[GRASS-SVN] r65815 - grass-addons/grass7/raster/r.mcda.electre
Sun Aug 2 22:58:32 PDT 2015
Author: gianluca
Date: 2015-08-02 22:58:32 -0700 (Sun, 02 Aug 2015)
New Revision: 65815
   grass-addons/grass7/raster/r.mcda.electre/local_proto.h
Modified: grass-addons/grass7/raster/r.mcda.electre/local_proto.h
--- grass-addons/grass7/raster/r.mcda.electre/local_proto.h	2015-08-03 05:57:35 UTC (rev 65814)
+++ grass-addons/grass7/raster/r.mcda.electre/local_proto.h	2015-08-03 05:58:32 UTC (rev 65815)
@@ -15,8 +15,8 @@
     void *inrast;		/* input buffer */
-void build_weight_vect(int nrows, int ncols, int ncriteria,
-                       struct Option *weight, double *weight_vect);
+void build_weight_vect(int ncriteria, struct Option *weight,
+						double *weight_vect);
 void build_dominance_matrix(int nrows, int ncols, int ncriteria,
                             double *weight_vect, double ***decision_vol);
