Author: osfraid
Date: 2015-04-27 08:57:55 -0700 (Mon, 27 Apr 2015)
New Revision: 65156
grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.legal/r.green.biomassfor.legal.py
bug fix to r.green.biomassfor.legal.py
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.legal/r.green.biomassfor.legal.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.legal/r.green.biomassfor.legal.py 2015-04-27 15:57:22 UTC (rev 65155)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.legal/r.green.biomassfor.legal.py 2015-04-27 15:57:55 UTC (rev 65156)
@@ -5,7 +5,7 @@
# MODULE: r.green.biomassfor.legal
# AUTHOR(S): Sandro Sacchelli, Francesco Geri
-# Converted to Python by Francesco Geri reviewed by Marco Ciolli
+# Converted to Python by Pietro Zambelli and Francesco Geri, reviewed by Marco Ciolli
# PURPOSE: Calculates the potential Ecological Bioenergy contained in a forest
# COPYRIGHT: (C) 2013 by the GRASS Development Team
@@ -15,56 +15,74 @@
#%Module
-#% description: Estimates legal bioenergy depending on yield, forest management and forest treatment
+#% description: Estimates potential bioenergy depending on forest increment, forest management and forest treatment
#% keyword: raster
#% keyword: biomass
+#% overwrite: yes
#%End
+#%option G_OPT_V_INPUT
+#% key: forest
+#% type: string
+#% description: Name of vector parcel map
+#% label: Name of vector parcel map
+#% guisection: Base
+#%end
+#% key: boundaries
+#% type: string
+#% description: Name of vector boundaries map (boolean map)
+#% label: Name of vector boundaries map (boolean map)
+#%end
#%option
#% key: energy_tops_hf
#% type: double
#% description: Energy for tops and branches in high forest in MWh/m³
#% answer: 0.49
-#% required : yes
#% guisection: Energy
#%end
-#%option G_OPT_R_INPUT
-#% key: yield1
+#%option
+#% key: forest_column_yield
#% type: string
-#% description: Map of forest yield (cubic meters)
-#% required : yes
+#% answer: yield
+#% description: Vector field of increment
#%end
-#% key: yield_surface
+#%option
+#% key: forest_column_yield_surface
#% type: string
-#% description: Map of stand surface (ha)
-#% required : yes
+#% answer: yield_surface
+#% description: Vector field of stand surface (ha)
#%end
-#% key: management
+#%option
+#% key: forest_column_management
#% type: string
-#% description: Map of forest management (1: high forest, 2:coppice)
-#% required : yes
+#% answer: management
+#% description: Vector field of forest management (1: high forest, 2:coppice)
#%end
-#% key: treatment
+#%option
+#% key: forest_column_treatment
+#% answer: treatment
#% type: string
-#% description: Map of forest treatment (1: final felling, 2:thinning)
-#% required : yes
+#% description: Vector field of forest treatment (1: final felling, 2:thinning)
#%end
#%option
#% key: output_basename
+#% answer: biomassfor
#% type: string
#% gisprompt: new
#% description: Basename for potential bioenergy (HF,CC and total)
#% key_desc : name
-#% required : yes
#%end
#%option
#% key: energy_cormometric_vol_hf
#% type: double
#% description: Energy for the whole tree in high forest (tops, branches and stem) in MWh/m³
#% answer: 1.97
-#% required : no
#%end
#%option
@@ -72,7 +90,6 @@
#% type: double
#% description: Energy for tops and branches for Coppices in MWh/m³
#% answer: 0.55
-#% required : no
#%end
@@ -86,18 +103,48 @@
def main(opts, flgs):
ow = overwrite()
- output = opts['output_prefix']
+ output = opts['output_basename']
- yield_=opts['yield1']
- management=opts['management']
- treatment=opts['treatment']
- yield_surface=opts['yield_surface']
+ forest=opts['forest']
+ boundaries=opts['boundaries']
+ yield_=opts['forest_column_yield']
+ management=opts['forest_column_management']
+ treatment=opts['forest_column_treatment']
+ yield_surface=opts['forest_column_yield_surface']
l_bioenergyHF=output+'_l_bioenergyHF'
l_bioenergyC=output+'_l_bioenergyC'
l_bioenergy=output+'_l_bioenergy'
+ ######## start import and convert ########
+ run_command("g.region",vect=boundaries)
+ run_command("v.to.rast", input=forest,output="yield", use="attr", attrcolumn=yield_,overwrite=True)
+ run_command("v.to.rast", input=forest,output="yield_surface", use="attr", attrcolumn=yield_surface,overwrite=True)
+ run_command("v.to.rast", input=forest,output="treatment", use="attr", attrcolumn=treatment,overwrite=True)
+ run_command("v.to.rast", input=forest,output="management", use="attr", attrcolumn=management,overwrite=True)
+ run_command("r.null", map='yield',null=0)
+ run_command("r.null", map='yield_surface',null=0)
+ run_command("r.null", map='treatment',null=0)
+ run_command("r.null", map='management',null=0)
+ ######## end import and convert ########
+ ######## temp patch to link map and fields ######
+ management="management"
+ treatment="treatment"
+ yield_surface="yield_surface"
+ yield_="yield"
+ ######## end temp patch to link map and fields ######
#import pdb; pdb.set_trace()
#treatment=1 final felling, treatment=2 thinning
ECOHF = l_bioenergyHF+' = if('+management+'==1 && '+treatment+'==1 || '+management+' == 1 && '+treatment+'==99999, yield_pix1*%f, if('+management+'==1 && '+treatment+'==2, yield_pix1*%f + yield_pix1*%f))'
