[GRASS-SVN] r65806 - in grass-addons/grass7/raster: . r.mcda.electre
svn_grass at osgeo.org
Sat Aug 1 10:07:23 PDT 2015
Author: gianluca
Date: 2015-08-01 10:07:23 -0700 (Sat, 01 Aug 2015)
New Revision: 65806
Added:
grass-addons/grass7/raster/r.mcda.electre/
grass-addons/grass7/raster/r.mcda.electre/Makefile
grass-addons/grass7/raster/r.mcda.electre/Makefile~
grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py
grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~
Porting r.mcda.electre to grass70 with the python power
Added: grass-addons/grass7/raster/r.mcda.electre/Makefile
--- grass-addons/grass7/raster/r.mcda.electre/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.mcda.electre/Makefile 2015-08-01 17:07:23 UTC (rev 65806)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.mcda.electre
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.mcda.electre/Makefile~
--- grass-addons/grass7/raster/r.mcda.electre/Makefile~ (rev 0)
+++ grass-addons/grass7/raster/r.mcda.electre/Makefile~ 2015-08-01 17:07:23 UTC (rev 65806)
@@ -0,0 +1,7 @@
+PGM = r.mcda.roughset
+default: script
Added: grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py
--- grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py (rev 0)
+++ grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py 2015-08-01 17:07:23 UTC (rev 65806)
@@ -0,0 +1,116 @@
+#!/usr/bin/env python
+# MODULE: r.mcda.electre
+# AUTHOR: Gianluca Massei - Antonio Boggia
+# PURPOSE: Elaborate several criteria maps and gets concordance and
+# discordance maps indices as a base for electre analysis
+# COPYRIGHT: c) 2010 Gianluca Massei, Antonio Boggia and the GRASS
+# Development Team. This program is free software under the
+# GNU General PublicLicense (>=v2). Read the file COPYING
+# that comes with GRASS for details.
+#%module
+#% description: Gets concordance and discordance maps indices for MCDA analysis
+#% keyword: raster
+#% keyword: criteria maps
+#% keyword: MCDA
+#%end
+#%option G_OPT_R_INPUTS
+#% key: criteria
+#% multiple: yes
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Name of criteria raster maps
+#% required: yes
+#%end
+#%option
+#% key: weights
+#% type: double
+#% description: weights (w1,w2,...,wn)
+#% multiple: yes
+#% required: yes
+#%end
+#%option G_OPT_R_OUTPUT
+#% key: concordancemap
+#% type: string
+#% gisprompt: new_file,cell,output
+#% description: output concordance raster map
+#% answer:concordance
+#% required: yes
+#%end
+#% key: discordancemap
+#% type: string
+#% description: output discordance raster map
+#% answer:discordance
+#% required: yes
+#%end
+import sys
+import grass.script as gscript
+from grass.pygrass import raster
+def preprocessing(attributes,weights):
+ matrix=[]
+ for attribute in attributes:
+ c=[]
+ criteria = raster.RasterRowIO(str(attribute))
+ #criteria.is_open()
+ criteria.open('r')
+ for row in criteria:
+ c.append(row)
+ matrix.append(c)
+ criteria.close()
+ print len(matrix),weights
+ print dir(criteria)
+def concordance(attributes,weights,concordanceMap):
+ i=0
+ listMaps=[]
+ for attrRow,weight in zip(attributes,weights):
+ for attrCol in attributes:
+ concordanceMap="conc_%s" % str(i)
+ formula="%s=if(%s>%s,%s,0)" % (concordanceMap,attrRow.split('@')[0],attrCol.split('@')[0],weight)
+ gscript.mapcalc(formula,overwrite = True)
+ listMaps.append(concordanceMap)
+ i=i+1
+ endMap="%s=%s" % (concordanceMap,("+".join(listMaps)))
+ gscript.mapcalc(endMap,overwrite = True)
+ gscript.run_command("g.remove", type='raster',flags='f', name=",".join(listMaps))
+ return 0
+def discordance(attributes,discordanceMap):
+ i=0
+ listMaps=[]
+ for attrRow in attributes:
+ discordanceMap="conc_%s" % str(i)
+ formula="%s=if(%s>%s,%s-%s,0)" % (discordanceMap,attrRow.split('@')[0],attrCol.split('@')[0],attrRow.split('@')[0],attrCol.split('@')[0])
+ listMaps.append(discordanceMap)
+ i=i+1
+ endMap="%s=max(%s)" % (discordanceMap,("+".join(listMaps)))
+ return 0
+def main():
+ options, flags = gscript.parser()
+ attributes = options['criteria'].split(',')
+ weights = options['weights'].split(',')
+ concordanceMap= options['concordancemap']
+ discordanceMap= options['discordancemap']
+ concordance(attributes,weights,concordanceMap)
+ discordance(attributes,discordanceMap)
+ return 0
+if __name__ == "__main__":
+ sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~
--- grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~ (rev 0)
+++ grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~ 2015-08-01 17:07:23 UTC (rev 65806)
@@ -0,0 +1,116 @@
+#%module
+#% keyword: raster
+#% keyword: MCDA
+#%end
+#% key: criteria
+#% multiple: yes
+#% key_desc: name
+#% required: yes
+#%end
+#%option
+#% key: weights
+#% type: double
+#% multiple: yes
+#% required: yes
+#%end
+#% type: string
+#% required: yes
+#%end
+#% type: string
+#% required: yes
+#%end
+import sys
+ matrix=[]
+ c=[]
+ c.append(row)
+ matrix.append(c)
+ criteria.close()
+ i=0
+ listMaps=[]
+ i=i+1
+ return 0
+ i=0
+ listMaps=[]
+ listraster.append(discordanceMap)
+ i=i+1
+ return 0
+def main():
+ return 0
+ sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~
