[GRASS-SVN] r65811 - grass-addons/grass7/raster/r.mcda.electre
svn_grass at osgeo.org
Sun Aug 2 14:54:19 PDT 2015
Author: gianluca
Date: 2015-08-02 14:54:18 -0700 (Sun, 02 Aug 2015)
New Revision: 65811
Added:
grass-addons/grass7/raster/r.mcda.electre/dominance.c
grass-addons/grass7/raster/r.mcda.electre/local_proto.h
grass-addons/grass7/raster/r.mcda.electre/main.c
grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.html
Removed:
grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py
grass-addons/grass7/raster/r.mcda.electre/Makefile
Porting r.mcda.electre to grass7 with C language
Modified: grass-addons/grass7/raster/r.mcda.electre/Makefile
--- grass-addons/grass7/raster/r.mcda.electre/Makefile 2015-08-02 18:36:42 UTC (rev 65810)
+++ grass-addons/grass7/raster/r.mcda.electre/Makefile 2015-08-02 21:54:18 UTC (rev 65811)
@@ -1,7 +1,9 @@
-MODULE_TOPDIR = ../..
+MODULE_TOPDIR = ../../..
PGM = r.mcda.electre
-include $(MODULE_TOPDIR)/include/Make/Script.make
+LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
-default: script
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster/r.mcda.electre/dominance.c
--- grass-addons/grass7/raster/r.mcda.electre/dominance.c (rev 0)
+++ grass-addons/grass7/raster/r.mcda.electre/dominance.c 2015-08-02 21:54:18 UTC (rev 65811)
@@ -0,0 +1,116 @@
+#include "local_proto.h"
+ * global function declaration
+void build_weight_vect(int nrows, int ncols, int ncriteria,
+ struct Option *weight, double *weight_vect);
+void build_dominance_matrix(int nrows, int ncols, int ncriteria,
+ double *weight_vect, double ***decision_vol);
+ * function definitions
+ int i, nweight = 0;
+ double weight_sum = 0;
+ while (weight->answers[nweight] != NULL)
+ nweight++;
+ if (nweight != ncriteria)
+ G_fatal_error(_("criteria number and weight number are different"));
+ for (i = 0; i < nweight; i++)
+ weight_vect[i] = (atof(weight->answers[i])); /*transfer weight value in double array */
+ weight_sum = weight_sum + weight_vect[i]; /*calculate sum weight */
+ weight_vect[i] = weight_vect[i] / weight_sum; /*normalize vector weight */
+ int row1, col1, row2, col2;
+ int i, j, k, cont;
+ double *row_sum_conc;
+ double *col_sum_conc;
+ double *row_sum_disc;
+ double *col_sum_disc;
+ row_sum_conc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+ col_sum_conc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+ row_sum_disc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+ col_sum_disc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+ k = 0; /* make pairwise comparation and build concordance/discordance matrix */
+ for (row1 = 0; row1 < nrows; row1++)
+ G_percent(row1, nrows, 2);
+ for (col1 = 0; col1 < ncols; col1++)
+ j = 0;
+ for (row2 = 0; row2 < nrows; row2++)
+ for (col2 = 0; col2 < ncols; col2++)
+ double conc = 0, disc = 0;
+ for (i = 0; i < ncriteria; i++)
+ double d;
+ d = decision_vol[row1][col1][i] - decision_vol[row2][col2][i];
+ if (d >= 0 )
+ conc += weight_vect[i];
+ if (d < disc) /*WARNING: if(d>conc) */
+ /**/ disc = -d;
+ row_sum_conc[k] += conc;
+ col_sum_conc[j] += conc;
+ row_sum_disc[k] += disc;
+ col_sum_disc[j] += disc;
+ j++; /* increase rows index up to nrows*ncols */
+ k++; /* increase columns index up to nrows*ncols */;
+ /*calculate concordance and discordance index and storage in decision_vol */
+ cont = 0; /*variabile progressiva per riga/colonna della concordance_map */
+ /*fill matrix with concordance index for each DCELL */
+ decision_vol[row1][col1][ncriteria] =
+ row_sum_conc[cont] - col_sum_conc[cont];
+ /*fill matrix with discordance index for each DCELL */
+ decision_vol[row1][col1][ncriteria + 1] =
+ row_sum_disc[cont] - col_sum_disc[cont];
+ cont++;
Added: grass-addons/grass7/raster/r.mcda.electre/local_proto.h
--- grass-addons/grass7/raster/r.mcda.electre/local_proto.h (rev 0)
+++ grass-addons/grass7/raster/r.mcda.electre/local_proto.h 2015-08-02 21:54:18 UTC (rev 65811)
@@ -0,0 +1,23 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#include <grass/config.h>
+struct input
+ char *name, *mapset; /* input raster name and mapset name */
+ int infd;
+ void *inrast; /* input buffer */
Added: grass-addons/grass7/raster/r.mcda.electre/main.c
--- grass-addons/grass7/raster/r.mcda.electre/main.c (rev 0)
+++ grass-addons/grass7/raster/r.mcda.electre/main.c 2015-08-02 21:54:18 UTC (rev 65811)
@@ -0,0 +1,237 @@
+ * MODULE: r.mcda.electre
+ * AUTHORS: Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
+ * PURPOSE: Make a multicriterio decision analysis based on ELECTRE algorthm
+ * COPYRIGHT: (C) GRASS Development Team (2008)
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
+#include <stdio.h>
+ * main function
+int main(int argc, char *argv[])
+ struct Cell_head cellhd; /* it stores region information, and header information of rasters */
+ char *result_concordance, *result_discordance; /* outputs raster name */
+ char *mapset; /* mapset name */
+ unsigned char *outrast_concordance, *outrast_discordance; /* output buffer */
+ char *message;
+ int i,j, ncriteria=0; /* index and files number*/
+ int nrows, ncols;
+ int row1, row2, col1, col2;
+ int outfd_concordance, outfd_discordance; /* output file descriptor */
+ RASTER_MAP_TYPE data_type; /* type of the map (CELL/DCELL/...) */
+ double *weight_vect, ***decision_vol;/* vector and matrix */
+ struct History history; /* holds meta-data (title, comments,..) */
+ struct GModule *module; /* GRASS module for parsing arguments */
+ struct Option *criteria, *weight, *discordance, *concordance; /* options */
+ struct input *attributes; /*storage alla input criteria GRID files and output concordance and discordance GRID files*/
+ /* initialize GIS environment */
+ G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
+ /* initialize module */
+ module = G_define_module();
+ G_add_keyword(_("raster,MCDA"));
+ module->description = _("Multicirtieria decision analysis based on ELECTRE method");
+ /* Define the different options as defined in gis.h */
+ criteria = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
+ criteria->key = "criteria";
+ criteria->type = TYPE_STRING;
+ criteria->required = YES;
+ criteria->multiple = YES;
+ criteria->gisprompt = "old,cell,raster" ;
+ criteria->description = "Input geographics criteria in information system";
+ weight = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
+ weight->key = "weight";
+ weight->type = TYPE_DOUBLE;
+ weight->required = YES;
+ weight->multiple = YES;
+ weight->description = _("Criteria weight(s) (w1,w2,..)");
+ concordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
+ concordance->key = "concordance";
+ concordance->type = TYPE_STRING;
+ concordance->required = YES;
+ concordance->gisprompt = "new,cell,raster";
+ concordance->answer ="concordance";
+ concordance->description = "concordance output map";
+ discordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
+ discordance->key = "discordance";
+ discordance->type = TYPE_STRING;
+ discordance->required = YES;
+ discordance->gisprompt = "new,cell,raster";
+ discordance->answer ="discordance";
+ discordance->description = "discordance output map";
+ /* options and flags parser */
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ G_message("Start: %s",G_date()); /*write calculation start time*/
+ /* number of file (=criteria) */
+ while (criteria->answers[ncriteria]!=NULL)
+ ncriteria++;
+ /* process the input maps: stores options and flags to variables */
+ /* CRITERIA grid */
+ attributes = G_malloc(ncriteria * sizeof(struct input)); /*attributes is input struct defined in top file and store alla criteria files*/
+ weight_vect=G_malloc(ncriteria * sizeof(double)); /*allocate memory fron vector weight*/
+ build_weight_vect(nrows,ncols,ncriteria,weight,weight_vect); /*calcolate weight vector*/
+ struct input *p = &attributes[i];
+ p->name = criteria->answers[i];
+ p->mapset = G_find_raster2(p->name,""); /* G_find_cell: Looks for the raster map "name" in the database. */
+ if (p->mapset==NULL) /* returns NULL if the map was not found in any mapset, mapset name otherwise */
+ G_fatal_error(_("Raster file <%s> not found"), p->name);
+ /* determine the inputmap type (CELL/FCELL/DCELL) */
+ /* data_type = Rast_map_type(p->name, p->mapset);*/
+ if ((p->infd = Rast_open_old(p->name, p->mapset))<0) /* G_open_cell_old - returns file destriptor (>0) */
+ G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),p->name, p->mapset);
+ Rast_get_cellhd(p->name,p->mapset,&cellhd);/* controlling, if we can open input raster */
+ G_debug(3, "number of rows %d", cellhd.rows);
+ p->inrast = Rast_allocate_buf(DCELL_TYPE); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL */
+ result_concordance=concordance->answer; /* store outputn name in variables*/
+ result_discordance=discordance->answer;
+ if (G_legal_filename(result_concordance) < 0) /* check for legal database file names */
+ G_fatal_error(_("<%s> is an illegal file name"), result_concordance);
+ if (G_legal_filename(result_discordance) < 0) /* check for legal database file names */
+ G_fatal_error(_("<%s> is an illegal file name"), result_discordance);
+ /*values = G_malloc(ncriteria * sizeof(DCELL));*/
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ /*memory allocation for-three dimensional matrix*/
+ decision_vol=G_malloc(nrows * sizeof(double*));
+ for (i=0; i<nrows; ++i)
+ decision_vol[i]=G_malloc(ncols * sizeof(double*));
+ for (j=0; j<ncols; ++j)
+ decision_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double)); /****NOTE: it's storage enven concordance and discordance index map****/
+ /* Allocate output buffer, use DCELL_TYPE */
+ outrast_concordance = Rast_allocate_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
+ outrast_discordance = Rast_allocate_buf(DCELL_TYPE);
+ /* controlling, if we can write the raster */
+ outfd_concordance = Rast_open_new(result_concordance, DCELL_TYPE);
+ outfd_discordance = Rast_open_new(result_discordance, DCELL_TYPE);
+ /*build a three dimensional matrix for storage all critera maps*/
+ for (i=0;i<ncriteria;i++)
+ for (row1 = 0; row1 < nrows;row1++)
+ Rast_get_row(attributes[i].infd, attributes[i].inrast, row1,DCELL_TYPE);/* Reads appropriate information into the buffer buf associated with the requested row*/
+ /*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row);*/
+ /* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array*/
+ DCELL v1 = ((DCELL *)attributes[i].inrast)[col1];
+ decision_vol[row1][col1][i]=(double)(v1);
+ build_dominance_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index*/
+ ((DCELL *) outrast_concordance)[col1] = (DCELL)decision_vol[row1][col1][ncriteria];/*write concordance map*/
+ ((DCELL *) outrast_discordance)[col1] = (DCELL)decision_vol[row1][col1][ncriteria+1];/*write discordance map*/
+ Rast_put_row(outfd_concordance, outrast_concordance, DCELL_TYPE);
+ Rast_put_row(outfd_discordance, outrast_discordance, DCELL_TYPE);
+ G_message("End: %s",G_date());
+ /* memory cleanup */
+ for (i = 0; i<ncriteria; i++)
+ G_free(attributes[i].inrast);
+ G_free(outrast_concordance);
+ G_free(outrast_discordance);
+ G_free(decision_vol);
+ /* closing raster maps */
+ Rast_close(attributes[i].infd);
+ Rast_close(outfd_concordance);
+ Rast_close(outfd_discordance);
+ /* add command line incantation to history concordance file */
+ Rast_short_history(result_concordance, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(result_concordance, &history);
+ /* add command line incantation to history discordance file */
+ Rast_short_history(result_discordance, "raster", &history);
+ Rast_write_history(result_discordance, &history);
+ exit(EXIT_SUCCESS);
Added: grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.html
--- grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.html (rev 0)
+++ grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.html 2015-08-02 21:54:18 UTC (rev 65811)
@@ -0,0 +1,40 @@
+<h2>DESCRIPTION</h2>
+<em>r.mcda.electre</em> is the implementation of the ELECTRE multicriteria
+algorithm in GRASS GIS environment. It is one of the available tools in the
+r.mcda suite. It requires as an input the list of raster representing the
+criteria to be assessed in the multicriteria evaluation and the vector of
+weights to be assigned. Every single cell of the GRASS region is considered
+as one of the possible alternatives to evaluate and it is described with
+the value assumed for the same cell by the raster used as criteria. There
+are two output files. One represents the spatial distribution of the
+concordance index, the other one of the discordance index. The optimal
+solution is the one presenting the maximum concordance value and the minimum
+discordance value at the same time.
+<h2>NOTES</h2>
+The module does not standardize the raster-criteria. Therefore, they must
+be prepared before by using, for example, r.mapcalc. The weights vector
+is always normalized so that the sum of the weights is 1.
+<h2>REFERENCE</h2>
+<p>Roy, B. (1971) Problem and methods with multiple objective functions
+ Mathematical programming 1, 239-266.</P>
+<p>Roy, B. (1990): The outranking approach and the foundations of Electre
+ methods , Document du LAMSADE, Paris.</P>
+<p>Janssen R. (1994) - Multiobjective decision support for environmental
+ management, Kluwer Academic Publishers.</P>
+<p>GRASS Development Team (2008)</P>
+<h2>SEE ALSO</h2>
+<em>r.mcda.fuzzy, r.mcda.electre, r.roughet, r.mapcalc</em>
+<h2>AUTHORS</h2>
+Antonio Boggia - Gianluca Massei<br>
+Department of Economics and Appraisal - University of Perugia - Italy
+<p>
+<i>Last changed: $Date: 2012-12-04 19:08:17 +0100 (mar, 04 dic 2012) $</i>
Deleted: grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py
--- grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py 2015-08-02 18:36:42 UTC (rev 65810)
+++ grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py 2015-08-02 21:54:18 UTC (rev 65811)
@@ -1,116 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r.mcda.electre
-# AUTHOR: Gianluca Massei - Antonio Boggia
-# PURPOSE: Elaborate several criteria maps and gets concordance and
-# discordance maps indices as a base for electre analysis
-# COPYRIGHT: c) 2010 Gianluca Massei, Antonio Boggia and the GRASS
-# Development Team. This program is free software under the
-# GNU General PublicLicense (>=v2). Read the file COPYING
-# that comes with GRASS for details.
-#%module
-#% description: Gets concordance and discordance maps indices for MCDA analysis
-#% keyword: raster
-#% keyword: criteria maps
-#% keyword: MCDA
-#%end
-#%option G_OPT_R_INPUTS
-#% key: criteria
-#% multiple: yes
-#% gisprompt: old,cell,raster
-#% key_desc: name
-#% description: Name of criteria raster maps
-#% required: yes
-#%end
-#%option
-#% key: weights
-#% type: double
-#% description: weights (w1,w2,...,wn)
-#% multiple: yes
-#% required: yes
-#%end
-#%option G_OPT_R_OUTPUT
-#% key: concordancemap
-#% type: string
-#% gisprompt: new_file,cell,output
-#% description: output concordance raster map
-#% answer:concordance
-#% required: yes
-#%end
-#% key: discordancemap
-#% type: string
-#% description: output discordance raster map
-#% answer:discordance
-#% required: yes
-#%end
-import sys
-import grass.script as gscript
-from grass.pygrass import raster
-def preprocessing(attributes,weights):
- matrix=[]
- for attribute in attributes:
- c=[]
- criteria = raster.RasterRowIO(str(attribute))
- #criteria.is_open()
- criteria.open('r')
- for row in criteria:
- c.append(row)
- matrix.append(c)
- criteria.close()
- print len(matrix),weights
- print dir(criteria)
-def concordance(attributes,weights,concordanceMap):
- i=0
- listMaps=[]
- for attrRow,weight in zip(attributes,weights):
- for attrCol in attributes:
- concordanceMap="conc_%s" % str(i)
- formula="%s=if(%s>%s,%s,0)" % (concordanceMap,attrRow.split('@')[0],attrCol.split('@')[0],weight)
- gscript.mapcalc(formula,overwrite = True)
- listMaps.append(concordanceMap)
- i=i+1
- endMap="%s=%s" % (concordanceMap,("+".join(listMaps)))
- gscript.mapcalc(endMap,overwrite = True)
- gscript.run_command("g.remove", type='raster',flags='f', name=",".join(listMaps))
- return 0
-def discordance(attributes,discordanceMap):
- i=0
- listMaps=[]
- for attrRow in attributes:
- discordanceMap="conc_%s" % str(i)
- formula="%s=if(%s>%s,%s-%s,0)" % (discordanceMap,attrRow.split('@')[0],attrCol.split('@')[0],attrRow.split('@')[0],attrCol.split('@')[0])
- listMaps.append(discordanceMap)
- i=i+1
- endMap="%s=max(%s)" % (discordanceMap,("+".join(listMaps)))
- return 0
-def main():
- options, flags = gscript.parser()
- attributes = options['criteria'].split(',')
- weights = options['weights'].split(',')
- concordanceMap= options['concordancemap']
- discordanceMap= options['discordancemap']
- concordance(attributes,weights,concordanceMap)
- discordance(attributes,discordanceMap)
- return 0
-if __name__ == "__main__":
- sys.exit(main())
