[GRASS-SVN] r65160 - in grass-addons/grass7/vector: . v.maxent.swd
Wed Apr 29 02:53:33 PDT 2015
Author: pvanbosgeo
Date: 2015-04-29 02:53:33 -0700 (Wed, 29 Apr 2015)
New Revision: 65160
Added:
   grass-addons/grass7/vector/v.maxent.swd/
   grass-addons/grass7/vector/v.maxent.swd/Makefile
   grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.html
   grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.py
Small utility to create SWD input files for Maxent
Added: grass-addons/grass7/vector/v.maxent.swd/Makefile
--- grass-addons/grass7/vector/v.maxent.swd/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.maxent.swd/Makefile	2015-04-29 09:53:33 UTC (rev 65160)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.maxent.swd
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.maxent.swd/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-sh
Added: svn:eol-style
   + native
Added: grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.html
--- grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.html	2015-04-29 09:53:33 UTC (rev 65160)
@@ -0,0 +1,45 @@
+<h2>DESCRIPTION</h2>
+<p><em>v.maxent.swd</em> Produce a set of SWD files as input to MaxEnt
+3.3.3k, based on a point vector layer(s) of species distribution(s), a point layer with background points and user-defined raster layers. The user can also let the function create the background point file.
+(respecting region and mask, if set).
+<p>The SWD file format is a simple CSV-like file file format as
+described in Elith et al. 2011. The first three fields provide the
+species name, x-coordinate and y-coordinate, while subsequent fields
+contain the values of the user-selected environmental parameters.
+Note that the coordinates are not used by the MaxEnt program if all
+environmental data is given in the SWD format file.
+<p>The user can provide one or more species point files, which will be
+combined in one SWD file. The map names of both the species point
+layers and the environmental parameters can be replaced by alias
+names, which will be used by MaxEnt.
+<h2>NOTES</h2>
+<p>The SWD output files are simple comma delimited text
+files (.csv) and can therefore be easily read in in for example R
+and subsequently used in other models / functions.
+<h2>SEE ALSO</h2>
+<ul>
+    <li>MaxEnt 3.3.3k (<a href="http://www.cs.princeton.edu/~schapire/maxent/">http://www.cs.princeton.edu/~schapire/maxent/</a>)</li>
+    <li>The <a href="http://svn.osgeo.org/grass/grass-addons/grass6/raster/r.out.maxent_swd/r.out.maxent_swd.html">
+    r.out.maxent_swd</a> script (for GRASS GIS 6.*) for an alternative implementation</li>
+</ul>
+<h2>REFERENCES</h2>
+<ul>
+    <li> Steven J. Phillips, Miroslav Dudík, Robert E. Schapire.A maximum entropy approach to species distribution modeling. In Proceedings of the Twenty-First International Conference on Machine Learning, pages 655-662, 2004.</li>
+    <li>Steven J. Phillips, Robert P. Anderson, Robert E. Schapire. Maximum entropy modeling of species geographic distributions. Ecological Modelling, 190:231-259, 2006.</li>
+    <li>Jane Elith, Steven J. Phillips, Trevor Hastie, Miroslav Dudík, Yung En Chee, Colin J. Yates. A statistical explanation of MaxEnt for ecologists. Diversity and Distributions, 17:43-57, 2011. </li>
+</ul>
+<h2>AUTHOR</h2>
+<p>Paulo van Breugel, paulo at ecodiv.org
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.py
--- grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.py	2015-04-29 09:53:33 UTC (rev 65160)
@@ -0,0 +1,371 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:       r.maxent.swd
+# AUTHOR(S):    Paulo van Breugel
+# PURPOSE:      Produce a set of text file (SWD file) which can be used as
+#               input to MaxEnt 3.3.3. It may also provide the input data
+#               presence and absence/background for other modeling tools
+#               in e.g. R
+#               The SWD file format is a simple CSV-like file file format as
+#               described in Elith et al. 2011. Generally it looks like:
+#               specie_name,X,Y,parameter_1,parameter_2,...
+#               your_species,1.1,1.1,1,1,...
+#               The first column always contains the name of a species (for
+#               background data this column is ignored so any name can be used),
+#               followed by two colums for the X- and Y-coordinates. Then each
+#               column represents one environmental parameter.
+#               Map names of the maps containing the environmental parameters
+#               can be replaced by short names. Likewise, it is possible to
+#               define aliases for the names of the species distribution layer
+# COPYRIGHT:   (C) 2015 Paulo van Breugel
+#              http://ecodiv.org
+#              http://pvanb.wordpress.com/
+#              This program is free software under the GNU General Public
+#              License (>=v2). Read the file COPYING that comes with GRASS
+#              for details.
+# REQUIREMENTS:
+#%Module
+#% description: Export raster values at given point locations as text file in SWD format for input in Maxent
+#%End
+#%option
+#% key: species
+#% type: string
+#% description: vector map(s) of species occurence
+#% required : yes
+#% multiple : yes
+#% gisprompt: old,vector
+#% guisection: point data
+#%end
+#%option
+#% key: species_name
+#% type: string
+#% description: Alias-name(s) for species (default: map names).
+#% required : no
+#%end
+#%option
+#% key: evp_maps
+#% type: string
+#% description: Environmental parameter map(s)
+#% required : yes
+#% multiple : yes
+#% gisprompt: old,cell,raster
+#% guisection: environment
+#%end
+#%option
+#% key: alias_names
+#% type: string
+#% description: Alias names for environmental parameter(s)
+#% required : no
+#%end
+#%option
+#% key: evp_cat
+#% type: string
+#% description: Categorial environmental parameter map(s)
+#% required : no
+#% multiple : yes
+#%end
+#%option
+#% key: alias_cat
+#% type: string
+#% description: Alias names for categorial parameter(s)
+#% required : no
+#%end
+#%option
+#% key: nbgp
+#% type: string
+#% description: Number or percentage of background points
+#% key_desc: number
+#% answer : 10000
+#% required: no
+#%end
+#%option
+#% key: bgp
+#% type: string
+#% description: Vector layer with background / absence points
+#% required : no
+#% multiple : no
+#%end
+#%rules
+#%exclusive: nbgp,bgp
+#%end
+#%flag
+#% key: e
+#% description: include the original columns in input layers in export to swd file
+#%end
+#%option G_OPT_F_OUTPUT
+#% key: bgr_output
+#% description: Background SWD file
+#% required : yes
+#% multiple: no
+#% guisection: output
+#%end
+#% key: species_output
+#% description: Species SWD file
+#% required : yes
+#% multiple: no
+#%end
+#%flag
+#% key: h
+#% description: skip header in csv
+#%end
+#%option
+#% key: nodata
+#% type: integer
+#% description: nodata value in output files
+#% answer : -9999
+#% required: no
+#%end
+# Standard
+# import libraries
+import os
+import sys
+import grass.script as grass
+import numpy as np
+import string
+import uuid
+import atexit
+import tempfile
+# Standard
+if not os.environ.has_key("GISBASE"):
+    grass.message("You must be in GRASS GIS to run this program.")
+    sys.exit(1)
+# create set to store names of temporary maps to be deleted upon exit
+clean_rast = set()
+def cleanup():
+    for rast in clean_rast:
+        grass.run_command("g.remove", type="rast", name=rast, quiet=True)
+# Functions
+# Create temporary name
+def tmpname(name):
+    tmpf = name + "_" + str(uuid.uuid4())
+    tmpf = string.replace(tmpf, '-', '_')
+    clean_rast.add(tmpf)
+    return tmpf
+def CreateFileName(outputfile):
+    flname = outputfile
+    k = 0
+    while os.path.isfile(flname):
+        k = k + 1
+        fn = flname.split('.')
+        if len(fn) == 1:
+            flname = fn[0] + "_" + str(k)
+        else:
+            flname = fn[0] + "_" + str(k) + "." + fn[1]
+    return flname
+# Main
+def main():
+#options = {"species":"species1 at plantspecies,species2","species_name":"", "evp_maps":"bio_1 at climate,bio_2 at climate,bio_3 at climate", "alias_names":"BIO1,BIO2,bio3", "evp_cat":"tmpcategory at plantspecies","alias_cat":"categ","bgr_output":"swd_bgr.csv", "species_output":"swd_spec.csv", "nbgp":1000, "bgp":"", "nodata":-9999}
+#flags = {"e":False, "h":False}
+    # Variables
+    # variables
+    specs = options['species']
+    specs = specs.split(',')
+    specsn = options['species_name']
+    if specsn=='':
+        specsn = [z.split('@')[0] for z in specs]
+    else:
+        specsn = specsn.split(',')
+    evp = options['evp_maps']
+    evp = evp.split(',')
+    evpn = options['alias_names']
+    bgrout = options['bgr_output']
+    if os.path.isfile(bgrout):
+        bgrout2 = CreateFileName(bgrout)
+        grass.message("The file " + bgrout + " already exist. Using " + \
+        bgrout2 + " instead")
+        bgrout = bgrout2
+    specout = options['species_output']
+    bgp = options['bgp']
+    bgpn = options['nbgp']
+    nodata = options['nodata']
+    flag_e = flags['e']
+    flag_h = flags['h']
+    if flag_h:
+        header = 'c'
+    else:
+        header = ''
+    # Create list with environmental layers and list with their (alias) names
+    if evpn == '':
+        evpn = [z.split('@')[0] for z in evp]
+    else:
+        evpn = evpn.split(',')
+    if len(evp) != len(evpn):
+        grass.fatal("Number of environmental layers does not match number of aliases")
+    evp_cols = [s + " DOUBLE PRECISION" for s in evpn]
+    evpc = options['evp_cat']
+    if evpc != '':
+        evpc = evpc.split(',')
+        for k in np.arange(0,len(evpc)):
+            laytype = grass.raster_info(evpc[k])['datatype']
+            if laytype != 'CELL':
+                grass.fatal("Categorical variables need to be of type CELL (integer)")
+        evpcn = options['alias_cat']
+        if evpcn == '':
+            evpcn = [z.split('@')[0] for z in evpc]
+        else:
+            evpcn = evpcn.split(',')
+        evpcn = ["cat_" + s for s in evpcn]
+        evpc_cols = [s + " INTEGER" for s in evpcn]
+        evp = evp + evpc
+        evpn = evpn + evpcn
+        evp_cols = evp_cols + evpc_cols
+    evp_cols = ['species VARCHAR(250)', 'Long DOUBLE PRECISION', 'Lat DOUBLE PRECISION'] + evp_cols
+    # Background points
+    # Create / copy to tmp layer
+    bgpname = tmpname("bgp")
+    if bgp == '':
+        grass.run_command("r.random", input=evp[0], npoints=bgpn, vector=bgpname, quiet=True)
+        grass.run_command("v.db.droptable", flags="f", map=bgpname, quiet=True)
+        grass.run_command("v.db.addtable",  map=bgpname, table=bgpname, quiet=True)
+    else:
+        grass.run_command("g.copy", vector=[bgpn,bgpname], quiet=True)
+    grass.run_command("v.db.addcolumn", map=bgpname, columns=evp_cols, quiet=True)
+    # Upload environmental values for point locations to attribute table
+    for j in np.arange(0,len(evpn)):
+        grass.run_command("v.what.rast", map=bgpname, raster=evp[j], column=evpn[j], quiet=True)
+        sqlst = "update " + bgpname + " SET " + evpn[j] + " = " + \
+        str(nodata) + " WHERE " + evpn[j] + " ISNULL"
+        grass.run_command("db.execute", sql=sqlst, quiet=True)
+    sqlst = "update " + bgpname + " SET species = 'background'"
+    # Upload x and y coordinates
+    grass.run_command("v.to.db", map=bgpname, option="coor", columns="Long,Lat", quiet=True)
+    # Export the data to csv file and remove temporary file
+    if flag_e:
+        grass.run_command("v.db.select", flags=header, map=bgpname,
+                          columns="*", separator=",", file=bgrout, quiet=True)
+    else:
+        cols = ['Long', 'Lat', 'species'] + evpn
+                          columns=cols, separator=",", file=bgrout, quiet=True)
+    grass.run_command("g.remove", type="vector", name=bgpname, flags="f", quiet=True)
+    # Presence points
+    bgrdir = tempfile.mkdtemp()
+    for i in np.arange(0,len(specs)):
+        specname = tmpname("sp")
+        bgrtmp = bgrdir + '/prespoints' + str(i)
+        grass.run_command("g.copy", vector=[specs[i],specname], quiet=True)
+        grass.run_command("v.db.addcolumn", map=specname, columns=evp_cols, quiet=True)
+            grass.run_command("v.what.rast", map=specname, raster=evp[j], column=evpn[j], quiet=True)
+            sqlst = "update " + specname + " SET " + evpn[j] + " = " + \
+        sqlst = "update " + specname + " SET species = '" + specsn[i] + "'"
+        grass.run_command("v.to.db", map=specname, option="coor", columns="Long,Lat", quiet=True)
+        if flag_e:
+            if flag_h and i==0:
+                    grass.run_command("v.db.select", map=specname,
+                              columns='*', separator=",", file=bgrtmp, quiet=True)
+            else:
+                grass.run_command("v.db.select", flags='c', map=specname,
+        else:
+            cols = ['species'] + evpn
+            if header == '' and i==0:
+                              columns=cols, separator=",", file=bgrtmp, quiet=True)
+            else:
+        grass.run_command("g.remove", type="vector", name=specname, flags="f", quiet=True)
+    # Combine csv files
+    filenames = bgrdir + '/prespoints'
+    filenames = [filenames + str(i) for i in np.arange(0,len(specs))]
+    with open(specout, 'w') as outfile:
+        for fname in filenames:
+            with open(fname) as infile:
+                outfile.write(infile.read().rstrip() + '\n')
+    # Remove temporary text files
+    for m in filenames:
+       os.remove(m)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.maxent.swd/v.maxent.swd.py
   + text/x-python
   + native
