[GRASS-SVN] r65165 - grass/trunk/raster/r.carve
svn_grass at osgeo.org
Wed Apr 29 20:55:41 PDT 2015
Author: hcho
Date: 2015-04-29 20:55:41 -0700 (Wed, 29 Apr 2015)
New Revision: 65165
grass/trunk/raster/r.carve/enforce_ds.c
r.carve: Remove a duplicate variable name; Combine two ifs
Modified: grass/trunk/raster/r.carve/enforce_ds.c
--- grass/trunk/raster/r.carve/enforce_ds.c 2015-04-30 03:51:02 UTC (rev 65164)
+++ grass/trunk/raster/r.carve/enforce_ds.c 2015-04-30 03:55:41 UTC (rev 65165)
@@ -469,7 +469,7 @@
cy = Rast_row_to_northing(r + 0.5, &wind);
for (c = col1; c <= col2; c++) {
- double dist;
+ double distance;
cellx = Rast_col_to_easting(c + 0.5, &wind);
celly = cy; /* gets written over in distance2... */
@@ -481,40 +481,36 @@
* Here we use a bitmap and only change cells once
* on the way down */
- dist = sqrt(dig_distance2_point_to_line(cellx, celly, 0,
+ distance = sqrt(dig_distance2_point_to_line(cellx, celly, 0,
pgxypts[i - 1][0],
pgxypts[i - 1][1], 0,
pgxypts[i][0], pgxypts[i][1],
0, 0, &cellx, &celly, NULL,
NULL, NULL));
- if (dist <= parm->swidth) {
- if (!BM_get(bm, c, r)) {
- double dist, elev;
+ if (distance <= parm->swidth && !BM_get(bm, c, r)) {
+ double dist, elev;
- Vect_reset_line(points);
+ Vect_reset_line(points);
- dist = G_distance(pgxypts[i][0], pgxypts[i][1],
- cellx, celly);
+ dist = G_distance(pgxypts[i][0], pgxypts[i][1],
+ cellx, celly);
- elev = LINTERP(pgpts[i][1], pgpts[i - 1][1],
- (dist /
- (pgpts[i][0] - pgpts[i - 1][0])));
+ elev = LINTERP(pgpts[i][1], pgpts[i - 1][1],
+ (dist / (pgpts[i][0] - pgpts[i - 1][0])));
- BM_set(bm, c, r, 1);
+ BM_set(bm, c, r, 1);
- /* TODO - may want to use a function for the
- * cross section of stream */
- set_min_point(rbuf, c, r, elev, parm->sdepth,
- parm->raster_type);
+ /* TODO - may want to use a function for the
+ * cross section of stream */
+ set_min_point(rbuf, c, r, elev, parm->sdepth,
+ parm->raster_type);
- /* Add point to output vector map */
- if (parm->outvect->answer) {
- Vect_append_point(points, pgxypts[i][0],
- pgxypts[i][1],
- elev - parm->sdepth);
- Vect_write_line(outMap, GV_POINT, points, cats);
+ /* Add point to output vector map */
+ if (parm->outvect->answer) {
+ Vect_append_point(points, pgxypts[i][0], pgxypts[i][1],
+ elev - parm->sdepth);
+ Vect_write_line(outMap, GV_POINT, points, cats);
