[GRASS-SVN] r65131 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Apr 25 03:28:41 PDT 2015
Author: martinl
Date: 2015-04-25 03:28:41 -0700 (Sat, 25 Apr 2015)
New Revision: 65131
grass/trunk/lib/vector/Vlib/read_pg.c
vlib: fix Vect__execute_pg() to handle long SQL statements on failure
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2015-04-24 17:52:23 UTC (rev 65130)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2015-04-25 10:28:41 UTC (rev 65131)
@@ -1505,9 +1505,14 @@
G_debug(3, "Vect__execute_pg(): %s", stmt);
result = PQexec(conn, stmt);
if (!result || PQresultStatus(result) != PGRES_COMMAND_OK) {
+ size_t stmt_len;
+ char stmt_prt[512];
PQclear(result);
- G_warning(_("Execution failed: %s\nReason: %s"), stmt,
+ stmt_len = strlen(stmt);
+ strncpy(stmt_prt, stmt, stmt_len > 511 ? 511 : stmt_len);
+ stmt_prt[stmt_len > 511 ? 511 : stmt_len] = '\0';
+ G_warning(_("Execution failed: %s (...)\nReason: %s"), stmt_prt,
PQerrorMessage(conn));
return -1;
