[GRASS-SVN] r65136 - grass-addons/grass7/gui/wxpython/wx.mwprecip
svn_grass at osgeo.org
Sat Apr 25 11:13:56 PDT 2015
Author: krejcmat
Date: 2015-04-25 11:13:56 -0700 (Sat, 25 Apr 2015)
New Revision: 65136
grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
fix data export
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-04-25 10:33:55 UTC (rev 65135)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py 2015-04-25 18:13:56 UTC (rev 65136)
@@ -387,7 +387,7 @@
if 'colorRules' in self.settings:
self.colorRules.SetValue(self.settings['colorRules'])
if 'colorName' in self.settings:
- self.colorsName.SetValue(self.settings['colorsName'])
+ self.colorsName.SetValue(self.settings['colorName'])
def saveSettings(self, evt=None, sett=None):
if sett:
@@ -451,8 +451,26 @@
self.chkpol = wx.CheckBox(self, label='polarization')
self.okBtt = wx.Button(self, label='export')
self.layout()
- # self.chkprecip.Bind(wx.EVT_CHECKBOX,self.onChckPrec)
+ self.chkprecip.Bind(wx.EVT_CHECKBOX, self.onChckPrec)
+ def onChckPrec(self,evt):
+ if self.chkprecip.GetValue():
+ self.chkrx.Disable()
+ self.chktx.Disable()
+ self.chkfreq.Disable()
+ self.chkpol.Disable()
+ self.chkrx.SetValue(False)
+ self.chktx.SetValue(False)
+ self.chkfreq.SetValue(False)
+ self.chkpol.SetValue(False)
+ else:
+ self.chkrx.Enable()
+ self.chktx.Enable()
+ self.chkfreq.Enable()
+ self.chkpol.Enable()
def layout(self):
mainSizer = wx.BoxSizer(wx.VERTICAL)
@@ -508,7 +526,7 @@
self.ntb.AddPage(page=self.pointInter, text='Points Interpolation')
self.grassLayers = GrassLayers(self.ntb, self.settings)
- self.ntb.AddPage(page=self.grassLayers, text='Layers')
+ self.ntb.AddPage(page=self.grassLayers, text='Colors')
#def initProfileSett(self):
self.loadScheme = wx.StaticText(self.mainPanel, label='Load settings', id=wx.ID_ANY)
@@ -825,17 +843,21 @@
interface.initTimeWinMW()
interface.initBaseline()
interface.doCompute()
- conn = self.GetConnection()
+ if interface.connStatus:
+ conn= interface.dbConn
sql = 'SELECT * FROM %s.%s' % (interface.dbConn.schema, interface.dbConn.computedPrecip)
res = conn.connection.executeSql(sql, True, True)
lines = ''
for r in res:
lines += str(r)[1:][:-1] + '\n'
print conn.pathworkSchemaDir
#path=os.path.join(conn.pathworkSchemaDir, "export")
io0 = open(path, "w+")
io0.writelines(lines)
io0.close()
+ os.remove(os.path.join(interface.dbConn.pathworkSchemaDir, "precip"))
GMessage('Data exported<%s>' % path)
self.exportDialog.Destroy()
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-04-25 10:33:55 UTC (rev 65135)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py 2015-04-25 18:13:56 UTC (rev 65136)
@@ -392,6 +392,10 @@
self.sumStep)
self.database.connection.executeSql(sql, False, True)
+ sql ='ALTER %s %s.%s\
+ ADD %s VARCHAR(11) '% (self.viewStatement, self.schema, self.viewDB,self.database.colorCol)
+ self.database.connection.executeSql(sql, False, True)
def setTimestamp(self):
self.timestamp_min = self.database.minTimestamp()
self.timestamp_max = self.database.maxTimestamp()
@@ -550,6 +554,7 @@
self.timeWin.createWin()
self.status['bool'] = True
def GetStatus(self):
return self.status.get('bool'), self.status.get('msg')
@@ -1004,8 +1009,6 @@
temp.append(out)
grass.message("Computing precipitation-done")
- # write values to flat file
- # print temp
pathExp = os.path.join(self.database.pathworkSchemaDir, "precip")
io = open(pathExp, 'w+')
io.writelines(temp)
@@ -1013,14 +1016,16 @@
#if getData:
grass.message("Computed data has been saved to <%s>" % pathExp)
grass.message("File structure is <linkid> <time> <precipitation>")
- if dataOnly:
- return False
grass.message("Writing computed precipitation to database...")
io1 = open(os.path.join(self.database.pathworkSchemaDir, "precip"), "r")
self.database.connection.copyfrom(io1, compPrecTab)
- #grass.message("Done")
+ if dataOnly:
+ return False
return True
def computeAlphaK(self, freq, polarization):
@@ -1121,8 +1126,9 @@
use='attr',
column=self.database.precipColName,
color=self.color,
- rgb_column='GRASSRGB',
+ rgb_column=self.database.colorCol,
layer=lay)
if self.rules is not None:
for lay in range(1, self.getNumLayer(self.database.linkVecMapName), 1):
Module('v.colors',
@@ -1130,8 +1136,9 @@
use='attr',
rules=self.rules,
layer=lay)
grass.message('Creating RGB column in database-done')
def getNumLayer(self, map):
@@ -1317,6 +1324,7 @@
self.rgaugRecord = 'rgauge_record'
self.rgaugeTableName = 'rgauge'
self.precipColName = 'precip_mm_h'
+ self.colorCol= 'rgb'
self.nodeVecMapName = nodeVecMapName
self.linkVecMapName = linkVecMapName
