[GRASS-SVN] r65818 - grass/branches/releasebranch_7_0/gui/wxpython/vdigit
svn_grass at osgeo.org
Mon Aug 3 05:54:05 PDT 2015
Author: neteler
Date: 2015-08-03 05:54:05 -0700 (Mon, 03 Aug 2015)
New Revision: 65818
grass/branches/releasebranch_7_0/gui/wxpython/vdigit/g.gui.vdigit.html
g.gui.vdigit manual: update 'Copy features from (background) vector map' description (contributed by Aldo Clerici)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/vdigit/g.gui.vdigit.html
--- grass/branches/releasebranch_7_0/gui/wxpython/vdigit/g.gui.vdigit.html 2015-08-03 12:53:38 UTC (rev 65817)
+++ grass/branches/releasebranch_7_0/gui/wxpython/vdigit/g.gui.vdigit.html 2015-08-03 12:54:05 UTC (rev 65818)
@@ -66,12 +66,11 @@
Loading it within the digitizer is different from simply loading it via
<em>Layer Manager</em> since direct interaction with single vector features
then becomes possible.<br>
-A background map can be selected from the map layer contextual menu, in
-<em>Layer Manager</em> ("Use as Background Map"). Newly digitized vector
-features are snapped in the given threshold to the features from the
-background map. Vector features may be also copied from the background
-map by "Copy features from (background) vector map" tool
-from the digitizer toolbar.
+Vector features may be copied from the background map by "Copy features from
+(background) vector map" tool from the "Additional tools" of the
+digitizer toolbar.
+Newly digitized vector features are snapped in the given threshold to the features
+from the background map.
<h3>DIGITIZER TOOLBAR</h3>
@@ -177,7 +176,7 @@
layer/category pairs are not removed from category settings of
the target features.</li>
- <li><em>Copy features from (background) map</em><br> Make identical copy of
+ <li><em>Copy features from (background) vector map</em><br> Make identical copy of
selected vector features. If a background vector map has been
selected from the Layer Manager, copy features from background
vector map, not from the currently modified vector map.</li>
