try_rmdir, try_remove, basename
+from grass.script import vector as gvect
from grass.script import core as grass
from grass.exceptions import CalledModuleError
def main():
- filename = options['file']
+ filename = options['input']
type = options['type']
- vect = options['vect']
+ vect = options['output']
e00tmp = str(os.getpid())
@@ -118,7 +119,6 @@
else:
grass.message(_("E00 Compressed ASCII found. Will uncompress first..."))
try_remove(e00shortname)
- try_remove(info)
grass.call(['e00conv', filename, e00tmp + '.e00'])
grass.message(_("...converted to Arc Coverage in current directory"))
grass.call(['avcimport', e00tmp + '.e00', e00shortname], stderr = nuldev)
@@ -157,7 +157,7 @@
grass.message(_("Done."))
# write cmd history:
- grass.vector_history(name)
+ gvect.vector_history(name)
if __name__ == "__main__":
options, flags = grass.parser()
