[GRASS-SVN] r65147 - grass/trunk/scripts/d.rast.leg
svn_grass at osgeo.org
Sun Apr 26 23:49:51 PDT 2015
Author: lucadelu
Date: 2015-04-26 23:49:51 -0700 (Sun, 26 Apr 2015)
New Revision: 65147
grass/trunk/scripts/d.rast.leg/d.rast.leg.py
d.rast.leg: fixes trunk r64459; PEP8 cleanup
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2015-04-27 06:36:52 UTC (rev 65146)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py 2015-04-27 06:49:51 UTC (rev 65147)
@@ -13,9 +13,9 @@
# PURPOSE: Displays a raster map and its legend on a graphics window.
# Description: d.rast.leg clears the entire screen, divides it into a main
-# (left) and a minor (right) frames, and then display a raster
+# (left) and a minor (right) frames, and then display a raster
# map in the main frame and the map legend in the minor frame.
-# The user can run the program interactively or
+# The user can run the program interactively or
# non-interactively.
# See also: d.rast, d.legend.
@@ -65,6 +65,7 @@
import os
import grass.script as grass
def make_frame(f, b, t, l, r):
(fl, fr, ft, fb) = f
@@ -80,6 +81,7 @@
s = '%f,%f,%f,%f' % (rt, rb, rl, rr)
os.environ['GRASS_RENDER_FRAME'] = s
def main():
map = options['map']
nlines = options['lines']
@@ -88,7 +90,7 @@
flip = flags['f']
smooth = flags['s']
- #for -n flag of d.legend
+ # for -n flag of d.legend
if not grass.find_file(map)['file']:
grass.fatal(_("Raster map <%s> not found") % map)
@@ -96,35 +98,38 @@
if rast and not grass.find_file(rast)['file']:
grass.fatal(_("Raster map <%s> not found") % rast)
- s = grass.read_command('d.info', flags = 'f')
+ s = grass.read_command('d.info', flags='f')
if not s:
sys.exit(1)
- f = tuple([float(x) for x in s.split()[1:5]])
+ # fixes trunk r64459
+ s = s.split(':')[1]
+ f = tuple([float(x) for x in s.split()])
grass.run_command('d.erase')
os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
- #draw title
+ # draw title
# set vertical divide at 65 instead of 80 if real labels in cats/ file??
make_frame(f, 90, 100, 70, 100)
# use map name without mapset suffix
mapname = map.split('@')[0]
- grass.run_command('d.text', color='black', size=5, at='5,97', align='cl', text=mapname)
+ grass.run_command('d.text', color='black', size=5, at='5,97', align='cl',
+ text=mapname)
- #draw legend
+ # draw legend
# set legend vertical position and size based on number of categories
- cats = grass.read_command('r.describe', map=map, flags = '1n')
+ cats = grass.read_command('r.describe', map=map, flags='1n')
ncats = len(cats.strip().split('\n'))
# Only need to adjust legend size if number of categories is between 1 and 10
if ncats < 2: ncats = 2
if ncats > 10: ncats = 10
VSpacing = (100 - (ncats * 10) + 10)
if not nlines:
nlines = None
@@ -133,11 +138,11 @@
else:
lmap = map
- kv = grass.raster_info(map = lmap)
+ kv = grass.raster_info(map=lmap)
if kv['datatype'] is 'CELL':
leg_at = None
else:
- leg_at = '%f,95,5,10' %VSpacing
+ leg_at = '%f,95,5,10' % VSpacing
# checking for histogram causes more problems than it solves
# histfiledir = grass.find_file(lmap, 'cell_misc')['file']
@@ -155,14 +160,14 @@
# lflags += 'n'
make_frame(f, 0, 90, 70, 100)
- grass.run_command('d.legend', flags = lflags, raster = lmap, lines = nlines, at = leg_at)
+ grass.run_command('d.legend', flags=lflags, raster=lmap, lines=nlines,
+ at=leg_at)
- #draw map
+ # draw map
make_frame(f, 0, 100, 0, 70)
- grass.run_command('d.rast', map = map)
+ grass.run_command('d.rast', map=map)
if __name__ == "__main__":
options, flags = grass.parser()
main()
